Question about Refrigerators
My refigerator leaves too much moisture in the refigerator. Everything has mositure on it.
  • 93 Answers
99 percent of the time that is from leaking door gaskets or a door not closing completely. The moisture you are seeing is from air entering the refrigerator and the moisture in the air condenses to water. Check the door gaskets for a good seal all around and make sure there is no gaps anywhere when the doors are shut.
Posted on Sep 14, 2009
Mositure in watch how can I get rid of it
You could remove the back and place the watch somewhere warm and dry for a day or so. As your watch is an automatic, you would have to be very carefull to make sure no dirt or contaminants entered the watch.
However, I'd recommend thath you have it looked at by a professional - the watch is supposed to be water-resistant to 50 metres but there is moisture inside which suggests that the seals have failed.
Jun 25, 2015 | Fossil Watch Style # ME1026 Watch for Men
Dryer won't shut off.
Will the timer advance in the NO HEAT mode? If it does advance you would know it has something to do with the temp alright but if it don't advance in No Heat then the timer motor is bad in my opinion. And it can fail by more than one way. Open winding OR stripped motor gear.
Aug 30, 2012 | Maytag Dryers
2001 4.8lit i have mositure inside onpass floor with hearter on and air off . when i feel by inside firewall the 2 air cond lines cold but heater working fine
ok is it water in your floor board or moisture if its water you heater core is leaking and needs to be replaced/ most of the time moisture on pass side floor is always a heater core prob/ if you need instructions on changing it let me know
Sep 23, 2011 | 2001 Chevrolet Silverado
The Samsung GTC3300 mobile unit had dropped and wet. so the power does not ON and does not Charging.
Make sure that the battery was removed immediately and the phone kept for drying. Use some warm air blown to the battery compartment to dispel any moisture. Also you can pack the phone with some mositure absorbants like silica gel.
If you are able to open then remove and dry the board and ONLY when the boards are confirmed to be DRY you must insert the battery back. If there is function fault then you need help and consensus from a service center.
Aug 11, 2011 | Samsung GTC3300 Cell Phone
There is water coming out from under the dryer. I have checked and there is nothing wrong with the washer.
Check and insure the vent is clear. A clogged vent will prevent mositure from leaving dryer, as this moisture builds it will pool at the low spot or appear to be leaking from the dryer. A second possibility which I am sure you have already checked is that the clothes are not being thoroughly rung out in the wash cycle. If they are dripping wet when placed in the dryer, access mosture could leak out as well.
Mar 02, 2011 | Kenmore Dryers
Phone will not power up
Better get that warranty card if you have it. or repair / service shop is the next stop. sorry.
May 15, 2009 | Motorola Mobility E815
No Heat on any cylce
when that happened to mine i replaced the moisture sensor and all is well....easy and cheap.
Jun 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Refrigerators Logo
523 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
