Question about Samsung Dryers
Samsung dryer has hour glass on display and will not start
Model # DV42H5600EP/A3 :the dryer will not start in any cyle. The drying indicator is lit up but it is not starting and an hour glass is in the display beside the timer counting down.
    Problem Solver:
  • 12 Answers
Have you tried unplugging it for a minute or so?
Posted on Aug 21, 2019
SOURCE:
codfish124
  • 36 Answers
SOURCE: Whirlpool dryer will not stay on, no heat, and timer acts weird
sounds like the motor or the even heat board is out i would say the even heat board is more likely
Posted on Dec 09, 2008
  • 10865 Answers
SOURCE: MAYTAG MAH5500BWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Posted on May 23, 2009
  • 43 Answers
SOURCE: Samsung front load clothes dryer not working.
may have loss to one line of voltage.may only have half the voltage required to power the machine.make sure proper voltage is coming to wiring block at bak of machine.may need voltage meter.
Posted on Oct 16, 2009
rickead1
  • 1998 Answers
SOURCE: samsung dryer dv317aeg/xaa has code on display
http://www.washingmachinereviews.org.uk/fault-codes/errors-and-solutions/ use this site try this solution is what the company suggests simply folo down the list till u see your error code with there solution if this does not work u willhave t call a tech to do test on your heater as well as the wiring going to the heater
Posted on Jul 26, 2010
richroth
  • 9472 Answers
SOURCE: my kenmore elite dryer will not start up,all the
There are some things about the "Check Lint Screen" light you should know. It's a reminder light and doesn't actually check anything. When you select a cycle it should come on and stay on until the Start button is pressed, the door is open or after 5 minutes.
If the Control Lock is not turned on then you may have to replace the console/interface to resolve this problem.
A hard reset is used to describe a reboot process. With the dryer stopped and the control turned off (if possible), unplug the dryer to completely disconnect electrical power. If it is difficult to reach the dryer outlet plug, you can shut off the breaker for the dryer to completely disconnect electrical power. Leave the electrical power completely disconnected for 5 minutes. This will sometimes reset a control board that is stuck due to a power surge or glitch encountered through the electrical lines. Plug the dryer back in to see if the control will operate properly.
If the control does not reset and work normally after the hard reset, then you could have a stuck "touch up" button on the control. The image below describes a diagnostic test mode that can be entered to check the buttons on the control. If you are able to enter this mode, you can check to see if the "touch up" button is stuck. You may not be able to enter this mode with a stuck button, bad user interface control board or a failed machine control board. If the dryer will not go into this diagnostic test and the console will not respond to other cycle selections, then I recommend calling a service technician to diagnose and repair the dryer. It is likely that the user interface control board will need to be replaced.
Test Mode Sheet
Posted on Dec 11, 2010
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
www.samsung.com/uk/support/skp/faq/1025253
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
www.samsung.com/ca/support/skp/faq/230147
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
MACHINE OPERATION
docs.whirlpool.eu/_doc/501930002795EN.pdf
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
501930001546EN.pdfDOWNLOAD
Jan 01, 2016 | Dryers
Dryer shuts off during cycle
DOES IT START RIGHT AWAY OR ABOUT AN HOUR LATER? IF LATER U MAY HAVE A BAD MOTOR WINDINGS PROBLEM? OR A BAD CYLING THERMOSTAT, MOISTER SENSOR NOT DETECTING DRYNESS OR DETECTING DRYNESS WHEN ITS NOT DRY?
Feb 27, 2015 | Whirlpool LER5636P Electric Dryer
Samsung dryer where to press cancel on hour glass pops up
An hour glass on the display, it is normal. The hour glass is there to let you know that there is a cycle in progress.
Nov 24, 2012 | Samsung 7.3 Cu. Ft. Electric Dryer
An hour glass pops up on my Samsung dryer and will not start. What does this meen?
It means it has been set for a timed drying period. When the time passes it should be OK or press to cancel the timer function.
Hope that helps.
Nov 27, 2011 | Samsung 7.3 Cu. Ft. Electric Dryer
Samsung DV410AGW Dryer My dryer which is brand new will not start. It appears to have an hour glass on the control panel which i have not seen before. dryer will not start even after i unplugged it...
Sorry to take so long. I have been talking to Samsung support. the hour glass indicates that the dryer is in a cycle, but as it wont start and you've tried unplugging it, it seems there is a fault. Your dryer is new, so you need to contact Samsung for a service visit:
http://www.samsung.com/us/support/service/request
Before doing this, try unplugging the dryer again and this time leave the power off for a few hours - assuming you haven't done this already. It might reset if you do this.
I've pasted a transcript of my conversation with Samsung below. I pretended to be the appliance owner as otherwise they would not answer my questions!
Hope this helps!
info: Please wait for a Samsung Agent to respond.
info: All Samsung Agents are currently assisting others. Thanks for your patience. A Samsung Agent will be with you shortly.
info: You are now chatting with 'Darlene'
Darlene: Hi, thanks for reaching out to Samsung tech support. How can I help you today?
Nick: Good evening
Darlene: I see that you are not chatting from USA. Let me know the place of purchase of the unit.
Nick: USA
Darlene: Please let me know the Samsung Unit model number you have. You can find the model number on the label attached to the right side of the Unit.
Nick: DV410AGW
Darlene: Let me know the exact issue you have with the Dryer, so that I can assist you to isolate and troubleshoot the issue.
Nick: Ok - the dryer is displaying the hour glass symbol, but it's not on a drying cycle
Nick: I tried unplugging it but it hasn't reset
Darlene: Let me know if the dryer works fine when you select any cycle.
Nick: it wont start
Nick: Is there some way of resetting the dryer? I think there is a programme stuck in memory
Darlene: Let me know if you are using Dryer in UK.
Nick: no
Nick: I'm working here for 2 days
Darlene: If your dryer is showing an hour glass on the display, it is normal. The hour glass is there to let you know that there is a cycle in progress.
Nick: I know this. I read the FAQ
Nick: But it wont start and the symbol remains even after it's been unplugged
Nick: Can it be reset?
Darlene: Let me know if you have tried to unplug and replug the unit from different wall outlets.
Nick: Cmon, be serious
Darlene: There is no option to reset the Dryer, only way is to unplug and replug the unit from power.
Nick: It's not my outlets
Darlene: I am sorry, a physical diagnostic is necessary to determine the exact defective part on your device.
Nick: I left it unplugged while I am away
Nick: I will try when I get home
Darlene: I recommend you file online service request to schedule service appointment, there you can get the Service Center information, so you can contact them.
Darlene: Would you like me to provide you with the link to fill out an online service Request?
Nick: Yes please
Darlene: Visit the link given below to file an online service request to get the Dryer serviced:
Darlene: http://www.samsung.com/us/support/online/supportOnlineServiceRequest.do
Darlene: Fill the required information to schedule the Service for your Dryer.
Nick: Please answer one more question for me . . .
Darlene: Sure, please go ahead with your question.
Nick: Is the dryer equipped with a memory so in the event of a power failure, it will restart when the power returns?
Darlene: When power fails, Dryer will start from the beginning of the cycle.
Nick: OK, so unplugging it should fully reset it?
Darlene: Yes.
Nick: OK, If that's the case I definitely need a service request
Nick: Thanks for your assistance
Nick: Have a good evening
Darlene: You're welcome. Is there anything else I can assist you with?
Nick: No thanks
Darlene: Thank you for chatting with us. If you have a minute, please click on the blue "X close" button to receive a transcript of your chat and fill out a brief survey to help us serve you better. Have a Good Day!
Nick: Goodnight
Oct 20, 2010 | Samsung DV410AGW Dryer
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
Dryers Logo
42 people viewed this question
Top Samsung Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Mike
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
