Question about Apple iPhone 3G
I phone not charging since it fell into water. when it fell into water i had problem with speakers, but later that resolved, once no more charge in the battery, i try to charge it now and nothing will happen when attached to computer or wall outlet.
Hi i have a huawei y220 it fell in water and now it charges but does not want to be on what must i do
ufortunately in the user manual for your phone there are safety lists once a phone like yours is in conditions such as water damage or any other on the list, the phone will not work properly, what i can suggest if you are on a warrenty and the warrenty has not expired yet, get ahold of the company and tell them you accidently dropped your phone in water and need a replacement.
Aug 13, 2014 | Cell Phones
Phone fell down in toilet. got it out dried with blow dryer but its not charging up now.
This could solve your problem : http://www.wikihow.com/Save-a-Wet-Cell-Phone ...but you have to consider the possibility that the phone is damaged and needs to be rapaired or replaced...
Jun 13, 2011 | Sony Ericsson XPERIA X10 Cell Phone
My Ipod touch fell down my wooden stairs -only a few stairs- but it fell, nevertheless. It still seems to work perfectly. What a relief! However, I just tried to give it a little bit of a charge before the...
Your relief was short lived. Though the fall did not damage the player itself it appears to have damaged the power supply side of the unit. Perhaps the charging socket got a direct hit and has broken internally. I think you will have to take this to a repair shop as it could need some parts.
Jul 06, 2017 | Apple iPod touch
Trouble is it fell in to some (water handset only) Dried out over 2 months but then battery wouldn't charge properly. Bought new battery and it charges but does not stay charged and then everything on...
sounds as its still damp inside of handset. u could strip down and make sure the water hasnt coroided any contacts which is making it discharge to earth.
with regurds replacement handsets , i have been looking for spare base as mine is just started going and cuts calls off ( sound like dry joint in base unit or power supply is giving up) try a philps dealer to see what spares philps have other than that it secound hand units.
Jan 23, 2010 | Philips Zenia 300 TU7370 Cordless Phone
My cordless phone fell in water. I have dried it and used it to make a call successfully once. It then prompted me with a message to charge the battery. After the phone sat on the charger it began to...
Usually ,phones don`t survive in water. But the best shot is to remove battery from the phone,dry the battery compartment with kitchen towel and battery.
Now leave it in a warm room for 24 hours(NOT on a RADIATOR, reconnect and fingers crossed for you !
Dec 27, 2009 | Panasonic KX-TG5651S 5.8 GHz 1-Line...
The screen of my nokia e66 does not light up
The problem is inside your phone inside your phone The wire may be damage by falling
May 27, 2009 | Nokia E66 Smartphone
Ive got a Razr phone and it's not charging??
the battery is no good, the battery charges but it can't hold the charge. This could be because of age or damage.
Apr 15, 2008 | Motorola Mobility RAZR V3
Phone got wet
I would definately let it dry out fully. Take the battery out and take it apart as much as you can and place in front of a fan (probably overnight). If there was water in the phone when you plugged it in it could permanently damage the phone. Even though the outside is dry, there could still be some water inside. I once had a remote control in a swimming pool overnight and followed these instructions and it worked fine after a couple days of drying. Hope this helps!
Nov 06, 2007 | Motorola Mobility RAZR V3
Water
yes it can be fixed. it has to be rinsed in some chemicals to take the water out, thereafter need to load softwmare
Oct 24, 2006 | Nokia 6230
Apple iPhone 3G Logo
220 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
