Question about Hunter Dryers
Hunter ceiling fan stopped responding to switch. Switch serms alive as signal light appears when button pressed. Is it the cspacitor?
    Master:
  • 456 Answers
I DON'T KNOW. IF FAN HAS PULL CHAINS, PLEASE CHECK TO SEE IF THEY ARE IN ON POSITION AND TRY REVERSING DIRECTIONS A FEW TIMES.
Posted on Aug 30, 2019
Testimonial: "Thanks for replying. However, the light and the fan are both not functioning. Do these fan types have a fuse somewhere? Could the wall switch (controls light and fan speed) have blown out??"
  • Jim Hicks
    Jim Hicks Sep 06, 2019
    right Mike, seldom is but it might be fuse or circuit breaker in your main electrical panel.
SOURCE:
SOURCE: Remote control ceiling fan
I am changing the remote in hunter fan an i got the wires mixed up coming from the fan what wire goes where?
Posted on Apr 12, 2008
  • 10865 Answers
SOURCE: How do you set the switch for 3 adjacent ceiling fans
Each remote/fan unit has to be set to a different code otherwise you will always have this problem. Open up one of the remotes and you will see the area where the numbers can be selected, usually one thru five. Then remove the cover on the fan at the ceiling and you will see the same set up. Just go from unit to unit and do not use the same code on any two fan/remote sets and your problem is solved.
Posted on Jul 31, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
  • 351 Answers
SOURCE: Westinghouse Lighting 3speed Ceiling Fan Switch 7707500: I just replace the speed control switch in my Hunt...
Typically the old and new switches have no relative relationship to each other .. One way to figure this out is shut off the power and then using the black power wire attach each speed wire to it and turn power back on to observe the speed .. mark the wire with the speed 1, 2, 3, .repeat this untill all the wires are identified .. . then you can put the wires on the appropriate terminations on the new switch ..
questions ..
Please vote !
Posted on Jun 04, 2010
Hunter Ceiling Fan Remote Works Sporadically
The part that receives the signal from the remote control is the receiver which is located in the motor housing.
Apr 29, 2017 | Hunter 27148 Remote Control
Hunter ceiling fan pull chain for fan broke
First write down which color wire goes in which slot on switch.Turn power off! Disconnect wires from defective switch by inserting a paper clip or something a little bigger into the wire connection.Then press the spring down and release the wire to insert in new HUNTER switch. DO NOT CUT WIRES!Call 1-888-830-1326 with model # to order the correct switch.
Mar 24, 2013 | Hunter (25417) Ceiling Fan
I have a Hunter ceiling fan with light kit. The controls for the fan and light are on the wall. It is a Hunter dimmer and 3 speed control switch. The fan works fine and the lights do not come on. I have...
Usually you have to press the light switch 3 times and hold to get dim effect adjustments, it is often radio transmitted in some newer models, if the pull switch is bad replace it anyways it could be dangerous if let alone!
Aug 23, 2009 | Hunter (25417) Ceiling Fan
Hunter ceiling fan. Lights and fans turn on and off by themselves.Both fans are on the same wall switch and are operated by separate remotes.
I just installed a 2nd hunter fan model 23811 that also seems to be controlled by grimlins. If the power is left on, the light and fan randomly turn on and off. And no, it is not due to fans being on the same frequency. It appears to be an issue with the control module. I'm contacting Hunter.
Jul 26, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Jun 20, 2009 | Hunter Ceiling Fan Remote Receiver...
Hunter Fan - Remote
Most likely the fan turns on with a wall switch and then as long as the power is there [ wall switch left in on position], the remote works
Apr 26, 2009 | Universal Remote Control Hampton Bay...
Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Mar 15, 2009 | Hunter Low Profile III 20807 Ceiling Fan
Remote control fan
I had the same problem and I thnk Hunter Fan knows about it....I just called Hunter Tecnical Support at 901-745-9222 and they sent me a new White circular receiver which goes inside of the canopy and it worked fine after installing the receiver....
Mar 14, 2008 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Dryers Logo
Top Hunter Dryers Experts
Joe Paxton
Level 1 Expert
Paul Bade
Craig Butler
Craig Butler
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
