Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
HOW TO I GET INSIDE A NEPTUNE DRYER MODEL 9700 TO FIX A FUSE
  • 220 Answers
Unplug the unit.
Remove the top panel(two bolts in the rear metric 10 or Phillips will work) There are four screws across the top front of the control panel remove those and the panel will swing out and down,move it back and forth while pulling upward it has plastic clips on the bottom that keep it in place.follow the wires from the panel to the control board and unplug them or you can just lay the whole panel on top of the unit.
Open the dryer door and remove the two phillips screws on either side at the bottom of the door opening,then remove the four screws across the top of the panel it will lean out toward you,unplug the door/light switch and lift the front panel off the bottom clips.
You're probably looking for the thermal fuse located in the plastic elbow of the blower housing at the bottom of the unit it will be the round metal disc with a brown or black plastic backing.check your vent going outside and make sure it is completely clear/open doesn't have to be spotless clean but if it gets restricted in any manner it will blow this fuse.
Posted on Sep 13, 2009
  • TomZS Sep 13, 2009
    Oh and if you have any questions or problems let me know....hope this helps
Maytag Neptune Dryer, Light inside with door open, but no lights up on top and does not run, can you please help me out, or where to start?
Check the breaker or fuse box. Sounds like one leg of the 220 volts is tripped. Reset it or replace the fuse if so.
Oct 19, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Control panel not lighting up
there is a fuse inside the machine but try to unplug it for 15 mins to reset and see what happens
Sep 15, 2008 | Maytag Neptune MDE5500AY Electric Dryer
I have a maytag neptune model mdg5500aww gas dryer. the light comes on but it wii not let me program it to start or stop what could be wrong? is there a way to troubleshoot
1) The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
2) Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
it is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3) Timer may be defective
Mar 13, 2011 | Maytag Neptune MDG5500AW Gas Dryer
How do you get inside a Neptune Dryer. and then i have to figure out why the dryer is not heating?
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel (which comes apart for testing thermal fuse) to the exhaust duct. Please get back to me if you have any other questions.
Kevin
Jan 17, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag Neptune gas dryer has stopped heating The button pannels turn on, dryer spins but no heat I cleaned the vents Model no. MDG6800AWW How do I fix it? Can I repair it myself? Is there a...
When the dryer wont heat it is the thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset.
Hope this will help...
Dec 30, 2010 | Maytag Neptune MDG5500AW Gas Dryer
We have a neptune dc that will not heat up. would also know how to take it apart?
When the dryer won't heat it is the thermostat/thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset.
Hope this will help....
Dec 29, 2010 | Maytag Neptune MCE8000AY Electric Dryer
One of the paddles inside the dryer has come loose, how can I fix this?
remove door screws and screws on opposite side. pull front forward and down. remove two brackets at top corners to raise top (unplug machine of course). screws are on outside of drum.
Jun 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Water leak from bottom of Maytag Neptune washer
The water pump is cracke,. replace the water pump. Peter
Mar 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
MDE 9700 AYW Maytag neptune dryer
My dyrer just stopped working one day. I've had the heating element checked, both boards and my electrical outlet checked but my dryer still doesn't work. All I get is a troubleshooting code that looks like an upside down F with a 5 behind it. If you have a solution to this problem please let me know Thank You.
Dec 05, 2007 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
301 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
