Question about Electrical Supplies
The natural s supplied generators that we use for
The natural gas supplied generators that we use for heating need to be restarted as a result of the gas supply having been lost.
  • 36 Answers
Fix another regulator before gen set gas supply
Posted on Sep 14, 2009
When a generator is heating after a few minutes what could be the cause
not enough information to answer. gas or propane?. if new,generator by it's very nature generates energy,and thereby heat. even coiled wires can get warm. what part is hot?
if you've owned it a while, and it is inordinately hot as compared to prior uses, is it lubricated ? running normal otherwise?
Jan 21, 2015 | Electrical Supplies
Generator is two yrs old only had a couple of outages maybe totaling thirty hrs Generator ran great and also ran every wk for its exerciser cycle. The generator didn't start on this cycle and the system...
Is this a natural gas fueled generator? Sounds like a fuel problem, i would go through the fuel system and find out whats wrong. If its a natural gas/propane unit its most likely a bad regulator or low pressure.
May 04, 2017 | Eaton Electrical Supplies
Pilot light lights but goes out when I turn the main heater on / off switch
clean silver supply line to pilot generator sounds like cob webs not enough gas going to pilot make sure pilot generator is good also
Aug 24, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
I own an older Jandy Lite 2. The pilot light is on. After the heater runs for a while it gwets very hot and then turns off making it impossible to re-start. Electician restarted by replacing wire that...
over temp situation causing high limits to open. inspect venting, heat exchanger. ensure proper gas/air mixture, proper ventilation and combustion air supply
Aug 19, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
I want to connect my heating system with my generator. It's a forced hot air system natural gas by York.
yes, you need to have at least 120volts and make sure your generater can power at least 3000 watts min not peak.
if you have an extension cord and must find the supply to the furnace
then splice the cord to the supply
then plug it in and there you go.
Nov 02, 2012 | Heating & Cooling
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Cozy heater
I can help with part of this problem. The thermocouple is a sensor right next to the pilot flame. When heated by the pilot flame, it generates a small voltage. This voltage opens a small valve and feeds gas to the pilot. If the pilot light should go out, the thermocouple stops generating voltage. This causes the gas valve supplying gas to the pilot to shut off. I oversimplied the way it works. If this does not make sense. Google how a thermocouple works.
Oct 11, 2008 | Cozy Enclosed Front Console Heater 70,000...
Electrical Supplies Logo
62 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
