Question about Tag Heuer WK1120.BB0314 Wristwatch
I have lost the connecting pin link on my watch which connects the watch to actual strap, where can i buy a new one
  • 183 Answers
This is most likely a metal band and the part you are talking about is the head piece. I do not know of any outlets that sale the head piece by itself. You will most likely have to buy a replacement band either from the watch manufacturer or an after market watch band supplier like Speidel.
Posted on Sep 18, 2009
    Sergeant:
  • 302 Answers
Another possibility is a watchmaker. I never through "endpieces" away. I have hundreds because people lose the spring bar and the endpiece falls off quite regularly. Find a watchmaker.
Posted on Nov 07, 2011
NEW STRAP FOR 11299J POLICE WATCH
Barry, It is more and more common these days for a watch to have a unique band, unique unto itself. The only way some bands can be purchased is from the manufacture or seller which I presume is Shop NBC. Call them. I actually couldn't find your specific watch on the site but unless it is a watch with the "traditional lugs" you will need to go there. Michael
Nov 07, 2011 | Watches
How do you remove links from a casio watch strap S-1183DV on watch WV-59DU ?
You will need to hold the watch firmly in your hand, with the side pointing up. Make sure that you can grip it firmly. If you have trouble holding onto the watch, place it on a stable surface. Make sure that the side is facing toward the ceiling and locate a connecting pin. There will be a connecting pin on each link of the watch band. Select a link, and hold the eyeleteer over the connecting pin for that link. Carefully place the eyeleteer onto the connecting pin. Push gently but firmly until the connecting pin slides partially out the other side. Occasionally, the pin will be difficult to push through the slot. If this is the case, gently tap it though with a standard hammer. Using a pair of pliers, pull on the connecting pin carefully until it slides out. Keep a firm grip on the watch band so that the links do not come apart before you are ready for them to. Separate the Casio watch band. Repeat this process with additional links until the watch band is as small as you would like it to be. Reconnect the band by tapping or pushing a connecting pin into the band where it is disconnected.
Aug 06, 2011 | Casio Watches
I have a Casio GW 500 watch with screws securing the strap. I have ordered and received the new watch band but cannot determine how to remove and replace the screws (which substitute for the spring bars...
The screws are for display on the strap they are actually just a pin on each strap you can push the pin through with a small flat head screw driver it takes a little while bit fidely. First time I have done it. It took me 20 mins
May 19, 2011 | Watches
WHERE CAN I BUY A NEW STRAP AND PINS FOT A TCM
mcdevito75 here, Any small watch repair shop in your area could help out.
Jun 22, 2010 | Watches
My festina watch has lost the pin that attaches the strap to the actual watch
Most watches use a standard size pin. Try your local watch shop.
May 11, 2010 | Watches
I have lost the pin link connecting from the strap to the watch on my tag heuer, where can i get a new one? do i have to go to a shop or can i buy it online?
You should go to shop. If that pin is not 24K gold they may give you one for free. Or scavenge a cheap watch for the part you need.
Hope it helps.
Sep 13, 2009 | Tag Heuer Link Quartz WJ1110.BA0570 Wrist...
Watch strap adjust
Not all watch bands are adjustable. If yours is, you will see the links are connected with tiny pins. Any store that sells watches will have the tool to remove links. Some watches require a special tool, those need to be adjusted at a store that sells that brand.
Nov 06, 2008 | Watches
Broken strap.
contact Cartier. www.cartier.com Donald
May 20, 2007 | Cartier Santos W20056D6 Wrist Watch
Removing links
It?s very tough to remove the links, I would recommend taking it to a dealer If you have to, you will either need a fine punch (or very masonry nail), a medium hammer, and a piece of wood a couple of inches square, a rag or wash cloth. A sturdy flat blade watch makers screwdriver. The ones from a dollar store may not work, and a pair of pliers. There are two types of links, both of them are a pig to remove, expect lost fingers, lots of swearing and possible scratched strap. Version one, The one I think you have, Place the watch strap flat on something hard, put a cloth under it so it will not mark, the outside of the strap will be on the cloth and you will see the arrow, there is a rectangle with a nipple recessed inside. Place the blade of the screwdriver between the nipple and the edge of the rectangle, press down and wiggle between the nipple and the edge and twist, there will be a locking pin which comes out of the side link, in the direction of the arrow. Wiggle away until you can free the locking pin. It?s simpler to put them back. Version two, Place the rag folded a couple of times on the block of wood Place the strap on the rag so it?s on it?s side, hang the watch over the edge of the block so the strap is flat against the block and there is nothing touching the watch (hanging in air) Look at the edge of the strap, see the small pin, in the fold of the metal, punch it out (down into the cloth) enough to then grab it with the pliers, I actually drilled a small hole in the block of wood so the pin would be pushed into that rather than against the wood, but don?t drill holes in your dining table! I would still recommend taking it to a dealer,
Apr 05, 2007 | Fossil BQ9183 Wrist Watch
Tag Heuer WK1120.BB0314 Wristwatch Logo
478 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
