Question about Ovens
My Gemini Petit Chef multi-function oven's display is flashing 0-.-- and the oven does not switch on after a power cut. I can set the time but the display alternates between the time and 0-.--.
3 Suggested Answers
SOURCE:
SOURCE: Defy thermofan flashing 0.00 and auto. I've tried pressing key 4
Hi
Can somebody please help
Thanks Terry
Posted on Jun 19, 2010
SOURCE: i have a defy gemini petit chef multi function
i have a defy gemini petit chef thermo fan oven.I only used it for about 20 times the warranty is over the fan works but the elements are not getting hot both the grill and bake.could you please tell me what the problem could be
Posted on Jun 21, 2010
Where is to cut out switch located in a gemini petite oven
if the oven is wired in to the house correctly
all ovens are hard wired into the house wiring
will be a trip switch marked" oven" on the house main power board outside ..
a fautly oven cant be used at all
call electrician for testing
ring for take out or home delivery meals
user manual link
OVEN DEFY GEMINI PETIT CHEF
https://www.defy.co.za/wp-content/uploads/.../Gemini-DBO472-DBO473-Manual.pdf
Oct 10, 2016 | Ovens
Beko built in double oven alarm after power outage
Switch oven on using the function knob (first knob on left hand side)then press and hold(for 3 to 5 seconds) the left top button right next to the display screen this should give you a chance to set the current time on the oven after setting the current time switch oven off at function knob and on agian problem should be solved
Jul 05, 2015 | Ovens
Forno sy36x oven.. following powercut, timer wont set, therefore oven wont come on. digits constantly flashing
after a power cut, the clock display will-automatically reset to 0:00 and begin to blink.
starting buttons left to rigth Press the
2nd and 3rd buttons simultaneously, release,
and then set the exact time (within 4 seconds) using
the +buttons.
advances the hours.
The button
- decreases the hours.
The time can also be changed in a second ways
1.Repeat all of the steps above.
2.Press the 4th
button, release, and then use the +and -
buttons to update the time.
Sep 23, 2014 | Ovens
Need illusrated wireing diagram for 18 year old defy gemini petit chef electric stove
Oven:
power comes in, goes to overtemp > timer > function switch > thermostat > element then back to neutral
fan & light come on with function or thermostat switch.
what else do you need to connect?
Oh, hotplates. Power in > infinite switch > hotplate and indicator then back to neutral.
Watch out for two phase with indicator light.
Oct 18, 2013 | Ovens
Wiring diagram of a Satchwell type70th thermostat switch
need wiring diagram for defy gemini petit chef oven switch
Dec 07, 2010 | Ovens
Hi
Thanks Terry
Jun 01, 2010 | Ovens
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
I have a defy gemini petit chef multi function themofan oven but dont have a manual on how to use would you be kind enough to let me no how to us it thanks naaz
Apr 01, 2009 | Ovens
Problem with electric single oven Tecnik tkc241/2
Hi, switch off the mains for the cooker, wait for about 15 seconds, switch it on (0:00 flashing) then press the 2 buttons on the left at the same time and hold them, and then press the - or + button to set the time.
Cheers
Feb 19, 2009 | Tecnik TKC215/3 Electric Single Oven
Ovens Logo
26 people viewed this question
Top Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
