Question about Dell Latitude D600 Notebook
HDD Hard Error when trying to turn on - Dell Latitude D600 Notebook
  • srbuckley Sep 13, 2009
    Problem-I don't have a system restore disk. This is my work computer and has all important documents on it. I bought it refurbished about a year a go
  • 4,281 Answers
First when you power up the computer press F1 or F2 or "del" key then you can see bios screen.
Check their that SATA option in advanced menu is disabled if you have laptop.then save settings and exit.
then check.
But if you have desktop then reconnect connnection to harddisk then check in bios that your hd is detected.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 13, 2009
  • 601 Answers
There It sound to me your hard drive has failed or windows is corupt. Sounds like a system restore might get you back on track.
Put your System Restore discs in and try a restore.
If you have important files on your laptop you will have to get back to me.
Thanks
Smith.
HDD mount failure on Toshiba 351c copier
"HDD mount" means it has an internal hard drive (HDD, or hard disk drive), and the copier has failed to "mount" (place in operation) that disk drive. That error means that the internal hard drive has failed and needs to be replaced. It will very likely need to be a special proprietary hard drive, preloaded with some sort of operating system for the copier, and you'll need to get it from a dealer.
Jul 30, 2014 | Toshiba E-studio 351c Color...
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
What does error code E602-0003 mean on an IR 2200?
A HDD (iScsi most probably) failure - Internal HD. (Hard Disk Drive = HDD).
Jun 02, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Pioneer HDD DVR DVR630H - in Australia
When fitting a replacement hdd the hdd must be paired with the DVR using the Service Remote Controller used only at Pioneer Service Centres.
Mar 17, 2017 | Pioneer DVR630H DVD Recorder
Error message Non system disk error replace and strike any key wh
Hi !
This error means either there is no disk (or disconnected/wrong connected) or your HDD is gone (which I don't believe) !
I can't find a reason why you pulled out your HDD when it was (I assume) working good before ?!?
Anyway, . . .now, please check carefully the connectors - both sides, to the HDD and to the Board(if any), if they are properly fit!
It is an IDE disk and there are two groups pins on the HDD. Check the pins if they are all going to plastic male connector (and then to the board.
A group of 4 or 6 pins on HDD should not be connected. There is one pin missing in (about) middle of the second row of pins - it is o.k.
Put your ear close on the chasis of laptop and find if there is a spinning noise when you turn your laptop on.
If there you can hear noise, then check in BIOS if your HDD exists.
If not, try to check it on another Laptop/PC.
Regards.
Apr 22, 2009 | Compaq Evo N800C Notebook
I get error code e-68
there's a possible hard drive issue on this.
try the ff:
-turn off your xbox
-remove your hdd from the xbox
-turn on the xbox while the hdd is removed
-if you're still getting the sme error code, your xbox needs to be repaired/replaced
-=hope that your xbox is still under warranty=- ^^
Jan 19, 2009 | Microsoft Xbox 360 Console
I have an lg 50pt8 plasma tv with hdd. the hard drive wont work, it just says ( hdd initialisation in progess please try again later!) any help would be great. thank you.
Check your owners manual and see if there is a way to format the hard drive. If so, format it and try it again.
If not, or if you can't get past the hdd error, check your owners manual and see what type of hard drive it takes. Go to your local computer store, buy one and install it in your TV. This SHOULD stop the error message, and allow you to format the new drive using your TV's menu structure. Again, check the owners manual for formatting instructions.
If you are an experimental type of person, you can install the tv hard drive in an external hard drive case, plug it into your computer and try to get it running.
Finally, if it turns out to be some kind of proprietary hard drive you may have to check with LG to purchase a replacement.
May 07, 2008 | Televison & Video
HDD error
I got the same HDD error on mine also. I removed the zif drive from the camcorder and checked it with an external zif hd adapter and the hard drive was good. I emailed JVC and asked them what is wrong with it they said to just mail it in for repair. I think it has to do with deleting the original hidden files and folders that were factory installed because when I checked the hard drive for folders it didn't have any in it(mistakenly deleted or moved). From what I have read from the manual you are not suppose to change folder names or delete hidden files. Hope this post helps you out a little. If you figure any thing else out post more info. Thanks.
Aug 26, 2007 | JVC Everio GZ-MG21 Camcorder
Hard disk failure
Hi, assuming the hdd won't finish a format, it is possible that some sectors are damaged. If you still want to try and use the hdd even with these defects, you can try and partition the hdd. Guesstimate at what point the hdd stops responding and really guess where the defects end. With this info, partition the hdd into 3 with the middle containing the defective sectors. Format only the first and third partitions. For simplicity, Win98 might be easier to work with rather than XP. Hope this be of some help. Do post again and let us know how things turn up.
May 05, 2007 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
Dell Latitude D600 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
