Question about Kenwood TK-3100K2 (2 Channels) 2-Way Radio
Kenwood tk-3140 two way radios
I HAVE SEVERAL OF THESE HOWEVER ONE HAS NO SOUND, IT STILL TRANSMITS THOUGH, IS THIS LIKELY TO BE THE INTERNAL SPEAKER BLOWN AND IF SO IS IT EASY TO REPAIR?
THANKS
  • MARTY_P Dec 12, 2007
    Guys thanks for your help i am going to locate an adapter and try to use an earpiece first then take it from there! hopefully is a simple problem. Thanks!
    Brigadier General:
  • 6,966 Answers
If I may add to luckydave's post, you can verify if it is the internal speaker which is at fault by connecting an ear piece or an external speaker to the jack. In some instances, it could be due to worn out volume control and/or squelch control.
Good luck and kind regards.
Posted on Dec 12, 2007
It could be one of several problems [a] Transmit switch has got moisture in it and is staying on so you can't receive [b] speaker could be blown but unlikely, more likely connection is corroded easy to fix if you have a proper electronic soldering iron.
check radio for internal moisture and corrosion, clean thoroughly and try again. [c] lastly if the solid state part for the sound has gone , chuck the radio out it's cheaper than trying to repair it unless you want to take it apart yourself or if you have another old one to use for parts
Kenwood instruction manual
http://www.ebay.ca/itm/KENWOOD-TK-210-VHF-FM-SERVICE-MANUAL-NO-STINKING-PDF-CD-FREE-SHIP-EXC-/291176745060?pt=US_Manuals_Magazines&hash=item43cb7c8864
Jul 15, 2014 | Kenwood...
Kenwood tk 208
Google it. There are several companies that make programming software and cables for Kenwood radios. However their commercial radios generally require their proprietary cables and software.
Jul 07, 2013 | Radio Communications
I bought additional kenwood tk 2100 radios and they are not sending the signal to my existingones. The fcc numbers and interior tk numbers are the same. How to I get them on the same frequency.
To change the channel frequencies on your TK2100, simply press and hold the PTT switch ("talk button") and Monitor key, then turn the power on. Now press the PTT switch again. The light should change from orange to red and a beep should sound. Next, adjust the channel switch to the channel you wish to program. Now simply press the PTT button to choose between 4 to 8 possible frequencies, depending on your model.
You can find the manual and frequency graphs here: http://www.heritageresale.com/documents/TK2100OwnersManual.pdf
Aug 26, 2011 | Kenwood...
I need a instruction manual TK-3140
Check the link below:
http://www.flash-services.com/upload/userguide-kenwood-tk2140-3140.pdf
Have a good one!
Jun 24, 2009 | Kenwood iTECH iQfive iQplus TK2140-3140...
I have a Kenwood TK-2160 and I am unable to
the 2160 has a freq range of 144 - 158 only
Jun 12, 2009 | Kenwood...
Manual for Kenwood TK-248 Two Way Radio
I wasn't able to find a manual, but was able to find programming instructions online. I hope this helps!
http://blog.savel.org/2006/11/16/kenwood-tk-248/
May 08, 2009 | Kenwood W&W Mfg -TK2140-2160-3140-3160...
Kenwood tk-280
The TK280 portable is a trunking/conventional two way. It does not support digital communication. There is no upgrade available short of a new radio. By the way...new digital radios are very pricey so be prepared to spend some $$$. Good luck.
Apr 18, 2009 | Kenwood KNB-17AM, TK-280, TK-290, TK-380,...
Install
Assuming that Kenwood KDC-135 is fully operational then your only concern would be matching the Kenwood wires to the Camry's wiring.
Most Toyota Camry uses the below wiring scheme. I have taken the liberty of including the corresponding Kenwood wires.
Hope that this be of some help. Pls post back how things turned out or should you need additional information.
Jan 02, 2008 | Kenwood...
Kenwood TK-3100K2 (2 Channels) 2-Way Radio Logo
198 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
