Question about RCA Televison & Video
I got a rca digital TV recorder and wanted to use it to record from my cobra security camera is it compatible
  • RCA Master
  • 6,004 Answers
The digital TV recorder shown is an ATSC (digital OTA) to NTSC (analog OTA) signal converter. It connects between an OTA antenna (RF, RG59/RG6 connector) and an older television or VCR/DVD recorder with a NTSC tuner. Some wired security cameras use a BNC connector to the security system receiver.
I wish that I had better news for you.
Posted on Aug 19, 2019
SOURCE:
SOURCE: RCA voice recorder problem
I let my rechargeable batteries run down before I closed a file. When I later transfered my file to the computer to the RCA Digital Manager program, I could do nothing and got the "Code Warning" message.
I left my DVR plugged into the USB cable and formatted my "removable drive G" which was my DVR. After that when I tried to turn on my DVR I got a blinking message "format." In desperation I pushed in the button for deleting a file from my DVR steadily for about five seconds. Voila! Everything came back to normal. I was able to turn my files into exe. files once again.
Posted on May 19, 2008
SOURCE: RCA RP 5012B digital recorder
It is not possible to download the sound files in their digital forms with this model of recorder. The only way to transfer the recordings is to connect a male-to-male 3.5mm (1/8") plug from the recorder to the line input of the PC (as was formerly mentioned) and record it onto the PC in real time. I've done this with mine and it works fine...it just takes longer to do than tranferring the actual digital file to the PC. A good MP3 recorder for the PC is Audio Record Wizard. http://www.nowsmart.com/arwizard/
The full version costs $25, but I think it's worth it.
Posted on Jun 23, 2008
SOURCE: how to record from a cctv camera to a digital tv recoder
You can't do this at all. It will only record from its own freeview tuners.
SOURCE: 64m RCA Digital voice recorder user manualfor free
How do I unlock a 64m RCA digital voice recorder?
Posted on Oct 29, 2008
SOURCE: RCA VR5220 recorder. VOC conversion to WAV corrupted
1. Go to http://www.rcaaudiovideo.com/downloads .
2. Download software (RCA Digital Voice Manager) for any specific model VR.
3. Choose platform (MAC, Windows, Linux)
4. Run software. Browse for file to fix. Right-click and convert to .WAV
5. Save file where you want. Its that simple.
Posted on Nov 11, 2011
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
I have a mac and to download the digital voice
not trying to be smart but you will have to use windows to run the dvm and or load windows on your mac.probably easier to buy another recorder that is mac compatible
rca doesnt offer any support for this model anymore
Apr 28, 2010 | RCA RP5012 Digital Voice Recorder
I have a security camera outside that runs to tv with rca cables. i want to record to a vcr which is connected to tv by coax. i cant get it to record the camera picture. can u help?
The coax connection is one-way RF only from the VCR to the TV. It cannot be used to record from TV to VCR.
Run the RCA cables to the Line or Aux input on the VCR first. Watch on the TV through the coax connection to the TV. You can watch even when not recording the camera signal on the VCR by setting the output of the VCR to Line instead of a channel.
Another option would be to connect a component (RCA) output from the TV (if there is one) to the VCR Line or Aux input.
Dec 16, 2009 | Office Equipment & Supplies
Recording with Converter
stil don't see sense in this. you lose a lot of quality.
Record direct to your recorder or is this TV with build-in receiver or so? You need al compatible digital devices with according stream codecs or be lucky to have RCA jacks out..........
Apr 20, 2009 | Philips Magnavox 20MT133S 20" TV
Must hookup DVD-VR375to tv,cablevision box & MSNtv2.
Here's How:
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Jan 20, 2009 | Air Tools & Compressors
Connections, security camara/vcr/tv
A VCR uses a "RF" signal, where a TV uses a broadcast signal. The standard TV will not record from a security VCR. However, if the TV has a yellow "video in" jack on the back, this will work to record the VCR. You might need to buy a BNC to RCA adaptor at radio shack. Let me know if this does not work.
[email protected]
Nov 25, 2008 | Home Security
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
Sep 27, 2008 | Televison & Video
Connect
Does your set have compatible connectors on the rear of it? Did you read the instruction manuals that came with the new equipment? Did you ask your dealer???
Jerry G.
May 25, 2008 | RCA 32F531T 32" TV
Connections
You need compatible equipment!!! Or, go to your local TV/Audio store and buy converters.
Jerry G.
May 25, 2008 | Televison & Video
Black bars in the picture
For Models: CC4352, CC4362, CC4393. Your camcorder has a wide format recording mode that lets you make recordings compatible with the 16x9 format. When 16x9 is activated, the camcorder records black bars at the top and bottom of the picture to produce the wide-screen (movie) effect. This is also known as "letterbox" recording. Do not use this mode unless you have a compatible 16x9 TV. When played on a regular TV, black bars appear on the screen. If the 16x9 feature is activated on your camcorder and you want to turn it off, press REC/PAUSE to pause recording, and repeatedly press DIGITAL EFFECTS until no digital effects display appears.
Sep 06, 2005 | RCA CC-432 Camcorder
Televison & Video Logo
42 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
