Question about The Computers & Internet
My iPad mini has been disabled after multiple attempts to open it
I took it in for screen repairs and it failed to register the old password, what do i do
    Master:
  • The Master
  • 587 Answers
SOURCE:
SOURCE: My Ipdad is disabled
You should log onto Itunes, and when you go on Itunes you connect it. After that you just have to restore your ipad and go through the setup again. The only problem is that all the things you have saved on the Ipad will be erased.
Posted on Jun 23, 2012
herritykiera
  • 4 Answers
SOURCE: ipod touch is disabled
Take to apple shop or go to iTunes on pc
Posted on Aug 12, 2012
SOURCE: Ipad disabled b/c son forgot his password...help us get in?
If your son cannot remember the passcode, you will need to restore your iPad using the computer you last synced your iPad with. Using the last computer you synced with allows you to reset your passcode and re-sync all your data, apps, etc.
To begin the process, connect the iPad to your computer using the USB cable or lightning cable. Open iTunes and select the restore option.
If you restore on another computer, you can still unlock the device and remove the passcode, but your data and apps will be wiped.
Hope that helps!
Posted on Apr 03, 2013
  • 8 Answers
SOURCE: I do not want to put a password in every time I
Open "Settings" then go to "General" and scroll down until you see "Passcode Lock". Enter your current passcode when prompted and then selected the "Turn Passcode Off" option at the top of the screen.
Posted on Sep 21, 2013
SOURCE: i forgot my icloud password and my ipad got disabled now i can't login to my ipad can you plz remove my old device plz plz
Go to http://iforgot.apple.com to reset your password.
Posted on Dec 24, 2014
I have iPad two and cannot get it to swipe open it said change passcode I did and now I can't get in it
When you enter the wrong password in to your iPad 6 times in a row, you will see a message on the screen saying "iPad is locked" and recommending you to attempt it later. In the event that you attempt too often, your iPad many show the message letting you know "iPad is disabled connect with iTunes".
Try not to stress, we can work it out. So on the off chance that you overlooked iPad screen arrow password, this post will show you how to remove passcode from iPad easily.
Unless you made a backup before you overlooked your password, there isn't an approach to spare your iPhone information. You'll have to restore your gadget, which erases the greater part of your information and settings. The following guide provides you three methods to remove password from iPhone:
1. On the off chance you've adjusted with iTunes, use iTunes.
2. In case you're marked into iCloud and Find My iPhone is empowered, utilize iCloud.
3. In the event that you don't utilize iCloud and you can't match up or interface with iTunes, utilize recovery mode.
http://www.leawo.org/tutorial/how-to-remove-passcode-from-iphone.html
Mar 21, 2017 | Apple iPad Tablets & eReaders
How do I do my backup on my ipad mini 8.1? Do I restore the
try signing onto iTunes from a computer and then plugging ur iPad into the computer
Mar 19, 2015 | iPad mini Tablets & eReaders
I can not connect to face book from my home screen on my iPad. Yet I can connect through safari. I'm thinking it is something in my settings
Just a thought as I just experienced this myself: I wasn't aware that the applications on my ipad run in the background. So when I tried repeatedly to connect - each attempt was opening a new log in to Facebook. Once I learned that I had a number of background apps running - multiple times, specifically about nine Facebook entrances - I closed them all and was able to log in immediately. I'm not sure how something very simple (turning all these apps OFF - slipped by me.) If you wish to check: double click on your top / screen side, power button. Running apps will either have a red 'X' - older ipads, or have a 'mini screen' (each for all open apps) that you can 'swipe' off. On mine it's "up". This may not be what is causing you trouble but it was an instant 'fix' for me. Hope it helps - let us know? Thanks & good luck.
Nov 12, 2014 | Apple iPad (16 GB) WiFi Tablet PC
I forgot my password and now my mini ipad is disable
it's now in DFU mode and must be plugged up to the computer and connected to iTunes.
Jul 18, 2014 | iHome Ipad/ipod/iphone Rechargeable Mini...
I forgot my password, and disabled my ipad mini , and need to get back into it
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
For more methods, check: How to Reset Password on iPhone
Dec 02, 2013 | Apple iPad Mini
Disabled ipad 3
What wrong with your iPad 3? Maybe you can reply on the tablet replacement repair parts for iPad 3 to make your iPad return back new and health. Nowdays, there are more repair parts for fixing the unflexible and scracked.
Oct 04, 2013 | Apple iPad 64 GB WiFi
My mini ipad says disabled how can i enable it again?
Did you mean that the iPad is disabled for many attempts of passcode? Usually, waiting for a particular time span can enable agin the iPad. But if does not enable back again even after a few hours, then consider restoring your iPad in iTunes.
Apr 04, 2013 | Apple iPad Mini
I have forgotten my password for my kindle fire
After four failed attempts at entering your password, you'll be directed to restore your device to factory default settings. This will delete all content on your Kindle Fire and you'll need to register it again before downloading items from your Amazon account. You can then create a new password for your Kindle Fire. Hope this helps.
Feb 13, 2013 | Kensington Amazon Kindle Fire / 2nd...
Computers & Internet Logo
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
Inky Fingers
Inky Fingers
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
