ViewSonic VX715  17" LCD Monitor
Problem for ViewSonic VX715 (Black, Silver) 17" LCD Monitor
Viewsonic vx 715 the monitor turns off after
By simon_hales on Sep 13, 2009
viewsonic vx 715 the monitor turns off after 10secs through both vga and other cables on different pcs - the screen goes blank - when you turn the monitor off and on again the same thing happens - any suggestions on how to resolve - simon
Comments:
Sep 13, 2009
- the comments i have seen on this is that the issue is likely to be around inverter transformers also the 2 1000uf 16V bulged caps near the inverter side of the board may need replacing or too check the soldering the bad soldering apparently is an issue with vx 715s
Solution #1
posted on Sep 13, 2009
Somewhat Helpful)
keithkalish
Rank: Wiz
Rating: 81%, 64 votes
Your monitor is probably shuttin off once something is heating up enough to cause the safety relay in its power supply board to shut it off. I find that once a monitor goes, just toss it, it isn't cost effective to try and have it repaired the
cost will exceed the cost of a new monitor
Comments:
Sep 13, 2009
- Bulging caps are a common problem with a lot of Chinese electronics, they make crappy electrolytic capacitors. I fI had the monitor, I'd be able to repair irt myself. If you don't have that expertise, it will cost you more than its worth, not to say that the bad caps may have taken other components with it.
Was this helpful?
Yes
No
Popular Solutions for ViewSonic VX715 17" LCD
Questions and Unsolved Problems for ViewSonic VX715 17" LCD
Do you recommend ViewSonic VX715 (Black, Silver) 17" LCD Monitor?
Answer
Answer
My viewsonic 715L1075-2-V board has gone i think i had to put a hair drier onto the backlight... (More)
Answer
ViewSonic VE710B; power comes on, but the picture is dim. Can someone help with the solution?
Answer
ViewSonic V710B; power comes on, but the picture is dim. Can someone help with the solution?
Answer
Hi I have the same problem. Any idea what is the model number for the replacement tube? Any... (More)
Answer
yeah , it does , and i can see it adjusting slowly or quickly straight to max ~_~ , and while it is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For ViewSonic VX715 17" LCD...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
