Question about JVC Car Audio & Video
How to fix jvc kds640 with no black (ground) in the wiring harness
    New Friend:
  • 137 Answers
YOU COULD TRY PLUG THE RADIO IN AND ABOUT THE YELLOW WIRE YOU PUSH A GROND WIRE INTO THE PIN HOLE AND RADIO SHOULD WORK WHEN SECURE PROPERLY
Posted on Sep 12, 2019
SOURCE:
ampman
  • 98 Answers
SOURCE: Wiring Harness for JVC KS-R127
I can uually find those on ebay for a few bucks. You will need to count the number of pins then go shipping.... Also look for a seller called cali car stereo if they dont have it listed they probhably have it at thier store..
Posted on Sep 08, 2007
  • 4102 Answers
SOURCE: re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Posted on Apr 21, 2008
SOURCE: need to hook up a 200 pioneer stereo with wire harness from 96 honda accord to the wiring on a 64 impala
there is only one power wire i cant remember the color use a test light to figure it out...then you need to make a wire off the fuse box that turns on when the ignition is on
Posted on Jul 29, 2008
  • 306 Answers
SOURCE: trying to install clarion drb2475 into my car I
the brown is a mute wire. i dont recomend hooking this wire up
Posted on Feb 08, 2010
  • 1026 Answers
SOURCE: Replacing the driver side headlight wiring harness
one will be ground one will be high beam and the other dipped beam
Posted on Apr 05, 2010
IS THERE A WIRE ON THE STEREO HARNESS THAT HAS TO BE GROUND. OR THE ACTUAL HANDBRAKE SWITCH TO BE GROUND. IS THIS DONE BY PUTTING THE POS WIRE TO EARTH
No, you don't want to ground your positive wires, EVER! Also, I would avoid using the hand brake switch for anything but what it was intended for. Most power harness ground wires are just plain black. If you can't find one, ground it to the chassis of the car somewhere. This is less than optimal, as it may induce a ground loop and cause a buzzing that matches the engine's RPM.
Aug 23, 2013 | JVC Kd-avx33 Exad In Dash Dvd Player
My jvc stereo will not power up but have found the black wire is live ?
hi peter, before you start using the rest of the harness cables find out if the harness you have is a jvc original for your model. the black wire is the ground/chassis cable only for a jvc kd-r411. you mite be using a compatible fitting harness whose " wire colour configuration" is incorrect for your model. cheers.
Mar 02, 2013 | JVC AM FM CD DET FACE CAR STEREO
I am replacinng the factory stereo with a JVC unit. The harness for the original has two orange wires, one plain the other with a black stripe, and the JVC one doesn't. What are these for and are they...
the orange wire in the #8 cavity is your key on power wire, so yes you need it the yellow wire in the #1 cavity is the 12 volt alwise wire so you need it as well the orange wire in the #10 cavity is the right rear speaker wire + you also need it hear is the wire list.
wire #1. yellow 12 power with key on
wire #2. gray interior lights
wire #3. green right rear speaker -
wire #4. red right front speaker +
wire #5 black left front speaker -
wire #6 brown left rear speaker -
wire #7 gray power antenna
wire #8 orange 12 volt power hot all times
wire #9 pink interior lights
wire #10 orange right front speaker +
wire#11 blue right front speaker + ( door )
wire #12 empty
wire #13 empty
wire #14 yellow left front speaker + (door)
wire #15 white left rear speaker +
wire #16 black/orange ground
Apr 17, 2011 | 2004 Kia Optima
How do you install a JVC KD-R300 radio into a 2003 Mitsubishi Galant? I got some kit when i bought the radio to make it where the radio would be able to hook up to the car but it says to plug this black...
if your got a wiring harness you should be able to hook your ground up with a pre existing wire from the new harness it should be black if not and your looking for a place to ground it just below your steering colum is always a good place to ground anything right on the metal itself good luck
Mar 04, 2010 | JVC KDR-300
When radio is put on it plays for about 30 seconds then goes off.
its your ground wire its a simple fix make sure u plug in the stock stereo attennna line its a secondary ground and 2 dont use the normal ground from wiring harness run u a brand new ground i had same problem in my s-10 my grnd shorted out in my harness without me knowin it i ran a voltmeter through it found the problem and replaced the ground if u still having no luck hit me up and we can get it fixed 4 u im sure
Feb 02, 2010 | JVC Car Audio & Video
I need a wiring diagram for a JVC KD-R805 installation
For putting it into what kind of car? Or did you mean the radio harness itself? Red is constant 12v, yellow is Accessory 12v, Black is the ground. Solid blue is power antenna, blue with a stripe is a 12v accessory meant to power the amp (AKA AMP REM), White is front left speaker, gray is front right. Purple is rear left, green is rear right and any of the white,gray, green or purple wires with a black stripe is the negative for that speaker. If you post a reply with a vehicle model and year I can give you the factory wire harness colors as well.
Jan 13, 2010 | JVC KD-R800 Car CD/ MP3 Player
My JVC KD-AVX44 keeps flashing up the ''parking brake'' even though the green wire has been attatched to the handbrake.
hi ok first of all unless you want your vid not to show while the parking break is off i can fix this for you :) simply take your parking break wire and connect it to your ground from the wireing harness tada end of story my friend now you have vid and full fuctionality of your deck 100% of the time feel free to email me if you have anymore questions (i own black widow car audio also own a jvc avx 820 works with all jvc models)
Sep 23, 2009 | JVC Car Audio & Video
1986 NISSAN 300Z THE STEREO WIRE WERE CUT NEED COLOR CODE PLEASE TRYING TO INSTALLED A FTER MARKET STEREO JVC
i have attached the wiring info you requested. be sure to test all wires with a meter before connecting. also a link to metra's website if you need an installation kit
http://www.metraonline.com/fitl.aspx
Battery RED/BLACK (+) RADIO HARNESS Accesory BLUE (+) RADIO HARNESS Ground N/A THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS. Illumination RED/YELLOW (+) RADIO HARNESS Dimmer N/A Power Antenna GREEN/BLACK (+) RADIO HARNESS LF Speaker (+) BLUE/WHITE LF Speaker (-) BLUE/YELLOW RF Speaker (+) BROWN RF Speaker (-) BROWN/WHITE LR Speaker (+) RED LR Speaker (-) GREEN RR Speaker (+) BLUE RR Speaker (-) PINK
Sep 02, 2009 | JVC AM FM CD DET FACE CAR STEREO
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
Color code radio wires 1990 ford truck F350 4 w/d
Battery GREEN/YELLOW (+) RADIO HARNESS
Accesory YELLOW/BLACK (+) RADIO HARNESS
Ground RED OR BLACK (-) RADIO HARNESS
Illumination BLUE/RED (+) RADIO HARNESS
LF Speaker (+) ORANGE/GREEN
LF Speaker (-) BLACK/WHITE
RF Speaker (+) WHITE/GREEN
RF Speaker (-) BLACK/WHITE
LR Speaker (+) PINK/GREEN
LR Speaker (-) PINK/BLUE
RR Speaker (+) PINK/BLUE
RR Speaker (-) GREEN/ORANGE
radio Security YES
Feb 20, 2009 | JVC Car Audio & Video
Car Audio & Video Logo
22 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Dalynn Turner
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
