Question about Cameras
I have a nhdc_w55 Toyota radio I removed the battery and I lost the Sterling volume control and the reverse camera how do I reset to get them working the radio displays japanese
    Top Expert:
  • Cameras Master
  • 1,796 Answers
Posted on Aug 19, 2019
    Habit-Forming:
    New Friend:
  • 15 Answers
Hi, hold down the two buttons next to the shutter button on the top of the camera, you'll hear a short beep followed by a longer beep which signifies that it has reset. Release the two buttons. Hope this helps
Dave
SOURCE:
  • 10 Answers
SOURCE: Where to find the Audio Control (37411) manual 2002 Toyota Corolla
ebay
Posted on May 26, 2008
emissionwiz
  • 85161 Answers
SOURCE: 2006 toyota camry JBL radio; controls don't work
THIS IS A RADIO PROBLEM, THIS PROBLEM WILL REQUIRE THE RADIO BEING SENT OUT TO AN AUTHORIZED FACTORY ELECTRONICS REPAIR CENTER, THERE IS NO BLOWN FUSE OR THE RADIO WOULD NOT EVEN TURN ON.
Posted on Dec 05, 2008
  • 4 Answers
SOURCE: lost code for 1996 toyota prado radio
for our Toyota Prado 2001 01, after the battery had been removed SEC was showing on the cd / tape / radio display. To remove the security SEC warning, find the last 3 digits of your VIN number (under the hood) hold down the "TUNE" button and then press "1"
Then use the numbers 1 2 and 3 to type in the last 3 digits of your VIN number.
Quickly hold down "SCAN" button, the radio will power off, then press the volume button to turn it back on.
-I accidentally held down "auto" before holding down scan, I don't think auto has any part of fixing this (just an error on my part) but if the above doesn't work, you could try hold AUTO down after entering the digits then hold scan - just as I did.
SEC has now been removed, enjoy your radio!
Posted on Mar 09, 2010
Testimonial: "Thanks heaps finally got it going, great advice. "
SOURCE: 2006 Toyota Prius Radio Buttons inoperable
Same problem happend to my 2007 Prius, any solution? I would be grateful if you could get it sorted. My email: [email protected]. Thanks
Posted on Sep 02, 2010
  • 5013 Answers
SOURCE: How do you remove the
Free instructions are listed here
(at the bottom )
http://www.fitaudio.com/index.php?CategoryID=12
Posted on Feb 15, 2011
I have a Toyota auris 2007 and after flat battery, i have lost some of the reverse camera. How to I reset it. Can someone help
try using a scan tool to reset the cpu program in the ECM
sometimes the removal of a battery corrupts the cpu program
Jan 02, 2017 | Toyota Cars & Trucks
Reset radio code battery replaced radio &volume control dont work
the operator guides, in glove box , answer this.
answer: you forgot to write it down. (or lost the card) so trip to dealer
or any keyshop with NASTIF , license.
Nov 25, 2013 | Hyundai Tiburon Cars & Trucks
WHERE IS THE RESET BUTTON IN THIS CAMERA
The Camera does not have reset button. You can reset the Camera by either using the Initialize option from the Menu or removing the battery.
You can find the Initialize option under the Setup Menu of the Camera.
To Power reset the Camera, remove the battery it, press and hold the power button for more than 15 seconds and then reinsert the battery.
Thanks for understanding.
Dec 18, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Had to install a new battery in 06 Lincoln Mark LT, Now my radion volume and station select stopped working on my steering wheel. Do I need to reset something?
You need your owners manual, to reset what ever you lost
on the radio
I don't believe the wheel controls were lost
Check the radio to see if you have things set the way you want
There won't be anything you do for the wheel buttons
just the radio
Dec 16, 2010 | 2006 Lincoln Mark LT
Cyber-shot DSC-W55 Digital Camera: sonyW55 lens only comes out half way ,can not take...
1.Please reset the Camera to its factory defaults and check if it helps.
2.To reset the Camera, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.
If you're not able to access the menu option in the Camers, try this:
Power Reset the Camera and check if it helps
To Power Reset the Camera, please remove the Battery Pack from the Camera and then press the POWER button for 30 seconds.Then, reinsert the Battery Pack after 1 minute and check if that helps.
Please Power Reset the Camera and I am certain that it should resolve the issue. If the issue still persists after Power Resetting the Camera, then it requires service.
http://eservice.sony.com
May 18, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Lost code for 1996 toyota prado radio l had the battery replaced now the radio displays a sec sign
Feb 08, 2010 | Car Audio & Video
Volume control
Remove the back battery cover only. Turn unit on. Insert a tiny paperclip thru the tiny 'reset' hole on the back of the unit inside the battery compartment. OK?
Aug 05, 2009 | Pioneer XM2go Inno Satellite Radio...
Sony DSC-W55 Access Message - lenses going in & out automatically
Please remove the Battery from the Camera then reinsert it after two minutes. Make sure that the Battery is fully charged. if menu options are accessible on the Camera then reset it to the original factory settings. Please follow the steps that are mentioned below to reset the Camera to the original factory settings:
(i) Please turn ON the Camera.
(ii) Then use the control button on the Camera to the select the Setup (setting) option.
(iii) Next, select the Setup1 option then "initialize".
Performing the above mentioned steps will reset the Camera to the original factory settings. If the issue persists then service will be required.
Jul 13, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Start problem SOny dcs-w55
Please try Power Resetting the Camera.
First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
If the issue still persists after performing the step provided above service of the Camera is recommended.
There might be an internal malfunction occurred in the Camera which can be determined only after physically examining the Camera at the Factory Service Center
Jun 13, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Cameras Logo
23 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
