Question about Cannon Office Equipment & Supplies
What is the problem if cannon image Runner is saying restart the machine and if the problem persists call for repair service **000003-0000
    Master:
  • Cannon Master
  • 867 Answers
That is a temperature protection error . Please specify the model of your copier so we can help you out
Posted on Aug 21, 2019
SOURCE:
SOURCE: Cannon Image Runner 3200
turn of the copier and hold down the 1 and 9 and turn the power back on. you shoule see a black screen with a little block in the upper corner. the blocks will fall to the bottom. when this is done cycle the power.it may take 30-60 minutes.
this is like a scandisk on a computer and will try to repair itself. If this does not work a service tech can try to format and reload sys software.
rep
Posted on Dec 28, 2007
  • 153 Answers
SOURCE: waste toner
to change the waste toner on your IR 5055, stand directly in front of machine and look on the right hand side of it where the power switch is a black button on right hand sdie at the back and you will see 4 screws and a metal plate that will come off the waste toner bottle is in there just empty it out and refit to machine all will work, now on your IRC3170 just undo front door and you will see a clear bottle just undo the black screw and take out the bottle and you will see a couple of little clear windows in the bottle make sure you take them out and clean them before you emtpy the bottle, this is where the machines shines a light through it to tell if the bottle is full or not so make sure you have them clean. refit the bottle and all will be ok
Posted on Jun 01, 2009
techbuster
  • 5081 Answers
SOURCE: E000
A E000 code means the error history has detected any one of the following error codes 4 times :E001;E002;E003. Here's the definitive reset procedure Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
please rate my answer after trying if satisfied
Posted on Jul 06, 2009
SOURCE: Cannon image runner 2200 error code E000002-0000,
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Posted on Sep 26, 2009
canontech
  • 1219 Answers
SOURCE: cannon image runner 2200 Error code E000019-0000
Empty the waste toner container. From left side of copier you have small cover with one screw.Remove the cover and empty the container and clean it very well, you may use alcohol for the neck of the bottle to ged rid of of antistatics.
Posted on May 04, 2010
_code_error_e000007_0000
Dear
The machine gets abnormal rotation of the fixing film.
The probable fault with the part is mentioned bellow.
1-tearing off the film/ dust on the white spot on the film (most cases)- REPLACE/CLEAN the film.
2- Dusty on sensor. clean it or replace it.
3-harness of the sensor-check continuity.
4-DC-CON pcb (rare).-Replace it.
Thanks.
Mar 06, 2015 | Canon Cannon Copy Machine Image Runner...
How to resolve problem for canon imagerunner 2420L pritner error show "restart if problem persist "
There should be an error code on the screen too, what is it? it should start with E
Sep 06, 2014 | Cannon Office Equipment & Supplies
Canon image runner 2420l error message **E000001-0001
Canon Digital Copier IR2420L.
in this we are receiving the error Restart the machine if problem persists, call service rep **E000001-0001
Feb 04, 2013 | Office Equipment & Supplies
In my canon xerox imagerunner 2420L displays error massege
i have canon image runner 2420l copier and it show the error message restart the machine if problem persists, call service rep. **E000007-0000 how can i solve the problem/ and fix the machine
Nov 04, 2012 | Office Equipment & Supplies
I have cannon image runner 4570 that I cleaned
The transfer roller is cleaning use to a vacuum cleaner.The black lines is caused to dirty charge corona or charge roller.Clean the charge unit.
Aug 19, 2009 | Canon Office Equipment & Supplies
Can't fine servers during LDAP search
hi
try to change the setting of lancard speed to half duplex of photo copy machine
Dec 11, 2008 | Canon imageRUNNER 210S Copier
16 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Ekse
Clive
Clive
Inky Fingers
Inky Fingers
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
