Question about Canon Office Equipment & Supplies
How can i disable u0159 error in canon pixma mx300 Printer? infact i want to use scanner of this printer but the error dose not let.
    Master:
  • 456 Answers
Contact Canon at 1-800 OK CANON (652-2666)
Posted on Aug 19, 2019
SOURCE:
SOURCE: error code MP170
i have widows vista and i purchase canon pixma mp180/mp160 but it not woking with this window
Posted on Jan 03, 2008
  • 62 Answers
SOURCE: I can't get my computer usb to recognize my Canon
This problem may require you to uninstall the drivers once again. Restart the computer with the printer disconnected. After boot up is complete, plug in the usb printer cable and turn on the printer. Make sure cartridges and paper are loaded properly.
Have the CD that came with the printer in the drive, but don't let it run the Auto install feature. We will use it later should XP not be able to load its own driver for the Canon printer.
Should XP detect the printer, it will attempt to load its own default driver. Watch for the bubble messages at the bottom right of the screen. At some point it may not get the proper driver installed. You then have the option to select "Have driver from disk..." Point Windows XP to the driver disk that came with the printer. Opening the disk contents should show a folder somewhere with XP as a label. Browse to it and have XP install the driver software located in it.
You should now have a functioning printer.
Good luck and let me know if this works for you.
OpenSource13
Posted on Apr 19, 2009
  • 155 Answers
SOURCE: Canon - Pixma MP150 printer/scanner won't scan in color.
hi,
u've to install all third party drivers related ur printer that u've got on time of purches.
Posted on Sep 18, 2009
SOURCE: Canon Pixma mx300. "U163 col," won't scan.
press reset botton for 5 sec
Posted on Jan 10, 2010
pineworks
  • 4345 Answers
SOURCE: Canon Pixma MX300 - error code 5B00 - check
Try it works for most Canon
Hi you can try
Solution:
  1. Turn on the machine
  2. Press MENU
  3. Press SCAN COPY SCAN to enter service mode
  4. USE > to got to NVRAM ACCESS
  5. Set ABS-M LEVEL to 0
  6. Set ABS-P LEVEL to 0
  7. Press STOP to EXIT
All The Best: Pineworks
Posted on Jan 25, 2010
Error U051 de canon mx300
I think you need to reinstall printer driver again, Be sure unistall by REVO then reistall the drivers again.
Download the printer drivers from this link Pixma MX300 Driver download
http://printer-driver-download.us/canon-pixma-mx-300-driver-download/
Oct 20, 2012 | Canon PIXMA MX300 All-in-One Printer
U051 error can i disable printer and use only scanner and fax canon mx300
Sadly not. The cartridge error will have to be resolved before you can use the scanner/fax. You do not however have to have a full cartridge installed, the printer just needs to be able to recognise the cartridge.
Sep 11, 2012 | Canon MX300 Office All-In-One Printer
How do you get the Canon MX300 printer to scan? I do not know what all you need for a printer to scan but when I press the scan button it just beeps and nothing happens.
Hİ,
First You must install "MP Navigator EX" program to your Pc..and then you can control every feature of the scanner from your computer..(not from scanner...)
This program normally comes with the MX300 as CD ,if not you can download from Canon support page....Good luck..Regards
Mar 31, 2010 | Canon PIXMA MX300 All-in-One Printer
Need to find printer part
From http://www.canon-europe.com/Support/Consumer_Products/services_locator/index.aspx
Electroversal
Photo Printers, Inkjet Fax, Scanner, InkJet Printer, Laser Printer, InkJet MFP
Electroversal provides a return to base service for A4 Bubble Jet Printers, PIXMA iP90/iP90V, Selphy, CP, DS & PIXMA Mini Printers, the Fax B820 & B840, JX200/500, PIXMA MP110, MP130, MP140, MP150, MP160, MP170, MP180, MP210, MP220, MP450, MP460, MP470, MP510, MP520, MX300 & MX310, the LBP2900, LBP3000 and Scanners (except the dedicated 35mm Slide Film Scanners 2700F, FS2710& the FS4000US – Canon UK RCC).
Unit 2
Sedgwick Road
Luton
LU4 9DT
Tel: 01582 582023
Fax: 01582 582 087
Web: www.electroversal.com
To obtain a repair quote for products serviced by Electroversal, please call Electroversal Customer Service department on 01582 582023 or email [email protected]
CRC (Tasktron Ltd)
Photo Printers, Inkjet Fax, Calculator, Scanner, InkJet Printer, Laser Printer, InkJet MFP
CRC Tasktron Ltd provides a return to base service for Calculators, A4 Bubble Jet Printers, PIXMA iP90/iP90V, Selphy, CP, DS & PIXMA Mini Printers, the Fax B820 & B840, JX200/500, PIXMA MP110, MP130, MP140, MP150, MP160, MP170, MP180, MP210, MP220, MP450, MP460, MP470, MP510, MP520, MX300 & MX310 the LBP2900, LBP3000 and Scanners (except the dedicated 35mm Slide Film Scanners 2700F, FS2710& the FS4000US – Canon UK RCC)..
Unit 3 Wintonlea
Monument Way West
Woking
Surrey
GU21 5EN
Tel: 01483 776 060
Fax: 01483 721 389
Web: http://www.crc-tasktron.co.uk
Cura Technical
Personal Copiers, Laser Fax, Inkjet Fax, InkJet Printer, Laser Printer, InkJet MFP, Laser MFP
CURA Technical provides on-site service for A3 and PIXMA iP90/iP90V, laser Beam Printers, PC/FC Copiers, Multifunctional Printers and Fax machines. On-site service can be arranged by dialing 0844 369 0100.
Please note that Cura Technical do not service the following products: Selphy, CP, DS & PIXMA Mini Printers, Fax B820, B840, JX200/500, PIXMA MP110, MP130, MP140, MP150, MP160, MP170, MP180, MP210, MP220, MP450, MP460, MP470, MP510, MP520, MX300 & MX310 and the LBP2900 & LBP3000. These units are repaired at our Return to Base Agents, Electroversal or CRC Tasktron Ltd.
Cura Technical
Uniter House
3 Radford Way
Billericay
Essex
CM12 0DX
Tel: 0870 400 2080
Web: http://www.curatechnical.co.uk
Dec 17, 2008 | Canon PIXMA MP610 InkJet Printer
Canon mx300 printer dont know how to enlarge/decrease photostat
Had several other problems with my new canon mx-300 printer. trouble with word perfect and scanner Phoned Canon tech who brushed me off saying trouble was with my driver and not compatible with my computer. Returning it to the store tomorrow and going to pick up a HP
printer somewhere else..
Nov 24, 2008 | Canon PIXMA MX300 All-in-One Printer
Can not use my scanner on my mx300
It assume to be Canon Pixma MX300 Office All in one printer.
It may be due to incomplete installation of the All In One printer. Please check for the Device manager and also reinstall the printer with its installation CD.
Regards
ELLIN
Sep 17, 2008 | Office Equipment & Supplies
14 people viewed this question
Clive
Clive
old marine
old marine
Ekse
