Question about Cameras
Taking battery out - Cameras
  • Cameras Master
  • 6,019 Answers
Are you taking it anywhere nice ? On a first date, many batteries like to go somewhere quiet for a romantic meal. Wherever you go, I hope you have a good time, and, who knows ? There may even be a spark between you.
Posted on Aug 19, 2019
SOURCE:
Dead Battery?
Take out the batteries. Also take out the backup battery. It is a button battery beneath the screw in the battery compartment. Check the button battery volts with a multi-meter. After 5 minutes put the button battery back in and then the fresh batteries. It might work now. Alternatively take out a battery, then hold the clear button and put the battery back in. Then try to turn on. If it still does not work take out a battery press the del button and put the battery back in.
Feb 06, 2014 | Texas Instruments TI-83 Plus Calculator
Tip
How to take Care of Your Laptop Battery
BATTERY 101 PART 1
What really makes the Laptop or Notebook really portable is its Battery. Remove the Battery then you are indirectly removing the Laptops portability. As human beings we need energy to survive which is form of the food we eat. Similarly a Laptop needs energy to survive. The energy a Laptop needs to survive comes from the Battery which is made up of chemical juice (Lithium Ions). This chemical juice operates optimally at particular conditions. Hence we need to take care of it. Now if you take away the battery of a Laptop, you are taking away the life of the Laptop. We can then understand that it is the battery of the Laptop that keeps it alive.
Since Battery = Life of Laptop it simply means that No battery = Death of Laptop. Because batteries are so important in the existence of a Laptop we definitely have to take care of our Laptop battery.
HOW TO TAKE CARE OF YOUR LAPTOP BATTERY
I observed that many Laptop owners do not really care for their Laptop batteries. You might wonder why? It is simply Lack of information. So i am going to be giving you several tips on how to take care of your Laptop battery. I am going to cover two tips in this Part of the article and continue in subsequent parts. So watch out for Part 2.
TIPS
1) NEVER ALLOW BATTERY TO DRAIN COMPLETELY
Lithium ion battery is the technology used in modern Laptops. Squeezing every drop of its juice (chemical) weakens and strains the battery. Hence cumulative drain of the battery will shorten the life of the battery and eventually kill the battery.
2) NEVER ALOW THE TEMPERATURE OF THE BATTERY TO BE TOO HIGH OR TOO LOW
High temperature breaks down the battery and reduces its overall life expectancy. Always make sure the vents are unblocked and also never work with a Laptop on the cushion because if you do so you will be blocking the vents in the Laptop. If you are wondering how to check the temperature of your battery you could get a software to do that.
on Sep 11, 2010 | Computers & Internet
Changing battery
Take then old battery out with the proper size wrenches making sure not to touch metal when taking positive off. Put new battery in. If your vehicle has a battery holder you will have to take this off with socket or wrench....usually long bolt
Feb 10, 2012 | Cars & Trucks
It says use genuine battery when i try to turn it on and it says power off and counts down from ten and nothing helps it i tried charging it taking the battery out nothing helps
amandapan13 I want you to take the battery out of the phone. Also feel the battery to see if is swollen in the center of the phone. If the battery is swollen you need a new battery. Take the battery out and clean all the contacts. Then put the battery back in the phone to see if you still have that problem. It could be the phone itsel that is not working. Plug the phone in without the battery. See if you still get that message. Hope this help. One replace the battery if it is swollen. If the battery is not swollen take the phone to the nearest carrier and have them look at it for you.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Dec 29, 2010 | LG Cell Phones
My 97 lincoln town car won't start. it's cold out. would taking the battery inside be a good idea to warm it up?
Your battery is usually challenged in cold weather, you are right...to much trouble to remove to take in to warm up...Do you have a battery charger? My suggestion would be to jump start your Lincoln with another car battery...this will assure that your battery is not further damaged by being under charged in cold weather...drive to assure charging system ie alternator is working...taking the battery inside to warm will help to save your battery if it is just low on charge...taking inside will not ncecessarily re-charge your battery...in the summer, sometimes leaving hood up with sun on battery will slightly re-charge a low battery...:)
Dec 13, 2010 | 1997 Lincoln Town Car
Is there a certain process to changing the battery
Take the key out , make sure you have the security key for the radio, clean the battery plots with water and a brush, take out the fixing bar, take out the [-] cable from the battery plot and clean it again, take out the [+] cable and clean it again, take out the battery.
The install of the new battery is the reverse procedure.
Sep 18, 2010 | 1996 Nissan Maxima
How do you cahrge the battery on a kawasaki zx14 ninja?
What you would do is take the seat off, usually you have a key lock under the seat. Then what you wanna do is take off the positive battery cable off the battery and hook up a battery charger. If you don't have a battery charger take the battery completely out and take it to autozone or what ever auto dealer you have near by, and they will charge the battery for no charge. Finally you take your battery and put the terminals back on make sure you have the cables on right, also what ever you do don't charge the battery while its hooked up to the bike. If this was useful information plz rate me. Thank you.
Aug 20, 2010 | 2006 kawasaki ZX-14
MY DELL INSPIRON 6000 DOES NOT SEEMS TO WORK WITH OUT THE BATTERY CHARGER PLUG IN AT ALL TIMES, MEANING IF YOU TAKE THE BATTERY CHARGER OUT THE COMPUTER DIES.
Either battery is not taking charge or battery charger is not charging the battery. You can take to a local PC repair center and have the battery tested. If it is battery, you can find OEM replacements online from companies that do nothing but batteries and typically beat manufacturer part prices.
Oct 19, 2009 | Dell Inspiron 6000 Notebook
How long does it take to charge batteries?
depending on the type of battery and charger the time usually takes from 6 to 12 hrs. for a full charge. Shorter charging time will result in battery not operating to its full potential
Aug 12, 2009 | Universal Battery Charger Charges Multiple...
Can't turn off ALERT - battery low
taking the battery out should do it. Or maybe just turning it off. To take out the battery, just take the back cover off and pull the battery off.
Nov 19, 2007 | Samsung Blackjack SGH-I607 Smartphone
Cameras Logo
24 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
