Question about Dell Office Equipment & Supplies
New xerox workcentre 6027 keeps giving error 024-963 while printing on my dell D620 laptop
  • Dell Master
  • 5,278 Answers
Top cause on all printers is filth, paper dust and chunks
we clean all paths with due diligence.
or read here. (btw first google hit, eva google?
https://printcopy.info/?mod=erc&brand=Xerox&model=WorkCentre%203045&code=024-963
Posted on Sep 14, 2019
SOURCE:
checkitright
  • 1362 Answers
SOURCE: Xerox Workcentre Pro 123 error code 016-719
this is not a mechanical error but a software error.
It either doesn't recognise the format or program
as for the driver don't thinkit's the problem the HP can use PCL6
Posted on Sep 08, 2008
  • 2072 Answers
SOURCE: workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
Posted on Oct 23, 2008
  • 2072 Answers
SOURCE: my xerox workcentre pe 220 machine have an error message on "low heat error"
You will have to replace the fuser.
Posted on Apr 19, 2009
  • 323 Answers
SOURCE: Printer installed fine, won't print. Error code 0x0000007e?????
First make certain a USB cable is attached to your printer and to your USB. The windows install device will tell you it has located new equipment and ask if you want Windows to install it. If you didn't go through this before, allow Windows to install it. Use the disk that came with the printer if you have it. (Make sure the drivers on the disk will run on Vista. The disk should tell you. Lexmark 7100 series was introduced a ways back).
If you've gone through this, and you know it is installed correctly, with the proper drivers, go to "Control Panel". Choose Device manager, and click open "Ports (Com &LPT).
Choose Communications Port (Com 1). Opening that will give you the Properties page. Click Resources at the top of the page. About halfway down the page will be a small box that says "Use Automatic Settings". Make sure this is clicked. It gives Window permission to find and use the best generic drivers for your printer, among other things.
At the bottom should be another box entitled Conclicting Device List.
It should say in the box "No Conflicts." Click OK to exit that box if all is well. Next, go back to Control Panel again. Look for and choose "Printers". Among other selections, you should see an icon of a printer that says Lexmark 7100 series. That should have a big green checkmark by it in a circle. If it doesn't, click on the icon and a small box will open in the upper left hand corner.
It should say "Lexmark 7100 Series". If it does, click on Printer, then click add as default printer. Then when you close the box you shouls see the icon marked Lexmark 7100 series, with the green checkmark inside a circle.
If you don't see all these things wirite back and we will take the next step.
Sirwriter
Posted on May 17, 2009
  • 2072 Answers
SOURCE: I can't seem to print envelopes on the xerox workcentre 7345. I fed the envelope into the bypass tray, configured the settings on the workcentre as well as the word doc, but it gives me an error 012-2
There is a lengthy set up process to that. I would recommend going ot Xerox.com, then at the home page, click on Support and drivers. When you get to that page, type in 7345, then click on the support home page, once there type in envelopes and the step by step instructions are there.
You are correct, setting up envelope printing on that machine can cause you to beat your head against a wall. The machine settings and the driver settings MUST be set exact. And it may take 3 or 4 tries, even for a service rep to get it all correct. Trust me on that LOL.
But once set up, it does a nice job. It is just very picky. Personally, I think it is way over designed just to print an envelope.
Posted on May 20, 2009
Hello! I have this message on my printer: "eror relating to PDL emulation problems occur. 016-720". What this mean?
Dell and Xerox printers reportedly have this error. What model printer is it?
Example of Xerox:
https://forum.support.xerox.com/t5/Printing/WorkCentre-7435-Error-codes-116-324-amp-016-720/td-p/8240
Jun 28, 2018 | Office Equipment & Supplies
Error C0...Xerox WorkCentre 5020DN Printer
C-0 declares that the size of the document you are trying to print is incorrect with the paper size you have in your machine's tray. To remove the error, press the red button on the control panel and check the size of the document within the printing properties. If the papre size of the document and the paper in the tray are correct then try to use another tray or bypass tray. If the problem still persists, call for service.
Dec 06, 2013 | Xerox WorkCentre C2424DN All-In-One Laser...
LSU error in XEROX workcentre pe220. What is the
R/sir,
I have a Fax machine of Xerox make model PE220.From BSNL line connectivity is allways out of order.I want to connect FIXED CELLUR TERMINAL (FCT).After conecting machine give dial tone for outgoing calls.and other end caller received a fax tone on their machine when they want to make a call on my machine.But printer is not printing after some LCD diplayed a massage communication error.Kindly GUIDE me for change in settings.
Thanks and regards
PK Jain
(Pennywise)
Dec 15, 2010 | Xerox WorkCentre PE220 Series
Xerox 4150 prints from Macs but not from XP
Have you updated the machine firmware? At Xerox.com the machine firmware is there to download and install. Currently the firmeware is at level 10.100.45.018. Even if your machine is new you may have an older version of firmware.
That machine has had tons of firmware updates to it and uploading the machine to the newest level probably will resolve your problem.
There are some versions that fix 300 known problems at an update.
You have to follow the directions carefully, updating it can wipe out your LDAP settings if you use scan to E-mail etc.
If you have a maintenance agreement, or the machine is less than a year old, ( there is a one year on site warrantee on that machine for on site service) call 1-800-821-2797 and request a service call to update your firmware.
Those updates are really critical for that machine to operate properly.
Feb 11, 2009 | Xerox WorkCentre 4150 All-In-One Laser...
L6 error keeps popping up
That is a laser error. The motor that drives the mirrors is most likely oing bad, The laser unit will have to be replaced.
Jan 30, 2009 | Xerox WorkCentre XD105F Laser Printer
Xerox Workcentre XD125f problem
Does it keep showing that after you replaced the toner cartridge?
Aug 17, 2007 | Xerox WorkCentre XD125F All-In-One Laser...
24 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
