Question about Gemini XL-500 Turntable
I just bought a set of Gemini 500 the belt has come off and I am usure how and where it fixes back on???
  • 189 Answers
HELLO
This should be straightforward. Take off the slipmat and lift off the turntable (platter) and you'll see there is a rim on the underside of the platter this is where the belt goes.
Put the belt round that rim and you'll notice a couple of holes in the platter itself. Hold the belt through one of these holes and put it back on the tunrntable while taking notice of the motor position on the deck.
When the platter is in place (still hold belt) and move the platter to the position of the motor pulley and slip it on. Manually turn the deck once or twice to make sure it is in place - DONE! Replace the slipmat.
ENJOY! (:-)
Posted on Sep 13, 2009
How to fix flutter & wow on a Gemini 500 XLii direct drive turntable
Direct drive turntables have electronically controlled speed. If the records you are playing are warped (not flat) that will cause wow & flutter. If that's not the problem then you might try connecting the turntable to a different power outlet using a long extension cord. Failing that, the turntable needs repair.
Jul 30, 2014 | Philips gemini XL-500 II Turntable
Where to get a needle for Gemini XL 500 II
Look at the cartridge make and model number fitted. Put that into Google and the type of stylus needed will show up.
Jun 29, 2014 | Gemini XL-500 Turntable
I bought a home with this system and need to be able to use it. Who can help me set it up?
i bought a home with a gemini system in it / i dont have the old codes can i reset this key pad
Oct 07, 2011 | Gemini Sound Products Gemini Napco...
I need a replacement cartridge for the gemini xl 500 ii series and i can't seem to find it in any stores or online.
Maybe this will be of help?
http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=GEMSXL500II
Aug 03, 2010 | Gemini XL-500 Turntable
I BOUGHT NEW KENMORE 500 WHEN TURNED ON IT ONLY HUM
Check the belt to see if its broken
or off the Drum or Idler Pulley.
If the belt is in place
(there is usually a mark on the drum where it should go)
then I would call the place where I bought it,since it's new, & tell them to fix it or you will call:
The Better Business Breau & Sears Headquarters.
I'd give them at least a week to make it right....log everything that you do.
Good luck,
Vinnie
May 30, 2010 | Kenmore 500 6952 Dryer
My gemini cdm-500 comes up with a error wen trying to play a cd on one side
HI. i would try cleaning the lens with cleaning disc. if this doesn't produce results, the issue will then be a damaged optical lens assembly. you will need to replace this assembly in this case.
May 28, 2009 | Philips Gemini CDM-500
Turntable will not hold pitch,speeds up or slows down.
try replacing the drive belt with brand new one and see if this improves the situation
May 27, 2009 | Philips gemini XL-500 II Turntable
Gemini XL-500 Turntable Logo
98 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
sean tan
Level 1 Expert
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
