Samsung LNT4061FX makes clicking noise before coming on.
My Samsung TV when you turn it on in the mornings it acts like it going to come on it makes a clicking noise and red light flashes this will repeat about six or seven times then it will come on. Once it comes on you can turn it off and turn it back on and it will come right on. It just does the clicking noise several times before actually coming on in the mornings, when the tv is cold.
  • mlisa402 Sep 13, 2009
    How do you do that?
    Can you fix it your self or do you have to have repair center do it
  • 60 Answers
Replace capacitors in power supply you will see that they are bulged on top
Posted on Sep 13, 2009
My samsung tv is making clicking noises and won't turn on
Clicking noises may mean a power supply voltage is not staying correct or that board is bad---a suggestion: visit shopjimmy.com who has by model number a list of all the boards used in almost every Samsung Flat screen set made.
Jun 17, 2012 | Samsung Televison & Video
Turned the TV on this morning and it is making a clicking noise
I know exactly what the problem is. If you feel competent to do so..remove the back of the tv with the power disconnected for your safety. On the power board located in the centre you will see capacitors on the right of the board that have bulging tops..There are usually 4 of them that bulge (go faulty) like this..The value of each of these should be 1000uF..Replace these by buying from Maplins Electronics or CPC, both online..Solder new ones in (takes 10 mins) and all will be ok..
Feb 04, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Clicking noises before TV turns on.
The clicking noise is coming from the power supply relay. Is makes this sound when the TV is usually turned on or off but has become faulty. It will only get worse over time usually until the TV will no longer turn on anymore. You need to replace the power supply in order to fix the TV.
Nov 07, 2009 | Samsung LN-S4052D Television
Samsung LCD TV slow to start
Dont have a solution, my samsung 46 inch is doing same thing. Have you found a solution?
Oct 05, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Samsung tv turn on problem
check here: http://www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound/ [worked for me]
Aug 23, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
I have a Samsung LNT4061FX/XAA Serial no. AHBA3CSPA03617J. The TV will not turn on. It just continues to Click and the Red light in the front goes on and off. Is there a part available to fix this problem?
Regarding the problem with LNT406FX/XAA models not powering up - I contacted Samsung @ 1-800Samsung and they issued a repair tag and put me in touch with a repair company that came out the next day and replaced the capacitors on the power supply. Apparently Samsung got a batch of bad capacitors from a supplier and they know which TVs by the serial numbers. My TV was 28 months old and there was no charge. TV works fine now. Good for Samsung for acknowledging they had bad parts for and getting the tv fixed at no charge.
Aug 17, 2009 | Samsung Televison & Video
Samsung LNT4061fx does not turn on
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts.
Good Luck, big IRISH.
Nov 20, 2008 | Samsung TXG2547 25" TV
Televison & Video Logo
834 people viewed this question
Top Televison & Video Experts
