Question about Kodak EasyShare C875 Digital Camera
The lens on my C875 is stuck in the out position and won't retract. Nothing seems to work as if there was no battery in it. Help.
    President:
  • 2,761 Answers
If you've recently dropped the camera you may have damaged the lens tube (housing). This can prevent the lens from moving. This problem will require professional repair. If you haven't dropped the camera though, this problem is frequently battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing into the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Posted on Sep 13, 2009
Lens error for coolpix l3. The lens won't retract and the camera won't work. took batteries out and put new ones in. nothing is working. is there a way to reset the camera?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 29, 2011 | Nikon COOLPIX L3 Digital Camera
Optio 555
Is the lens totally stuck? Does it even move a little? Did you try to power cycle the camera?
Feb 27, 2008 | Pentax Optio 555 Digital Camera
Hi I slipped in the garage and dropped the camera when it was on==batteries came out and lens of course didn't fully retract. Put batteries back in and the green light comes on and beeps but won't...
Sorry about your moms camera Terry... but it sounds like it needs the lens replaced. If the lens is stuck out at an angle you can *SNAP* the inner lens section back into place if you're lucky, and it will work again like normal.
I don't know your model, but a refurb lens can usually be installed for about $75 including return shipping. You should check the replacement cost of a used camera and see which is cheaper in the long run.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Samsung Cameras
Camera stoped working and lens is in the out position, i can't get it on again
It seems your camera Lens got stuck in open condition, This will happens due to two reason.
1) Either your camera battery got died or need to be recharged or replace.
or
2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery indicator on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Follow the instruction to retract camera lens:-
1) Turn on your camera.
2) Press the Playback button on the back of your camera. The lens on your camera should retract.
If problem still not resolved then your device need to be serviced (Repair).
Rating the solution is highly appreciated...Good Luck.
Feb 28, 2010 | Samsung Digimax S750 Digital Camera
Lens stuck in "out" position. Won't retract.
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Mar 22, 2009 | Samsung Digimax S630 Digital Camera
C875 lens won't retract
Camera (with new rechargable batteries) won't let the lens come out or if it does it instantly retracts.
Nov 14, 2008 | Kodak EasyShare C875 Digital Camera
Stuck lens
You can restart the camera (power off and on or follow reset procedures) and/or try to get the grit out so the lens can retract.
Jun 25, 2008 | Kodak EasyShare C875 Digital Camera
My nikon says lens error
my camera says lens error. the lens is also stuck in the position as if it where taking pictures. it will not retract.
Jun 16, 2008 | Nikon COOLPIX L5 Digital Camera
Camera won't turn on
Are you using Lithium batteries?
ALL Kodak cameras have huge problems with alkaline batteries (including brand new ones)..
Hope this helps.
Jan 17, 2008 | Kodak EasyShare C875 Digital Camera
Lens Error - Cool Pix L6 - Camera unuseable
Dont know if this will help anyone. I had a lens error for ages. In my long lasting devotion to google serk I found that many equall contenders found that a strike with a soft book in different directiions solved the problem. I ended up beating the camera from all angles with the palm of my hand. But hey! it worked. 4 months later im looking for the cure to system error 2. If you can help wi that one.
Sep 11, 2007 | Nikon Coolpix 5200 Digital Camera
Kodak EasyShare C875 Digital Camera Logo
78 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
