Question about Solar Electronics - Others
MPPT Ml2430 solar control. it shows night setting during day so not charge. How do I change setting?
5 Suggested Answers
SOURCE:
  • 65 Answers
SOURCE: Date Changes during the day
Hi Jeffrey, Put stem into "set hands" position and adjust hands to the 12:00 position. Day and date should advance at or close to that time. If you pass 12:00 and there's no change continue rotating another 12 hours and they should advance. Once youv'e found that there's midnight so if you're setting the time at say four (4:00) in the afternoon (pm) you will neew to rotate the hands so around the dial so they pass 12:00 once more then four hours more to 4:00. Now I assume by bilingual you mean that the day ring has like Mon (monday) and Lun for Spanish or the like. In this case if it's showing the wrong languare set the crown (winder) to the first position (second posn is "set hands) and rotate winder eithr clockwise or anticlockwise. Once you discover how to advance the day ring just set it to the correct day/language you want and press the crown home. Hope this solves your problem. If the advances are changing at some obscure time like 8:40 or something it's because the hands pave been located incorrectly and would need correcting by removing movement from the case.
Posted on Jul 24, 2009
Testimonial: "Perfect- very detailed and easy to follow. Thank you!"
01fordeb
  • 1033 Answers
SOURCE: solar cockerel light. the prolem
Yeah, there seems to be something covering the light sensor causing the light to stay on throughout the day preventing it from having any energy to produce light for night. Good luck
Posted on Apr 19, 2011
davidgrog30
  • 136 Answers
SOURCE: Solar lights that never go out!
Very common in the more cheaply manufactured lamps I'm afraid. It's fairly simple, in that the photo-electric cell that monitors whether it's daylight or dark has failed (or one of its connections has). Probably the simplest/easiest solution is to replace the whole unit. Alternatively, find a competent electronics engineer and ask them to take a look. Good luck!
Posted on Jun 11, 2012
alicelee400
  • 39 Answers
SOURCE: i"m working on a project to create a solar powered
If you are looking for solar kits South Africa has many choices to choose from but the best solar inverters South Africa has can be found at Ayatrading.
Solar Kits Solar Water Pumps Solar Inverters South Africa
Posted on Nov 20, 2015
Do Solar powered lights work for outdoors?
yes
they have installed a small aa battery that is charged during the day by the solar panel and run until flat at night
Jun 15, 2017 | Solar Hardware & Accessories
My Denon DM39 that I purchaed yesterday keeps powering off and then a red light flashes. Coudl it be related to my solar power?
Sounds like you system is set up to only provide output current when not charging via the array... its common... shut off or disconnect panels and your problem is solved but the batteries won't be receiving any charge obviously... this set up is used when the systemhas nothing to limit or control the current produced from the arrays/panels from going directly to the attached output devices. This is typical in small pv systems.
Dec 30, 2013 | Denon DM38S Audio Shelf System
I"m working on a project to create a solar powered
Hello. Think I found the necessary information you require. Check out this link:
http://www.solarpowerwindenergy.org/2009/04/26/how-to-build-a-small-solar-circuit-wiring-diagrams/
There are schematics for each stage.
This one is a ladder diagram schematic only:
http://electroschematics.com/5988/outdoor-garden-solar-lights-circuit/
Good luck, and if this helps, rate it a four-thumbs up please. Thank You.
Apr 21, 2011 | Atlantic Water Gardens SINGLE LARGE LED...
Solar cockerel light. the prolem is the light does not light up at night. I think the light sensor does not work, the light is on during daylight, the battery does not charge enough for the light to work...
Apr 19, 2011 | Garden
I've a pentair solar control panel for my solar system for my pool. On one sunny and very warm day in California, the water in the pool remained cold after a few hours of circulation. Therefore, I was...
There are many variables to this......
How big is your pool how big is your solar system.
Solar temps don't rise quickly ever, and definitely not when the temp is only 75 outside.
You need 80-90 degrees or more on the roof to see quicker results, if the water temp is currently at 70 and it's 75 degrees outside and 80 on the roof you will barely get any change.
You will also lose the heat at night due to lower temperatures.
Once it's hotter outside and warmer at night you get the gains and keep them.
Hope this helps
Mar 24, 2017 | Fafco Deluxe Solar Panel Heating System 1...
SunForce 2500w pure sine wave converter add on
Mixing different AH rated batteries, different ages of even the same type battery is a bad idea. The new batteries will be effectively reduced to the equivalent of your worst battery.
Jun 24, 2010 | Sunforce 11260 Pure Sine Wave Inverter
I would like to rewire a solar security light (motion activated) to stay on at dark. Brand westinghouse
The light will only stay on as long as the battery lasts. My guess is that will not last all night. What you can do is buy a light sensor switch (or even a light sensor socket adaptor is available to save you from having to wire it in) to keep a light on during the night. You can use a CFL or even an LED lamp to save electricity, but it is unlikely that a solar-charged cell will power even one of thes all night long.
Nov 16, 2009 | Solar Motion Security Light Conversion...
I just bought a pack of Westinghouse solar lawn lights and the lights are excessively dim at night. I know they are supposed to be brighter. They are in very dark places at night that get great sunlight...
Not a solution but -
if you put your batteries in a battery charger (normal battery charger) and charge them, they will work sooooo much better.
Just keep doing this every time they seam to be dull (after many clowdy days)
Jun 09, 2009 | Garden
My seiko stops overnight but works during the day
if the watch is solar power it may not be getting enough to last through the night. if it is battery powered it may just be stuck when in certin postion like upside down or somthing
Jun 03, 2009 | Seiko Kinetic watch
Electronics - Others Logo
27 people viewed this question
Top Solar Electronics - Others Experts
Sheldon Dedek
john h
ray gallant
ray gallant
Are you a Solar Electronics - Other Expert? Answer questions, earn points and help others
