Too much suds, clothes went out of the tub to the outside of the tub. I put too much detergent in the washer and my clothes came over the top of the tub into the outside of the tub...how can I get my clothes?
  • 1,543 Answers
If you are asking how to get rid of the excess suds, try this:
Buy a package of Phyzeme (not sure of spelling) at the drug store. It is for stomach gas. Cut open about 3 of the gel capsules and squeeze the contents into the sudsy water. Turn machine back on. Bingo, suds will disapear.
Posted on Sep 13, 2009
Why whirlpool duet washer
There are a number of causes for a SUD error. The most common is using non-HE detergent or just too much detergent. Try taking the clothes out and running the washer empty. (Do not add detergent.) When the tub doesn't have any suds, retry with a small load and very small amount of HE detergent.
The next issue is clogged drain hose/pump filters. Take the drain hose off the back of the washer and clean any debris with Q-tips or similar until you see the filter screen. The pump filter is sometimes called a coin catcher. You'll need to carefully check that. Take a small bucket or bowl to catch the water when you disconnect the hose from the tub to the pump.
The final cause is a leak either at the detergent "box" or in the tub or a bad sensor claiming there is such a leak. If the unit is detecting suds outside of the tub, you will need to call for repair. Depending on the age of the washer, this may be covered under warranty.
I hope this helps.
Jun 04, 2013 | Washing Machines
Maytag bravos MVWB300WQ1 keep getting sd code on ever other wash
The SD error code is caused by using the wrong detergent or excessive amounts of detergent.
To correct the issue: Make sure to use HE detergent. Note: Using Non - HE Detergent will cause oversudsing and can damage the washer. Do not use too much detergent.
Note: If using HE 2x - 5x concentrate detergent, reduce the amount being used. The washer will try to run a mini-clean out cycle using cold water and a 5 minute pause to clear the suds. If this cycle does not clear the display and complete the cycle the clothing may need to be rinsed by hand and then rewashed without detergent.
Feb 18, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
What does an F 35 problem indicator mean
The F35 indicates a water level pressure sensor failure. The SUD is normally displayed when there is excessive detergent suds in the tub. Make sure you are only using the recommended amount of HE detergent. Then run the washer without clothes on a drain and spin cycle. If the tub is empty and you do not see any suds please continue with the following trouble shooting tips. A loose wire harness connection could be causing this problem if there is no water or suds in the tub. I recommend unplugging the washer and removing the top panel. Screws at the very back of the top panel secure it to the washer frame. Remove the screws and then pull the top panel slightly back and then up and off of the washer. The analog water level pressure sensor is shown in the first image below. The second image shows a clear picture of this component. Check the wire harness connection on this sensor. If you find a loose connection, secure the wire harness properly on the component then reassemble and test the washer. If you continue to get the F35 code, then the pressure switch will need to be replaced.
Sep 22, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Washer displays F35
You can order a new analog water level pressure sensor from the Sears PartsDirect website.
Hope this helps.
Jul 31, 2011 | Maytag EPIC MFW9700S Front Load Washer
First my washer is saying sud, then going to f 35. not sure what to do
The F35 indicates a water level pressure sensor failure. The SUD is normally displayed when there is excessive detergent suds in the tub. Make sure you are only using the recommended amount of HE detergent. Then run the washer without clothes on a drain and spin cycle. If the tub is empty and you do not see any suds please continue with the following trouble shooting tips. A loose wire harness connection could be causing this problem if there is no water or suds in the tub. I recommend unplugging the washer and removing the top panel. Screws at the very back of the top panel secure it to the washer frame. Remove the screws and then pull the top panel slightly back and then up and off of the washer. The analog water level pressure sensor is shown in the first image below. The second image shows a clear picture of this component. Check the wire harness connection on this sensor. If you find a loose connection, secure the wire harness properly on the component then reassemble and test the washer. If you continue to get the F35 code, then the pressure switch will need to be replaced. richroth_129.jpg richroth_130.jpg
Apr 21, 2011 | Washing Machines
The waste doesn't drain all the way.clothes remain soaking wet and often during a separate drain cycle it flashes: sud
if you are using to much detergent the washer won't drain correctly and if it's a front loader you'll damage the spider gear and then it's time for a new washer.the detergent eats at the metal and the gear on the back of the tub falls apart,i've found pieces of it in the pump on some washers,you should be using 1/4 of a cup of detergent in a front load washer,if you're using a whole cap it will suds up,the pump can't move the suds,when the suds sit for a while it turns back into water,take out the clothes,fill up the washer and drain it out,flush it out a few times to get all the suds out and cut back on the detergent
Jan 14, 2011 | Washing Machines
Can you use regular detergent with front loader washers??
All manufactures suggest using a high efficiecy detergent. They are specially formulated to keep the suds level low and work well with the low water levels of a front loader. Boxes are marked with an HE on them letting you know they are for high effiency machines. Regular detergents were designed for washers that use many gallons of water.
Feb 03, 2010 | Kenmore Elite 45986 Front Load Washer
Do Frigidaire Front Load Washers require H&E detergents?
The answer is YES. Nearly all front loader washers built for consumers are rated as high efficiency because of the small amount of water and electricity they use. This small amount of water, coupled with a wash tub that does not agitate continously, followed by a high speed final spin of 1200 rpms or higher, all equate to an overall energy savings as compared to a conventional top loader. Regular detergent is formulated to be used in a wash tub with a 35 gallon capacity. So, if you use that same detergent in a wash tub that uses 5 to 7 gallons of water (such as yours), you are in effect putting about 5 times the concentration in the washer. This can lead to soap scum build up which causes odors, soap deposits that remain in your clothing and can cause skin irritation, "SUDS" errors that stop the wash program due to too much suds in the wash tub, and premature wear on the drain pump motor and seals. In fact, most front loaders will have a disclaimer added in the owner';s manual that explains this. Most manufacturers will also void the warranty if it is discovered you are using improper detergent. Use HE detergent and pay attention to the label. Some of them are double (2X) and triple (3X) concentrated. I hope this helps you.
Nov 30, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a HE5t kenmore elite front loading washer. It has done great for about 15 months. We were away for about 3 weeks, and since we have returned, I put in a load of clothes, and it tries to start...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*%^*
Aug 27, 2009 | Kenmore HE2 Plus Front Load Washer
I got a SUD code, i've rinsed and spun 3 times, taken the clothes out and ran another rinse and spin cycle, the suds went down. I put the clothes back in (after I rinsed them well in the sink) used the...
The "SUDS" error can be caused by too much detergent, improper detergent, drain pump/drain line problem, or pressure switch malfunction.
1. If you are not using HE detergent, you need to be. These washers are designed to use HE detergent which is formulated for wash tubs that use 5 to 7 gallons of water. If you use regular detergent, you are, in affect, placing a higher concentration of detergent in the washer that is normally formulated for wash tubs that have a 35 gallon capacity. The manufacturer should have a disclaimer in the owner's manual explaining this. In most cases this will also void your warranty. NOTE: Prolonged use of the wrong detergent can damage the drain pump components and or wash tub seals.
If you are using the correct detergent, double check the label to make sure it is not double (2X) or triple (3X) concentrated. You could still be placing too much soap in your wash.
To get rid of excessive detergent, place the washer on a RINSE & SPIN cycle, then run it through a normal wash cycle with NO detergent added. You may have to repeat these steps depending on the amount of detergent used.
2. If you do not have a detergent issue, double check the drain pump and drain lines to ensure they are not obstructed in any way. Click on the following link for step-by-step instructions:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Obstructions in the drain pump and/or drain lines can attribute to air getting trapped in the drain pump and cause the error code. Double check all electrical connections to the drain pump and Central Control Unit (CCU). You will need to remove the top panel of the washer to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top panel in place. With the screws removed, slide the panel back, then off. The CCU is located directly behind the wash tub in the center of the washer. The Drain Pump connector will be the 6th connector (facing from the front L to R) in the center of the CCU.
3. Check the Pressure Switch to ensure it is good. The Pressure Switch is located to the right of the CCU as you are looking from the front. It is a small cylindrical shaped device with a connector plug and an air hose attached. The switch can be checked at several water levels by removing the plug and taking resistance readings at the connector pins. Readings are as follows:
(Pins are numbered R to L facing the from the REAR)
Pins 1 to 2 (SUDS Detect) – 0 ohms
Pins 3 to 4 (Overflow) – 0 ohms
Pins 4 to 5 (L1) – 0 ohms
Pins 4 to 6 (Empty) – 0 ohms
May 08, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
