Question about Homelite Garden
My homelight gas trimmer won,t start - Homelite Garden
  • 124 Answers
You have to provide more information than that. Look in your owners manual for the trouble shooting guide and see if that helps. If you can not do that e9ther take it to a repair shop or just buy a new one.
Posted on Sep 14, 2009
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
Homelight weed either won't stay running
Several things to try: 1) Spray a LITTLE carb cleaner in and try to start Do not do this more than twice. Let set for a day..then try to start. This should help clean out any gunk. Spraying anymore will just dry up important parts. 2) If after priming and it runs and then dies then the diaphragm is suspected. If this is an old model..it may be just wore out. 3) Inside the gas tank there should be a filter..makes sure it is not clogged or wore out 4) Carb could be bad. Could cost more to fix ...throwing parts at it. Talk to local small engine service after trying these things..they may have other suggestions.
Jun 03, 2014 | Garden
Have two string trimmers, both hard to start. shindawa homelite 62061 & toro TB21EC. H/L does great job when it starts. Toro won't come up to speed. Have cleaned carbs in both and checked plug
When you say it will not rev up to full speed, that sounds to me like a blockage either in the spak arrester in the muffler outlet, or the exhaust port is blocked, or the muffler itself is blocked.
May 11, 2012 | Toro Garden
How to replace string in trimmer Homelight UT2006
To replace the string, you need to open the center cap by unscrewing the screw in the middle of the rotatory wheel. Then you will see the channel where the string runs through put the string there and close everything.
Thanks.
Jul 27, 2011 | Homelite Mighty Lite Lawn Trimmer
Hi, was just wondering what the fuel ratio is for the Kawasaki Homelite HK-18-B model TD 18? Thankyou
I have had many 2 stroke engines in my day, and all with different ratios... Homelight always uses a 50-1 ratio.
Jan 09, 2011 | Homelite Mighty Lite Lawn Trimmer
SPARK PLUG GAP
Should be .25 ivches. Try it...Lee
Oct 04, 2009 | Garden
Fuel Adjustment for a Homelight Edger
Does it operate well with the choke full off or do you have to have it partially choked to get it to run? Also, how old is the gas and have you tried to run any cleaner through it b/4 messing around with the carb? Your local auto parts store sells a product called Sea Foam Cleaner. You can add that accordingly with your oil and gas mixture to help clean out any dirt in the carbs.
Aug 08, 2009 | Homelite Consumer Products Tiller...
Fuel line on Homelight
the filter in the gas tank that line goes to carb
and the one that line goes to bulb
Jul 18, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Homelight trimmer dies
check the tightness of your cylinder to crankcase bolts sometimes they work loose and and blow the gasket
also at that time when it shuts down pull you plug and check for spark?
Jun 08, 2009 | Homelite Garden
Homelight MightyLite 17" Straight Shaft Trimmer
a lot of times there is a hole in the side of the head to insert a rod into so the head doesnt spin..now all you have to do is figure whitch way it turns as some a left hand thread
Aug 06, 2008 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Garden Logo
114 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
