Question about Koss USB Dongle Wireless Adapter
During installtion error shows that xp logo not passed,stop installation.When installed anyway icon occurred &intallation is completed.After restart *228 is called to activate,after programming of 2.15 minutes,error shows programming unsuccessful for several times.MDN No. 9302567384 sl no.RRSUK0037111536.After inserting inUSB alert shown repeatedly for logo &impairment.timetaken is more than half hour in stead of two minutes.Koss USB Dongle wireless Adapter LXU800,LG make
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and DEVICES (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updatig the drivers from the KOSS site
Posted on Sep 13, 2009
Software installed successfully. Scanner will not scan. Troubleshooting Assistant insists an error occurred during installation of device. It also says Epson Perfection V500 Photo does not pass...
Try shutting down your computer and then unplug from the power source. Wait a minute then plug it back in and turn on the computer.
Accept the driver installation even though it does not pass Windows Logo testing. Just accept it and continue with the installation.
Oct 05, 2010 | Epson Perfection V500 Flatbed Scanner
Lsass.exe system error An invlid parameter was
It seems your system file got crashed which you need to recover using Recover Disc.
Take any Windows XP installtion disc and boot the system from CD.
After all the scanning of Hardware it ask you want to install fresh copy of windows or you just want to repair it.
Choose Automatic repair, it will run thru the wizard as similar to windows intallation. Only difference it will just repair the crrupted system files without user files loosing.
So thats all you need to make it work fine.
Sep 10, 2009 | Microsoft Windows Xp Home Edition Sp2...
Nero7 installation problem
There should be no problems installing Nero 7 on XP SP2. Don't worry about the windows logo testing just answer continue anyway. Once the program is installed just go online and check through Nero for any updates.
Jun 09, 2009 | Microsoft Office Outlook 2003 for PC
Intex pc camera night vision ZC0301H
It just means that Intex didn't go thru microsoft to make sure that the software is written so its completely compatible with the operating system. That message honestly most of the time doesn't mean anything, just means it doesn't pass certain checks thru the Operating system but not all hardware needs to pass all the checks to work. Most hardware will work anyway.
When that message comes up, click on continue and let the software install. The computer will still recognize the hardware and everything will still work anyway. As long as the system can install it properly in the end then all is well.
Jun 01, 2009 | QPS QSIPBL2 Network Camera
Installation problem.. at the end of installation of the game ''desperados'' it is showing error occured during installtion and gives a error number as ''2''.
Error 2 has to do with your cd-rom not reading the disc correctly. Make sure the lens on the cd-rom is clean and it should install without a problem. You'll need a cd-rom cleaning kit for this.
Also if you can try installing the game on another computer. You should also check your CD's surface. Good luck
Apr 12, 2009 | Computers & Internet
I cannot find a driver for my Toshiba mass storage device.
Go to BIOS and change the USB setting to full speed and save it and continue. I am sure it will work after that....sodeep
Mar 24, 2009 | Computers & Internet
STOP: error msg
Boot up with your XP install CD and do a repair.
Go through with intalling XP on the same partition, pass the first repair notification, you will eventually get to another repair choice, this option will restore files and should leave your daa intact.
Nov 29, 2008 | IBM ThinkPad T40 2373 Notebook
Printer install problem
hi friend
u have to do this
1.plge in ur usb printer cable on other port
2.do not on ur printer
3 put ur printer cd in ur cd rom drive
4install ur printer software
5 in between the installtion ask to u power on ur printer then u have to on ur printer
5 completing the printer installtion
try to print
& thnx uing fixya
Mar 30, 2008 | HP Photosmart 2610 All-In-One InkJet...
Koss USB Dongle Wireless Adapter Logo
83 people viewed this question
Top Koss Computers & Internet Experts
David Payne
David Payne
Are you a Koss Computer and Internet Expert? Answer questions, earn points and help others
