Question about Sharp R-510HW Microwave Oven
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
I have a Sharp Carousel Convection Microwave R-9H56. The microwave works fine. The problem is the convection. You set it to pre-heat and it goes through the motions like it is preheating ie. carousel rotating, light on, making noise like it is working, but it takes forever. Eventually it suddenly stops (makes no sound like it has turned itself off). The display is static, displaying the temperature I was trying to heat it to and if you feel inside the oven it is stone cold (hasn't heated at all although it says it is preheating for so long). Another problem is it doesn't do it all the time. 50% of the time it works fine then next thing it won't. Taken it to be repaired twice. Had the thermostat replaced but still doing the same thing. Repairers cannot find problem. Help please. I really don't want to replace it as I love this oven.
  • 5 more comments
  • yenrah Feb 08, 2008
    I have the same problem as described...I set it to preheat, it seems to be working , then shuts off without getting warm. I would like to know if the other poster found a solution to the problem.
  • Anonymous Feb 10, 2008
    i have the same problem but the turntable is not turning
  • mrbeezer Jun 20, 2008
    similar problem except that if I place the oven on it's back it works fine. Checked all sitches and all are ok.
  • Anonymous Jun 28, 2008
    My micro is doing the exact thing except it does heat the micro/oven up but then stops will no warning and the temperature is never reached that you were trying to reach. Sounds like it is a defect on sharps side!
  • maggie311 May 22, 2009
    I have the exact same problem - the microwave does not heat - I had this microwave repaired about 4 times and there is still a problem. It is a fantastic one, large and looks good in comparison to today's inferior looking microwaves. I am in the Western Cape South Africa
  • Anonymous Mar 27, 2014
    will not preheat for convection baking and will not re-heat on microwave setting
  • Anonymous Mar 29, 2014
    will not mircrowave or preheat for convection
    Champion:
  • 225 Answers
At highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Posted on Dec 12, 2007
  • amd64online Apr 25, 2011
    The micro switch for the door stops working. Poke it with a wooden (non conductive) skewer about 20 times should temp fix it.
I have a sharp carousel but the convection oven is not heating up. The microwave works.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ,./';
May 24, 2011 | Sharp Carousel R530EST Microwave Oven
It is a sharp R-1870 turns on and runs but no heat from convection or microwave also carousel does not turn
heatman101
Apr 09, 2011 | Sharp R-1870 Convection/Microwave Oven
Sharp carousel convection/grill/microwave maybe R990
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Jun 03, 2010 | Panasonic NN-S254BF Microwave Oven
Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
Sharp microwave stopped working
Is it totally dead? No display? Or just does not cook? If it made an unusual noise before it 'died' something probably shorted out.... You need an ohm meter to troubleshoot. If the fuse is open, switches and HV circuit need to be checked before replacing fuse. Sometimes on the convection Microwaves (not just Sharp) the fuse will 'rust' and open rather than blow. Or the fuse holder can over heat and fail.
Sep 11, 2009 | Sharp Microwave Ovens
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Aug 29, 2009 | Sharp R-1870 Convection/Microwave Oven
Sharp Carousel R 9H56 Instruction manual & Cookbook
http://www.sharpusa.com/products/TypeDownloads/0,1087,5,00.html
Here is a link for your model.
Feb 23, 2008 | Sharp R-820B Convection/Microwave Oven
Sharp Carousel Model R-9H56
Check that the plastic connector from your motor to the turn table is not broken , mine broke and it took weeks to solve the problem. Try rotating the part that protrude into the oven. If you can turn it by hand it is broken, lucky cheap to replace
Nov 21, 2007 | Sharp R-510HW Microwave Oven
Sharp R-510HW Microwave Oven Logo
1,583 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
