Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Replaced keyway but lawnmower still will not start.
  • 718 Answers
The last one I worked on needed a new coil, was not getting spark. Check to see that yours is getting a spark, also check to see that the coil is close enough to flywheel, since you changed the key way. I assume that you removed the flywheel.
Posted on Sep 26, 2009
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: Grandson ran lawnmower on tree stump, bent blade
Hi momnpop2...
Either you can rent or if you have a puller the size to fit your flywheel then that is what you will use to pully the flywheel off after you remove the flywheel nut...
There is another way...but be really careful with this method...you can cause damage it if your overley aggressive...
Loosen the flywheel nut about 3 turns...then get two screwdrivers and put pressure on the flywheel from underneath with both screwdrivers at opposite sides of the flywheel.
Then with a brass/bronze hammer or rod strike the top of the flywheel nut as you are prying up on the flywheel with the screwdrivers...you will need some help to do it this way...
Someone to operate the screwdrivers while you hammer on the nut...the flywheel should pop up and then remove the nut and lift the flywheel.
Note: DO NOT USE A STEEL HAMMER...IT WILL DAMAGE THE NUT AND THREADS BEYOND REPAIR.
Please take time to rate me thumbs up
Posted on Sep 23, 2011
Lawnmower won't start
1. Bad gas
2. Check for spark
3. If no spark check flywheel alignment and gap on magneto coil and flywheel
4. If spark is present and flywheel is aligned with keyway, check for fuel manifold leaks
5. Check carburetor for debris
Aug 06, 2016 | Garden
How do I remove the blade and the sprocket piece that holds the blade on?
looks like it might have a pin thru the shaft then use a gear puller.lots of penetrating oil too
May 08, 2015 | Briggs & Stratton Briggs Stratton...
Lawnmower keyway
After you remove the nut that holds the cup on the key way is under the cup and the flyywheel has a slot in it which fits over the key which is in the key way.
Jun 12, 2014 | Briggs & Stratton Lawnmower Quantum...
Replaced the harmonic balancer and keyway, but the car won't start. The belts are turning all right.
Check that you have not damaged the crank position sensor or disconnected the wires to it . Check the air gap and the rotor for dirt and any thing that will prevent the sensor from working correctly.
Mar 23, 2014 | Honda Odyssey Cars & Trucks
Ridding lawnmower stopped woking vibrated then stopped
Did you hit something Hard with the lawn mower blade? That will break the keyway and cause the Timing to be off.
Nov 24, 2013 | Briggs & Stratton Garden
How to replace a square key on a lawnmower axle
Marc, if the wheel does not have the channel for the square key, then you have a mismatch and the wrong wheel. Put a new tire on the old wheel, or take it in to a mower shop and ask for an exact replacement.
junkl
May 07, 2013 | Murray Garden
Replace keyway
you will have to go to machine shop have it cut should cost 20.00
May 07, 2013 | Garden
Does briggs&Stratton have shaft extensions to lower my blade 1in. or 2
are you sure you have the blade on the right way or the right blade for the mower?
Apr 01, 2012 | Briggs & Stratton Briggs Stratton...
Mower Blades
most lawnmower shops can help you prob just a worn keyway ! or goto black&decker.com for closest repair shop?
Aug 27, 2009 | Electric Lawn Mower
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
260 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
itsman
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
