Question about Radio Communications
SOHO HEADSET BLUE TOOTH DOESN T WORK ONLY WORKS WITH WIRE NO VOL.
SOURCE:
  • 274 Answers
SOURCE: blue tooth adapter and hs850 headset on my computer
Yes, you need the blue tooth driver. The one that comes with your blue tooth "toggle". Although my laptop said "blue tooth compatible" I still needed a toggle. They are fairly cheap to buy and go into a USB port.
Posted on Sep 23, 2007
  • 33 Answers
SOURCE: blue tooth headset for nokia 3110c
You can purchase a universal bluetooth headset and then pair the device using the instruction manual that comes with the headset. This is a very easy process and all you need to do is make sure that the blutooth on your phone is switched on. When you turn the headset on, it should automatically pair after the first attempt.
Posted on Jun 09, 2008
SOURCE: Bluetooth problem
I have an lg sprint muziq and I cant get my blue tooth headset connected. The phone can't read or see the blue tooth head set
Posted on Jul 04, 2008
mistersony
  • 320 Answers
SOURCE: Can't bond Samsung bluetooth(WEP 200)with my Motorola A1200 Ming
Try this (from the manual)
2 Press and hold the Multi-Function button until
the indicator light turns on in blue
(approximately 8 seconds).
Posted on Oct 31, 2008
rockfixya
  • 679 Answers
SOURCE: motorola h350 blue tooth headset microphone does not work
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H350 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 22, 2009
I try to connect my blue-tooth headset model NOKIA BH-209 with my Nokia E63 mobile phone , but My NOKIA E63 mobile phone does not search NOKIA-BH-209, my NOKIA blue-tooh BH-209 is working with an other...
PLEASE MAKE SURE THAT YOUR PHONE BLUE TOOTH IS WORKING PROPERLY IF YES TRY CONNECTING YOUR PHONE WITH OTHER BLUE TOOTH HEADSETS. IF IT GETS CONNECTED YOUR PHONE DOESN'T SUPPORT YOUR HEADSET. IF IT DOESNT YOUR PHONE ISN;T WORKING GOOD.
Jul 18, 2011 | Cell Phones
I have connected the headset Blue-tooth with my laptop there is a blue tooth connection but no sound (music).from my media player (windows) I can change the numbers but there is no music. Hetset DR-BT21G...
It seems your laptop Bluetooth could be 1.1 version and headphones are 2.1 it won't work. I would suggest wired headset or get a 2.1 the difference is 1.1 doesn't not allow high quality sound 2.1 does allow stereo sound. here is a sample IOGear USB 2.1 Bluetooth Micro Adapter GBU421
Mar 02, 2011 | Sony DR-BT21G Wireless Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
Does explorer 230 pair with nokia 2600
the explorer 230 blue tooth can be paired with the Nokia phone if only the blue tooth tooth device is a universal blue tooth.
Universal blue tooth can work with any phone no matter the model.So check the blue tooth if it is a universal blue tooth, try it with the phone and see if it will work.
Have a nice day
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
On my ps3 bluetooth scanning for a ps3 headset its
Make sure that your blue tooth is in pairing mode when the sysytem is scanning.(refer to blue tooth headset manual for intrustions)
I hope i have helped and I hope it works!!
Jan 07, 2010 | Sony Playstation 3 (PS3) Console
My jwin TH-130 does not work
when i connect my blue tooth it would work but after i stop talking it would disconnect and then i can not connect it back on
Sep 16, 2009 | Jwin BLUETOOTH HEADSET Wireless Headset
Dont know how to work my blue tooth to my phone
You have to get the phone to recognise the bluetooth headset first. The manual should tell you how to do this. Normally you have to go into the bluetooth menu on the phone and get the phone to detect the headset, and then type in the pin code, normally 0000.
Jan 11, 2008 | Motorola Mobility H700 Wireless Headset
Bluetooth to mobile pairing
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done
Jan 05, 2008 | OEM Systems Bluetooth Headsets - Model...
Blue tooth adapter and hs850 headset on my computer
Sep 17, 2007 | Motorola Mobility HS850 Consumer Headset
MY BLUE TOOTH ISN'T BEING READ BY MY PHONE...
Delete the headset from your phones previous or known devices and turn off phone then back on again and try pairing again. If still same could be faulty phone, but if you can try headset on somebody elses phone to rule out headset.
Jan 23, 2007 | Audiovox SMT5600 Smartphone
Radio Communications Logo
22 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
