Question about Philips Home Audio&Video: HOME THEATER IN A BOX System
Regisitration on product try giveing a stamped envelope to send
Regisitration on product **** poor way to register cant get it to register by doing it on line, and at the price of it you should provide a stamped envelope with the product to send the registration card to ya, this will be my last product me and my friends will buy from philips company and l will inform all of my friends about your company and no stamped envelope to send the registration card in to your company
  • Philips Master
  • 9,231 Answers
Nobody cares. get over it.
Posted on Jul 23, 2017
ThaMp3Doctor
  • 8596 Answers
SOURCE: Register product
The sticker on the back with the serial number may have been removed. Hopefully you still have the warranty/registration card or the box. If none of the above, you are out of luck.
Posted on Feb 11, 2008
SOURCE: How do i reset philips voip4332b ip phone base unit to company default.
This should solve your problem:
1. On your phone select: Menu > System > Base Select
Select "Auto" and press "ok"
2. On your phone select: Menu > System > Register
(you might be prompted to enter a PIN if so the default is "0000" )
3. On the base station press and hold down the  "Page" button for 4-5 secs until the green light starts to blink. At this point the phone should be now able to find the base station.
Posted on Feb 02, 2010
SOURCE: I tried to register my cordless philip CD 155 but
tengo el mismo problema!!!! has podido resolverlo?
Posted on Apr 28, 2011
yesuyassi
  • 26 Answers
SOURCE: Please send me the link
Welcome to fixya. Here is the link for you to register your Philips sonicare toothbrush https://pnregistration.harte-hanks.com/sonicare_Registration.aspx.
Hope this helps.:)
Posted on Sep 11, 2011
How do i send my application forms if they are on paper?
put in an envelope and put a postage stamp and address on the outside of the envelope and then put it in a post office mail box that collects mail to be posted.
If you were referring to email you need to scan the documents and save them to a file. Then you to email and compose an email message and click on the attach a file option and attach eack scanned page via its file name.
If you do not own a scanner
if the place you are sending the application forms has a fax then find out the fax number and then send each page via fax.
If you do not have a fax machine check with your local newsagency if they have a fax machine that you can send faxes on for a paid price.
Jan 30, 2015 | Health & Beauty
How can i get to message my teacher if i don't have kik or a facebook huh
send a letter dude. all you need is a stamp, envelope, pen and a peace of paper. right a letter, stick the stamp and then post it and your local post office
Oct 23, 2013 | Computers & Internet
I don't know how to put an envelope in to print it out.
Please follow the steps below on how to print on an envelope:
  • The print side of the envelope is faceup.
  • The paper guides rest against the edges of the envelopes.
  • You print the envelopes with Landscape orientation. Note: If you are mailing within Japan, then the envelope can be printed in Portrait orientation with the stamp in the lower right corner or in Landscape orientation with the stamp in the lower left corner. If you are mailing internationally, then print in Landscape orientation with the stamp in the upper left corner.
  • You select the correct envelope size. Select the next biggest size if the exact envelope size is not listed, and set the left and right margins so your envelope is correctly positioned.
I hope this information has been helpful. Thanks.
Oct 22, 2011 | Lexmark Interpret S405 Wireless All-in-One...
How do I print envelopes in the printer Samsung SCX 4824fn? thanks
• Successful printing on envelopes depends upon the
quality of the envelopes. When selecting envelopes,
consider the following factors:
- Weight: The weight of the envelope paper should
not exceed 90 g/m2 or jamming may occur.
- Construction: Prior to printing, envelopes should
lie flat with less than 6 mm curl, and should not
contain air.
- Condition: Envelopes should not be wrinkled,
nicked, or otherwise damaged.
- Temperature: You should use envelopes that are
compatible with the heat and pressure of the
machine during operation.
• Use only well-constructed envelopes with sharp and
well creased folds.
• Do not use stamped envelopes.
• Do not use envelopes with clasps, snaps, windows,
coated lining, self-adhesive seals, or other synthetic
materials.
• Do not use damaged or poorly made envelopes.
• Be sure the seam at both ends of the envelope
extends all the way to the corner of the envelope.
Envelopes with a peel-off adhesive strip or with
more than one flap that folds over to seal must use
adhesives compatible with the machine's fusing
temperature for 0.1 second. Check your machine's
specification to view the fusing temperature, see
page 82. The extra flaps and strips might cause
wrinkling, creasing, or jams, and may even damage
the fuser.
• For the best print quality, position margins no closer
than 15 mm from the edges of the envelope.
• Avoid printing over the area where the envelope's
seams meet.
Place the side to be printed facing up.
Envelope Preprinted paper Transparency
Punched paper Card stock Letterhead paper
Labe
open the direct paper try on top of your A4 paper try by pushing it!
Apr 22, 2011 | Samsung SCX-4828FN All-In-One Laser...
Your site is very poor to simply get a new product registered. Far too cluttered. Should get an absolute priority when u have car[ptured a nrew custonmer.
I am sorry that you feel that you were put threw a wringer for registration, what product do you need to register, I will give you a link to the right area.... Guy
Sep 10, 2010 | Health & Beauty
How do you print an envelope
Stamps .com sends you blank sheets of stamps, you insert those sheets per the instructions and print stamps to apply to the envelope.
Aug 27, 2009 | Panasonic Workio DP-3030 Printer
I get a paper mismatch when trying to print envelopes in Stamps.com, what can I do to fix it??
SPENT THREE HOURS DOING THE INSANE OVER AND OVER AGAIN. THEN I DECIDED TO TELL THE STAMPS.COM CONFIGURE THAT IT PRINTED A TRIANGE WHEN IF FACT THE PRINTER ERROR MESSAGE"Paper mismatch.” SHOWED UP ON THE HP MESAGE MONITOR.
I THEN CONTINUED THRU THE PROMPTS ON STAMPS.COM SOFTWARE AND CONFIRED THAT "ALL FOUR" ITEMS PRINTED ON THE ENVELOPE WHILE IN FACT IT DID NOT. THIS GET YOU THRU THE "CONFIGURE PRINTER" SETUP. THEN I SELECTED "PRINT PREVIEW" AND PRINT TEST ENVELOPE AND IT WORKED!! HOPE THIS HELPS. I HAVE NOW PRINTED 30 ENVELOPES,ALL OK.
HP J6480 ALL IN ONE PRINTER
Jul 06, 2009 | HP Office Equipment & Supplies
Need to register my new Electric Range (A gift)
I just filled out the card, put it in an envelope, addressed and stamped it, and sent it US Mail. Thanks. Fran Adams
Aug 05, 2008 | Maytag Kitchen Ranges
Owners manual for kodak 5300 printer
Download and install Adobe Reader, if you do not have it.
Use the Get Adobe Reader button at this link
http://www.adobe.com
I am assuming you made a typo as many of us do and the title is correct and this is a Kodak 5300 All-In-One printer please respond if it is not and I will search for the correct printer.
Your printer's manuals and software can be found here
http://www.kodak.com/global/en/service/products/ekn033540.jhtml?pq-path=9104
As I do not know your operating system or version of MSWord, the following are hints about how this is done and may not be step-by-step accurate for you
http://safari.oreilly.com/0201741474/ch08lev1sec5
http://www2.essex.ac.uk/cs/documentation/use/word6/howto/env-lab.html
Dec 23, 2007 | Office Equipment & Supplies
Help
Hi, solution for your envelope
10 envelopes The print side of the envelopes faces up.
The envelopes are loaded vertically against the right side of the paper support.
The stamp location is in the upper left corner and printed with landscape orientation.
NOTE: For Japanese customers: If you are mailing within Japan, the envelope can be printed with portrait orientation with the stamp in the lower right corner or with landscape orientation with the stamp in the lower left corner. If you are mailing internationally, print landscape orientation with the stamp in the upper left corner.
The paper guide rests against the left edge of the envelopes.
You select the correct envelope size. Select the next biggest size if the exact envelope size is not listed, and set the left and right margins so that your envelope text will be correctly positioned.
Oct 25, 2007 | Dell 810 All-In-One InkJet Printer
139 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
