Question about Kenwood M256A3 (256 MB) MP3 Player
My mp3 cannot connect my media player maybe i have an error of chosing usb port connection what connection i used? I see it in the removable disk but my computer cannot read the items. First of it i can dowload a song there is a menu appeared that i can perform it faster if i plugged in into a high speed port.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 64 Answers
Follow this link to solve it, http://www.fixya.com/support/r4391734-usb_flashdisk_pen_drive_write_protect , and dont forget to report to me ... good luck
Posted on Mar 22, 2010
Do I need a startup disk to use my player?
Delstar is a USB mp3 player and you don't need any statup disk. Maybe it came originally with a CD as help to intall USB port on windows 98SE
If it won't work simply inserting it in your USB port check if it's blocked by lock but I believe it has no lock so if won't work, it is DEAD.
Delstar 1GB MP3 Player Voice Recorder
May 27, 2015 | Delstar DS 31024 MP3 Player
How to download music on my phone
connect your media player to your computer, your media player will detect as mass storage device
at computer open windows explorer, all drive will show include your media player (usually named removable disk) open the mp3 file at your computer then chose the file you want to download by click the file, then at that file right click then chose copy
after that open your media player drive and open sound/music folder, at that folder right click and chose paste
and you can remove your media player from your computer
i hope this helpful
thank you for using fixya
Feb 15, 2011 | Acer Audio Players & Recorders
The pc is unable to detect the sansa disk
If you are using Windows XP: verify the following operating system requirements are met. - Windows XP SP2 or higher - Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. - Download the hotfix from http://support.microsoft.com/kb/939211. - Run the hotfix.
Refresh the driverd
1 - Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Apr 03, 2010 | SanDisk Sansa Clip MP3 Player
I m not concect for my pc for mp3 player
If you want connect you MP3 player to the computer - Use USB cable, connect to the Computer USB port, and another connect to your MP3 player - If you connect your computer automatically show within 4-5 second running to your computer. If run directly open Folder, If not running go to my computer and go to Removable Disk - then open and Share your mp3 or Data.
Jan 29, 2010 | Sony NWZB133F MP3 Player
Boot error please format unit, this is my daughters, that I bought her a couple of years ago, she hasn't used it much and of coarse I can't find the installation disk.
Using Xp and or Vista you will not need drivers for your player. It should show up under hardware in device manager as a portable device, if it has a yellow exclamation mark or a question mark under other devices delete it and right click the small computer icon at the top of the tree and chose scan for changes. Then chose portable device. Next Xp or Vista will want Media player 10 or higher to see your player, also you may have to turn off any anti virus that may cause a problem. Try hooking up on the back side of your computer, the USB ports on the rear of a computer are set up to power such devices better than the front panel USB ports. Leave it hooked up for a while to be sure it has charged some.
Jan 21, 2010 | RCA OPAL M4001 MP3 Player
Computer does not recognize Coby MP822 4G MP3 player
The actual MP3 player should display a USB connection on the screen, if not, I would say its a connection issue (bad USB cable), my guess is your using a laptop, a lot of laptops disable their USB power options, you probably need to re-enable your USB ports, if desktop, it should show a USB connection on MP3, if not, battery or cable issue.
Sep 13, 2009 | Audio Players & Recorders
Format
To format your Sansa, connect it to computer, using USB cable.
After connecting to the computer go to computer in Windows (My computer on XP), you should see the Sansa as Removable disk.
Click the right button of the mouse on the sansa disk that you get on Computer and chose format.
If you are asked for the FAT chose FAT32.
Sep 12, 2008 | SanDisk Sansa m230 MP3 Player
Hanging problem
ya u are rite connect the cable thr will show that mtp connected then transfer music but is it hanged on than this means ur usb port has problem than try to use different usb port...make it sure u are using rear usb port of ur pc.....hanging problem is only due to breakage in transfer of data that is only due to low usb port...i have same problem i always connect my media player in front usb port of pc then i got to know that it has low speed than i connect it to rear of usb port in my pc that is high speed port than it worked smoothly
Sep 02, 2008 | Samsung YP-K5JAB MP3 Player
Uknown format
When using your MP3 player for the first time you should format it. Formatting prepares the disk (storage medium) for any reading or writing. It erases all information on the disk, and tests for any bad sectors or errors. Below are the steps for formatting your player: -Connect the disk storage (MP3 player) to your computers USB port. If the computer pops up a window asking what do you want windows to do? Click cancel. -Right click on My Computer and click on Explore. Look for the drive Removable Disk (E:) [The letter drive may vary depending on your computer] This is your MP3 player. -Right click on the drive Removable Disk (E:) and click Format… A small window will pop up displaying Format Removable Disk (E:) Click Start. Read the warning and click OK. Format is complete.This procedure can be done occasionally to erase all data on the disk storage.
http://www.nextar.com/frontend/support.asp?CATEGORY=10000309&MODEL=MA715&subpr=624950167&categ=519278318
Jan 21, 2008 | Nextar MA7151B MP3 Player
Help me
According to the user manual for the MA933ASC, if you're not using Windows 98, the player should be recognized as a removable drive if you plug it into the USB port on your computer.
To erase your songs, connect the player. Open "My Computer", and find it listed as something such as "Generic Removable Disk", maybe drive G:\ or so seems to be popular in Windows. Once you're browsing the files on the player, you can delete them as you would any other file on your computer.
Hope this helps, for more information you can find the manual for your player online here.
Jan 14, 2008 | Nextar MA933ASC MP3 Player
Kenwood M256A3 (256 MB) MP3 Player Logo
27 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
