Question about Sport & Outdoor - Others
Electrical layout for pargo golf cart 800 7
Electrical layout for pargo golf cart 800 (7 )silinoids series ,need to hook up a new speed control switch
3 Suggested Answers
  • 161 Answers
SOURCE: trickle charger for storing electric cushman golf cart
contact manufacturer, and seek there advice
Posted on Nov 27, 2008
  • 6 Answers
SOURCE: electric golf cart, mash the pedal won't move
you have a broken belt .
Posted on Jun 03, 2009
Have fitted new electric motor to 2001 ezgo golf cart. Supplier insists its the correct motor .hooked up the same as the old motor but it wont run any ideas
Did everything work before you replaced the motor( except the motor)? If you have a lever by your right leg then you need a series motor. If there is a rocker arm switch in the dash then you need a sepex motor.
Sep 13, 2017 | Golf
How can I Speed up my 2004 Yamaha 36 v golf cart short of changing motor
If you are getting full voltage to the motor and that is the best you can do, then you have no recourse other than to change the motor.
Mar 31, 2017 | V Golf Golf
Electric golf cart won't run on cold mornings. I hear solenoid click but nothing happens. When the temp warms up, it runs normal. I replaced controller, solenoid, speed control and ITS & switch.
Depends on how cold it's getting outside. Cold weather is ******* a battery. Try load testing your batteries. That "clicking" noise makes me believe that it's trying to start, but it's not pulling enough amps. Considering everything that you've already replaced, I would start there. Assuming you've already made certain all of your connections are good. Also, make sure the ground wire for your electrical system is good. Not loose, corroded, etc...
You can even call the local golf course and ask to speak to the golf cart mechanic. I would get several calls a week from drivers when I worked as a diesel mechanic.
Oct 20, 2016 | Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
I need to know wires to to the key switch on my western golf cart
The battery wire goes to one side, the other goes to the starter (if gas) or the controller f/r switch (if electric). Any other wires that control 12 volt accessories that are "switched" will go to the same lug as the controller f/r switch. Wires that control accessories that can stay "hot" regardless of the key switch will usually go directly to the batteries. Be careful that you hook to the proper voltage on the batteries. They are wired in series, so two 6 volt batteries wired together will give you 12 volts...........any two batteries, as long as the cables connect them together. If you have 12 volt batteries and a 12 volt accessory (like a stereo or electric horn), you need only to wire across one battery.
Oct 09, 2014 | Golf
Why don't I get power to the motor on my Golf cart and how can I fix it.
Pleasecontact golf cart Kings out of Austin Texas. They will be more than glad to help you with this problem that you are encountering. Their Tek savvy is always free. Please be patient as so many people are always asking questions. But you can't beat free. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Aug 21, 2014 | RHOX Yamaha G14, G16, G19 Golf Cart 6"...
BuggiesGoneWild has all types of poems. Please visit their website. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
We are searching for a schematic for a Legend electric golf cart
THE BATTERIES ARE RUN IN SERIES THAT MEANS THAT THE WIRES GO POS. TO NEG. NEG. TO POS. STARTING IN THE BACK AND THEY RUN LIKE THIS TILL YOU GET TO THE OUTPUT FROM BATTERIES TO MOTORS THE CURRENT GOES IN ONE SIDE OF BATTERY AND OUT THE OTHER BY CONECTING ALL POSITIVES YOU MAY HAVE JUST KILLED THE BATTERIES
Jun 15, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
Sport & Outdoor - Others Logo
425 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
