Question about Navigon 2100 Portable GPS Receiver
Navigon 2100 displays the computer symbol when connected to charg
Navigon 2100 displays the computer symbol when connected to car charger. When the car charger is removed the system is working fine.
This started happening recently
    Problem Solver:
  • 9 Answers
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
Posted on Jan 19, 2011
How long for a full charge?
From what I read in the manual, it takes 4-5 hours to charge from a 'flat' state (0% charge), and a full charge will last about 3 hours.
Here's a link to the manual.
http://www.navigon.com/portal/common/Download/Manual/PNA/Navigon21xxmaxVM/English_manual.pdf
And a link to a replacement charger if you need one (Title might only say 1200/1210 but it works for 2100)
Jun 26, 2015 | Navigon 2100 Max Portable GPS System
Navigon 2100 car charger unscrewed. Found a few
[PDF] NAVIGON 2100/2120 User's Guide Your NAVIGON 2100/2120 comes with the following accessories. .... With the NAVIGON 2100/2120, you can also use an external GPS antenna (not pro- ...
support.navigonusa THEIRS A SITE FOR YOU YOUR FUSE IS A 6V 1 A RADIO SHACK SHOULD HAVE ONE OR PACK OF 5 6 BUCK OR SO
May 08, 2010 | Navigon 2100 Portable GPS Receiver
Navigon 2100 screen problem
When you changed your charger, did you get the right one?
I bought an iGo and thought I could use the standard min usb tip. However, tip number A53 does charge and show the map.
I hope this answers your question.
Mar 23, 2010 | Navigon 2100 Max Portable GPS System
The MN6.exe fatal Application error is displayed all the time and I am unable to use the Navigon 2100 GPS
push the reset button on the side of the system (a paperclip works well for this). Also, remove the card and put in again. If this doesn't work go to Navigons website and make sure you've downloaded all the software updates. Make sure your unit is fully charged as well. Don't waste your time emailing Navigon's CS online help....I attempted to contact them on 3 separate occassions and never got a response. Good luck. Hope one of my work-arounds helps you.
Dec 20, 2009 | Navigon 2100 Portable GPS Receiver
Computer symbol when charging my Garmin Nuvi 200
TRY SWITCHING GPS OFF WHILE CONNECTED. IF NOT DOWN LOAD NEW SOFTWARE AND WHEN FINISHED IT LEAVE CONECTED SHOULD SHOW CHARGING AND YOU WILL BE ABLE TO USE
Dec 18, 2009 | Navigon 2100 Portable GPS Receiver
Navigon 2100 freezes when plugged in
sounds like you have the wrong charger did you buy a non gen one? you can charge it from the pc with mini usb lead, but will show the same screen
Dec 06, 2009 | GPS
Plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
Dec 28, 2008 | Navigon 2100 Portable GPS Receiver
Screen stuck
Had same problem with a navigon 2100 and after trying my daughters car charger it worked properly. Called Navigon and they are sending me a new car charger.
Nov 27, 2008 | Navigon 2100 Max Portable GPS System
Navigon 2100 text to speech not working
the same happened to my 2100 3.5 inch. any remediatons?
Nov 14, 2008 | Navigon 2100 Max Portable GPS System
Navigon 2100 Portable GPS Receiver Logo
856 people viewed this question
Top Navigon GPS Experts
perdue40
Are you a Navigon GPS Expert? Answer questions, earn points and help others
