Question about Kodak DC4800 Digital Camera
Kodak dc4800 battery replacement
I bought a NP80 battery as a replacement for my original kodak battery. now i have issues with camera display while using new battery. after the fisrt shot display goes blank and doesn't come back. when i turn it off and on everything seems fine again till i try to shoot another picture. but everything works perfect with the old battery. i thought that it is the new battery so i went to the shop i bought it and tried numerous np80 batteries and came up with the same problem. does anybody know the reason?? and help me with this...thanks.
bmwrider
  • 215 Answers
SOURCE: New Rechargable Batteries Die after A Couple of Pictures
This model is renowned for poor battery life. Some people say using the CRV3 battery lasts a lot longer but my advice is to buy NimH batteries with at least 2600mah. Some Nimh are only 700mah and obviously will last less than a third the time of a 2600. Keeping the use of the LCD to a minimum will increase battery life and using the flash puts a tremendous drain on the batteries so if you can do without the flash switch it off. Combine these tips with a set of 2600mah batteries and I'll guarantee you'll be pleasantly surprised. As a sideline I always have a good laugh when I see an Olympics opening at night or a firework display and all you can see is thousands of flashes going off which the majority only reach about 12 feet maximum and the parade being shot is some 300 feet away. BMW
Posted on May 30, 2006
RattMur
  • 53 Answers
SOURCE: Kodak Z812 shuts off automatically
It is a high-powered camera, also knows as a GREAT camera. Use CRV-3 lithium duracell batteries. I have the same camera and the same "problem", but when I use that battery it lasts forever.
Posted on Jan 16, 2009
BillB-SA
  • 2761 Answers
SOURCE: Kodak Easy Share M763 Won't turn on!!
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 15, 2009
leepania
  • 1099 Answers
SOURCE: Kodak can't shoot
Download new firmware:
Connect the camera w. the computer and turn on
http://wwwuk.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=13239/13240&product=EKN035313
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 03, 2009
Ranglo
  • 1194 Answers
SOURCE: driver digital camera kodak dc4800
Visit this link to find driver or firmware for Kodak DC4800 Select appropriate operating system & Start downloading.
Good Luck....
Posted on Apr 12, 2010
I have a kodak z650, this is "new" machine in the original box but we never used in the past six years. When then i turn on in the LCD showed "Kodak easyshare logo" then turn off by itself... The le
If you really left the batteries alone for 6 years without regularly charging them, they won't work anymore. I still have two KLIC 500 batteries from Kodak, which I bought in 2005, Both are in very good condition, because the both get a charge every 3 months, even in periods I did not use my camera.
You could try. charging the batteries several times, but don't have to high expectations.
Jan 03, 2014 | Kodak Cameras
I need some original kodak batteries for my kodak camera?
You have to used Kodak batteries in Kodak camera it's so good original branded Kodak batteries can support your camera then you have to check this link of an website that gives discount on branded batteries such as Kodak batteries..................http://www.batterywarehouse.co.uk/brand/kodak
Mar 28, 2013 | Cameras
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
My kodak mx1063 camera barttery not holding charge even with a new battery
Did you buy a retail, OEM (original) battery?
I ran into the same issue. I bought a replacement battery from eBay only to find that it wasn't an OEM original battery; it was an asian replica that does no justice. I can barely get 10 minutes out of it.
After repurchasing the battery directly from the manufacturer, all those problems went away. The moral of the story is when you buy batteries, stick to OEM's. You will pay a bit more, but the quality is there.
Mar 06, 2011 | Kodak MX1063 Digital Camera
I have a DX7590 that won't charge the batteries.
Jeff, you didn't verify the type of battery that you have on your camera, is that the KLIC-5000? if yes then still it will not charged on your dock try to charged your camera using the 5V AC adapter. If your camera will not turn on using the 5V AC adapter or will not turn on using your dock it means the camera is defective and not your battery or charger. You can still contact Kodak repair center at 1 800 665 6515 they will handle your issue.
Feb 09, 2010 | Kodak EasyShare DX7590 Digital Camera
Kodak v1253 won't start
Assuming that you have fresh or fully charged batteries installed, chances are that the problem is corroded battery contacts inside the camera. Remove the batteries and clean the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue that's in the camera from the cleaning, then reinstall your batteries. Hopefully this will cure the problem and get the camera back up and working the way it should.
If that doesn't do the trick, you might want to try your luck with the Kodak Troubleshooting guide at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10&pq-locale=en_US
Jun 19, 2009 | Kodak EASYSHARE V1253 Digital Camera
Kodak C763 - fully charged battery - blue lights go and blink for a few seconds - camera will not turn on, lens does not open.
Hi-
When you say 'fully charged', is it the original battery from the camera, or another type of battery?
The description you give indicates one of three possible issues:
1. Your old battery can no longer hold a sufficient charge and though it can give enough to show activity (blue light), it may not hold enough to run the device. You may need to replace it > should be available at most retailers that sell Kodak cameras.
2. Wrong type of battery used. Check to see what type of battery the camera requires: NiCad, Lithium, etc. are all different, and not all can be used in these cameras. It's not just about the battery size.
3. Did you drop it? If so, the threads for the lense may have been damaged, not allwing it to eject from the body.
Since you bought a Kodak, you are lucky. If options 1 or 2 do not fix the problem, contact Kodak and they will usually take care of you.
DigiChick
May 28, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Easyshare camera doesn't work
I have the same the problem other people with this same problem on another kodak 'grumble' messageboard. Someone resolved the issue by using only the kodak batteries. I will go look for some.
Nov 13, 2007 | Kodak EasyShare C315 Digital Camera
Camera keeps turning off
Digital cameras are very Voltage Sensitive. Using Nicad or NiMh batteries will not only , "Not" solve the problems above but will
actually aggravate the above problems for one reason.
Rechargable NiCad or NiMh batteries only produce 1.2 volts fully charged and will only give you 2.4 volts when used in pairs with this camera. This falls below the cameras desired 2.8 - 3.0 voltage requirement and will only result in about 30-40 pictures at most.
This camera requires a constant 2.8 - 3.2 volts to run properly. Kodak won't tell you this !!The camera was designed with Oxy Akaline batteries in mind.New alkalines will produce 3.2 to 3.4 volts in pairs but only for a short period of time.The issue with the Oxy Alkaline batteries is that they simply will not last very long in this camera due to its power requirements.
But there is a really great solution to the problem . You can purchase a CRV3 rechargeable Li-ion battery that fits right into this camera.
You will get a realistic 180-250 photos per charge.The Li-Ion battery maintains a constant 3.0 volts for a very long period of time
and will allow the camera to function the way Kodak originally intended it to and can be recharged. You will find rechargable CRV3 battery kits on ebay or other online battery stores at a very reasonable cost.
You can also use a Lithium Non rechargeable CRV3 battery that will give approx 250-300 photos per battery but you may
find non rechargeable Lithium batteries cost prohibitive.
I use the rechargeable Li-ION Battery exclusively in this camera and it functions perfectly since I switched. I have a pair
of CRV3 Li-Ion batteries so I always have a fully charge CRV3 ready to go.
For reference I was only able to get about 30 pictures with the high capacity 2800 Mah Rechargeable NiMH Batteries I used prior
to using the LI-ION Battery. I get on average about 175 pictures per full charge from the LI-ION Battery.
Jun 14, 2007 | Kodak EasyShare C875 Digital Camera
Kodak DC4800 Digital Camera Logo
61 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
