Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson dx3850 won't load paper from left side of tray
How do I fix my printer
Epson printer xp 305 printer error E-01
This Epson Printer error E-01 occurs in the Epson Service Manual which indicates a type of fatal error. It simply signifies that the printer is incapable to finish the self-test process. When users are trying to power ON the printer it begins to check for all systems. If it is found that it is unable to finish the self test process then, the printer will come up with an error message as mentioned above. Follow these steps to resolve Error E-01.
Steps to Resolve Error E-01:
Step 1: Turn on/off the printer power button
  • Turn the power off. Wait for a while then turn on it again.
Step 2: Managing the lock of the printer
  • Store transportation lock carefully.
Step 3: Managing the CD tray
  • Press the CD Tray button to retract the tray to its original storage position. Be careful never to push or pull the CD tray into the wrong position. Turn off the Epson Printer and make sure that there is no paper left which may lead to paper jam issue inside the unit.
Step 4: Checking the printer cartridge
  • If the printer is installed with the CISS then, make sure that its carriage is easily movable towards left and right side.
  • The printer's upper scanner part should be closed tightly.
Step 5: Perform a check-up process.
  • Install original Epson ink cartridges and then run the printer.
Step 6: Access the cartridge
  • Access the cartridge loading area while the printer is in off-mode and then, move the carriage right away from the stop. Carefully disassemble the printer and then, clean all its optical sensors, paper feed sensors, encoder strip as well as disc encoder.
Contact Epson Printer Support Number if you have any issues in printer.
Apr 12, 2014 | Epson Stylus RX580 InkJet Photo Printer
Epson T60, Paper Loading Problem
Jumped through outside the tray? Plz, describe more clearly. Epson T60 is "best design" in paper feeder for A4 size printer. I have a lot.
Jan 23, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
Receipt printer paper reduction isn't working
Power the printer on and press the Paper button to see if paper will load.
If the paper doesn't load, make sure the paper isn't curled or creased, isn't loaded above the arrow on the left edge guide, and that the paper isn't jammed in the printer.
Take the paper stack from the tray; fan it before attempting to print.
Make sure the paper stack is leaning against the paper tray and not standing straight up in the tray.
If the Paper Out light is on solid, reload the paper, making sure the paper edge guide is adjusted to fit the paper's width, and then press the Paper button again to see if the paper will now load.
If the Paper Out light is flashing, turn the printer off, reload the paper, turn the printer back on, and try pressing the Paper Feed button again to see if the printer will now successfully load the paper. If the problem persists, power the printer off, remove the printer cable, and make sure all of the packing materials are removed.
If the problem is not resolved, contact Epson's technical support for further assistance.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Dec 10, 2012 | Epson TM-T88V (Part C31CA85081) Power...
EPSON PX660 Display load paper but when i load paper the feeder does not roll/pick up paper the paper
Make sure it's not jammed with paper then follow these instructions for loading paper.Power unit offOpen the paper support, then slide out the extension.
Open the front cover. Next, slide out the front tray extension.Make sure that the tray lever is in up position.Slide the edge guide to the left.Fan a stack of paper, then tap it on a flat surface to even the edges.Load the paper with the printable side up, against the right side of the sheet feeder and place it behind the tabs. The printable side is often white and brighter then the other side... if using non-standard A4.Slide the edge guid against the left edge of the paper, but not too tightly.Power unit back on.
Nov 17, 2011 | Office Equipment & Supplies
Loading paper into an epson stylus tx110
hi there... this is what you need.
Loading Paper Follow these steps to load paper: step_1.gif Slide the edge guide to the left. ha5280001h.gif step_2.gif Fan a stack of paper, then tap it on a flat surface to even the edges. step_3.gif Load the paper with the printable side up, against the right side of the sheet feeder. Then slide the left edge guide against the left edge of the paper, but not too tightly. ha5280002h.gif ha5280003h.gif mark_no.gifNote: Leave enough space in front of the printer for the paper to be fully ejected. Always load paper into the sheet feeder short edge first, even when you are printing landscape-oriented pictures. Make sure the paper stack fits under the fon4_99.gif arrow mark inside the left edge guide.pls vote for me
Mar 09, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus sx515w paper will not feed properly
pls make sure that you loaded the paper correctly.
Open the paper support and pull up the extensions. Open the output tray and pull out the extensions. Then flip up the paper stopper on the last extension, unless you’re printing on legal-size paper. . Flip the feeder guard up, out of the way, then squeeze the edge guide and slide it left. Insert paper, printable side up, against the right side and beneath the tab. Load paper short edge first, no matter which way your document faces.
Load letterhead or pre-printed paper top edge first.
Do not load paper with holes punched in it.
Do not load transparencies.
Do not load paper above the paper.4.3.4.jpg arrow on the edge guide.
Check the paper package for any additional loading instructions. 5. Slide the edge guide to the edge of the paper, but not too tightly. if you put the paper correctly and still not feeding the paper correctly, that means the rollers of the printer is broken
Feb 12, 2010 | Epson Office Equipment & Supplies
Dx3850 epsonprinter problem jam
It was not easy, but we found a solution.
There are two key points: how to remove the panel with all the LED and buttons, and how to dismount the scanner.
The first is easy: back to the panel there is a small ****. Raise it up, and push the panel to the back of the printer. The panel will slide backwards, and can be easily removed. Carefully disconnect the flat cable and remove it.
The second point is *much* more tricky. The chassis part near the USB plug is only cosmetic, and can be easily removed once the button panel was removed. There is a clip that may be operated in the most back part of the button panel. After opening the clip raisin it a little bit, the small part may be easily removed (forcing a little bit).
Under it there is a screw fixing the left side of the scanner. To remove it you must disconnect all the cables going to the scanner.
The screw on the right side is easily accessible from the scanner top.
The rest is easy
R. Rossi
Nov 21, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Paper feeds through crooked and comes out crunched
Make sure the blue slide device on the left side of the paper holder is tight against the paper. If not, the paper will feed corrked.
May 29, 2008 | Epson Stylus Color 740 InkJet Printer
EPSON R1800
Clean the rollers down where the paper sets in the printer. Do not use cheap generic matte coated paper. Some generic matte coated paper will leave a film on your rollers and cause them to not grip the paper.
Apr 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
200 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
