Question about Bush WS6671 28" TV
Tv will not turn on when you press the main power button
When you try to turn on tv from the main power button, it does not do anything , except makes a strange noise from inside the tv , like a squeaky sound , as if something is trying to work, The set is about five years old.
I ve got WS6679 32 '' and exactly same problem
  • Anonymous Jan 10, 2008
    the same as the other two
    Problem Solver:
  • 7 Answers
I think the ploblem should be the horizontal output that may be shot circuting working voltage,
apperently if you are not a qualify technician I recomend that you seek the help of such technician
Posted on Jan 25, 2008
Why is there a black screen?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 20, 2015 | Televison & Video
Lg 47lc7df tv blinks green light, no picture or sound
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 27, 2017 | LG 47LC7DF 47 in. LCD HDTV
Hitachi 55" plasma TV. 5 years plus old, used a
Please let me know whats the model number of the tv so that I can tell you what the PCB LED diagnostics are pointing to. It sounds like a power supply or Main board issue so I would like to confirm which one of them it is.
Dec 22, 2011 | Hitachi 55HDS69 55 in. Plasma Television
My tv won't turn on anymore. The power light and the opc light blink twice at the same time and then the opc blinks once and it keeps doing that. Please help!
Hi
Make sure the AC cord is not loose or disconnected. Check to ensure the cord is firmly plugged into the outlet at one end, and firmly connected to your television at the other end. The AC cord connects to the television about midway across the back of the set, near the bottom of the back panel. The hole for the AC connection is shaped like a figure eight. Try powering up the TV with the cords firmly connected.
Check the "Main Power" to ensure it is on. Locate the button on the top of the television among the "Volume" and "Channel" buttons. Press the button to switch the television on. If the "Main Power" button is off the remote will not turn on the television. Wait to see if pressing "Main Power" will activate the TV.
Press "TV Power" on the remote control to power up the TV from stand-by mode. If the power light on the front of the television glows red when you press "TV Power" on the remote, press the "Main Power" button on top of the television to remove the TV from stand-by. If the TV is accidentally in stand-by mode it may not come on when pressing certain buttons.
Check the circuit board. If your set still won't turn on and you hear a clicking noise when you plug it in, you most likely have a defective circuit board.
Oct 23, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sony KV-32FS12. Buttons on the TV don't work, the remote don't work. Now stuck in one channel. Can access Menu with TV button but can't go anywhere. Unplugged from main power source still no go. Tried...
Hello
Your TVs front control buttons are inoperative except menu button. There are microswiches fitted inside the main board of your tv from which shafts ar extented towars the front of the cabin where you press to access the functions. Replace all the micro swiches inside at onetime. It won't cost more. Micro swiches as they have said is mini swiches, which can get damaged easly with high pressure thumb or impact put on it.
Oct 15, 2010 | Sony KV-32FS12 32" TV
No response to any button on remote or tv except power button
Press the 'Favorite' button on the remote. You may have accidentally pressed it. It locks the channel. Pressing again unlocks.
Apr 22, 2009 | iLO 3200 32 in. LCD Television
Aquos LC37D40U Blinking light and won't turn on
The power light is an error code that tells me exactly what is wrong with the TV. Count how many times the POWER led flashes per second? (Dont worry about the OPC led)
1x per second (constant steady blink) = bad inverters/lamps
2x per second = bad power supply
3x per second = bad main board
If its 1x per second, try doing the factory initialization to get the TV back on to confirm a bad lamp/inverter.
Try doing the Factory Initialization (WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
  1. unplug tv
  2. press and hold at the same time “Vol –“ and “input” button on the TV set.
  3. while holding those buttons, plug the tv back in
  4. the tv should turn on by itself, keep holding the buttons until the letter “K” appears. Then let go.
Once the TV turns on, take a look at the screen. Does it flicker then shut off? Or do you hear a buzzing noise from the right edge of the TV? If so, then you have bad inverters or lamps. Once youre done, unplug the tv to get it out of the service menu.
If it is 2x per second or 3x per second, then those boards are just bad and they need to be replaced. There isnt anything you can do right now to fix it.
Mar 27, 2008 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
sounds like the line output transistor is shorted look for a repair kit for your model
Nov 04, 2007 | Bush WS6671 28" TV
Locked out of TV
Use two buttons on the tv at the same time, hold four seconds.
Try menu & power or vol up & chan up.........
Nov 04, 2007 | Televison & Video
Planar PDP42BK Plasma TV
It is the power supply. Replace the C97, C19, and C16 Capacitors with 2.2 uF ones.
Jul 10, 2007 | Planar PDP-42BK 42 in. Plasma HDTV
Televison & Video Logo
96 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
