Question about HP LASERJET P1005 Printer
My HP laser jet P1005 will not install from wizzard gets to pug in cable and then nothing it just keeps giving you the option of back why?
I had a similar problem as this with P1005 and Vista home. It could never get past the plug in printer to finish installation.
How I solved it was plugging in the printer, turning it on, going into the device manager and finding the printer. It was stuck under Other. Had a question mark next to it. I double clicked on the name, it opened up the details. I clicked on update driver. Browsed to HP CD that came with printer, it found teh first driver (not in the 9X directories). Clicked on the main driver and it installed!!
That's how I did it.
Posted on Sep 21, 2009
    Sergeant:
  • HP Expert
  • 424 Answers
Driver download link: HP LaserJet P1005 Printer Driver
Posted on Feb 06, 2010
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 13, 2009
Printe shows out of memory HP LASER JET P1005
If its refilled cartridge, replace with new one & check, even its showing same error check cartridge memory contact unit located under the cartridge bank...Most of the cases we observed memory reader unit breakages happening. while inserting the cartridge it has to move to contact memory.. if its not moving properly results no contact between memory and memory reader.
Jul 20, 2012 | HP LASERJET P1005 Printer
When im trying to print a document using an hp laser-jet p1005 the printer doesnt respond but i get an error message one of the usb devices has malfunctionedand windows does not recognise it wha should i...
unplug the usb from the computer. try uninstalling the printer from the control panel.
then reboot the computer and plug the usb back in so that it will reinstall.
this may help. try this first.
Mar 28, 2011 | HP Hewlett Packard LaserJet P1005 Printer
How to solve Firmware Download error on P1005
when i try to print by hp laser jet p1005 the red led is flashing then error appear (firmware download error) the printer was unable to communicate with your computer
what can i do to solve this problem
Mar 08, 2011 | HP Hewlett Packard LaserJet P1005 Printer
My HP laser jet P1005 cannot install with ACER Aspire windows 7 system but can install with another pc Vista system. why ? please help me, thanks
To instal HP Laserjet P1005 Printer on you Aspire System with Windows 7, you need to install Windows 7 drivers for HP P1005. Click here to go to HP Official and download Windows 7 Drivers for HP P1005. Select the Operating System (e.g. Windows 7 32-Bit)
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 07, 2010 | HP LASERJET P1005 Printer
Erro no fusor da hp laser jet p1005
it seems to me that the fuser is blown, and needs to be replaced, but to repair this requires a dissaembly of the fuser, its the themister and the element that is blown.
not worth it, replace it.
Nov 12, 2010 | HP LASERJET P1005 Printer
I run the hp laser jet p1005 setup cd on windows xp 2006. It goes well until it asks to connect the printer and power on.I did that.Then the hardware wizard identified the printer and displayed "you...
Ok,right click on my computer > manage >divice manager >just check for yellow or red cross button and right click on that say update driver it will give you a wizzard go thruogh it, if it red cross just click on enable
Sep 16, 2009 | HP LASERJET P1005 Printer
Unable to install printer. Disc supplied will not load. Printer is a HP Laser Jet P1005 Brought 11/8/2008 from post office
Go to hp.com support downolads. enter your model number and you should be able to download updated software and drivers.
Aug 11, 2008 | Office Equipment & Supplies
HP LASERJET P1005 Printer Logo
906 people viewed this question
Seeker5211
Seeker5211
