Hotpoint Aquarius door won't open at end of cycle?
    Brigadier General:
  • 3,917 Answers
Thank You for contacting Fixya.com.
•Disconect the washing machine from the mains supply
•The door seal is held in place on the door frame by a thin metal clamp band. This band is held in place at the top of the door seal with two plastic halves that clip together. To remove, insert a flat bladed screwdriver between the two halves and gently lever or prize them apart and then unpeel the door seal from the door frame
•Remove the soap dispenser drawer
•Remove the timer knob and control panel
•Undo the 3 scews that were behind the control panel and the 3 screws at the base of the front panel under the door
•Remove and carefully place the front panel to one side
•The pressure chamber bottle is attatched to the bottom of the tub at the end of the small rubber tubing coming from the door interlock. Remove it and thoroughly clean it out, paying attention to the small hole where the rubber tubing is attached.
The pressure system is how the washing machine controls the water levels. Disturbing it can cause water leaks, or even overfilling and flooding if the job isn't done properly.
Have a nice day.
GodBlessU
Posted on Sep 13, 2009
  • 135 Answers
SOURCE: Door won't open
Usual reason for this is not emptied correctly. The filter on this model is in an awkward place so try lowering drain hose into a bowl to check if water still in.
Posted on Nov 11, 2008
  • 99 Answers
SOURCE: Door Won't Open
This is joyce
Have you tried to go to ge.com and download your documenton. your book. put in your model # and this will give you some info on why the door wont open. their is a reason.
let me know if you need any help, if you cant find out why, let me know and I will research it a little more and see if I can get you some help, but you may have to call a technician out to fix problem.
thanks
joyce
Posted on Feb 13, 2009
  • 5 Answers
SOURCE: hotpoint aquarius wf320 1200 spin
its blocked...try the waste pipe
Posted on Nov 14, 2009
barkencoa
  • 3463 Answers
SOURCE: aquarius hotpoint wf541 wont pump the water out at
You need to clean the filter.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean the filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well
Hope this helps with your problem
Posted on Dec 28, 2009
  • 51 Answers
SOURCE: WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Posted on Feb 03, 2010
The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
Jan 12, 2013 | Washing Machines
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Door on hotpoint aquarious wont open at end of wash cycle...in spite of door light OFF. Have checked drain off plug..its OK!
door catch is faulty unplug machine take off lid put hand down to door switch and pull back to open door replace handle kit
Jun 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Door won't open
Nov 11, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius washing machine
where is the filter for hotpoint aquarius wma54 washing machine
May 31, 2008 | Washing Machines
Door locked
Press 'end of cycle' button for over 3 seconds, & wait for a couple of minutes then try the door. Do not force door.
Mar 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hi hotpoint wm62 door locked
Try "end of cycle" button & wait for 2 minutes before you try the door..........
Jan 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
502 people viewed this question
Top Washing Machines Experts
