Question about Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater
Have a richmond water heater model 6g50 pv-42f flashing a service code for the fvd interface failure. checked out room for vapors all o.k. need to know how to reset the controll modual. found out that my kid was spray painting model cars in the basement.
4 Suggested Answers
robocop
  • 90 Answers
SOURCE: need reset code for hot water talk
Go to www.richmondwaterheaters.com and see if they can assist you with it. Just click on residential products on the left side of the page.
Posted on Jan 22, 2009
gary1121
  • 332 Answers
SOURCE: 40gal richmond powervent wont light. code says fvd
sounds like the circuit board is bad,, when you turn on the unit does the fan come on first if not you need a circuit board, depending on the age it might be cheaper to change the whole unit
Posted on Jun 21, 2009
SOURCE: need reset code for richmond
I am poting this here hopefully it will help someone else. I have a richmond 40 gallon power vent water heater and it was not working. It was flashing 2-3 on the LED. I used this procedure and it started up..
you can reset the control by unplugging the blower during start up, leave unplugged for at least 5 seconds, plug back in and within 30 seconds cycle temp control from hot to low 6 times.
Posted on Apr 13, 2010
Reset lock out due to fvd
You can reset some models.... depending on gas control valve and FVIR design.
Some newer models you replace the sensor located on outside of tank.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-flammable-vapor-sensor-works-Therm-O-Disc-25VS.pdf
Gene
Jun 04, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 42VP50FW flashes 2-3 (FVD Interface/miswiring) wont ignite
Your safety device is probably sensing humidity as vapor. That's what ours seems to do. The replacement FVD is Rheem AP13447-3 Flammable Vapor Detection Sensor. It's down near the floor, can be pried off with a screwdriver, and unplugged. It needs to be replaced, since the heater will not ignite if its unplugged or too high resistance (detecting gas, or, if broken, moisture after a rain).
http://www.amazon.com/gp/product/B007IB22NM
Jan 02, 2012 | Water Heaters
Rheem water heater 42vp40sf and the fvd interface failure code is flashing. how do i fix this?
Call Rheem
1-800-432-8373
TRD is flammable vapor system. Typically there is a glass bulb or fuse located in the combustion chamber.
See example image:
http://waterheatertimer.org/images/FV-TRD-glass-fuse-300.jpg
Remove the burner and look for the evidence of broken glass bulb that holds the air intake open.
Air intake is located bottom of combustion chamber, and bulb breaks causing metal plate to snap upwards and close off air supply to combustion chamber.
Rheem will have exact part number and possible instructions. Other people have wedged the air intake open to get system working again, but I do not know if that will work with your model water heater with electronic control. Working around the FV system exposes home and people to flammable vapor ignition and explosion when water heater is exposed to flammable vapors.
Example manual with illustrations.
http://waterheatertimer.org/pdf/Test-if-thermal-release-device-needs-replacement.pdf
Clean burner and pilot orifice and combustion chamber while burner parts are removed. Also clean air intake.
When burner is removed for cleaning, the access door gasket might need to be replaced.
Your product manual and/or Rheem will have that part number.
Sep 23, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
FVD interface failure is flashing. How do I reset the water heater?
Is it flashing 2-3? Try this: You can reset the control by unplugging the blower during start up, leave unplugged for at least 5 seconds, plug back in and within 30 seconds cycle temp control from hot to low 6 times.
Nov 06, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
What does fvd interface malfunction mean
richmond lock out how to reset or restart my hot water heater
Oct 14, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
40gal richmond powervent wont light. code says fvd interface failer what does that mean????????
Jun 13, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Need reset code for hot water talk
Jan 17, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater Logo
340 people viewed this question
Top Audiovox Water Heaters Experts
paulcarew
jdthefixer
Richard Lindsey ...
Are you an Audiovox Water Heater Expert? Answer questions, earn points and help others
