Question about Keurig B70 Coffee Maker
Strong plastic smell and taste on a new Keurig Platnum coffee mak
Almost returned a new machine, because of the strong taste of plastic, it was nasty! tried washingout the water res with hot soapy water and then running about 8 large size brews and the problem was eliminated.
I had the same problem and I discovered that after running 3 resevoirs full of water through the machine at 192 degrees , it got rid of the plastic smell. Set the cup size at the largest size mug and then just open the lid and close it , hit brew and let it fill the cup. Dump the water in the sink and repeat until you go through at least 3 resevoirs. The smell should be gone by then.
Posted on Dec 19, 2010
  • ewabm Jan 30, 2011
    Thanks for the advice. It works like a charm :)
I tried running 3 tanks through my at the highest temp and still taste plastic. I have read elsewhere that you can run the regular descaling procedure as outlined in the manual with white vinegar and supposedly that takes care of the taste/smell of plastic. I just got this B70WR as a replacement for my old B70, hopefully I don't have to get another replacement.
Posted on Nov 22, 2012
How do I remove the bad Plastic Smell & Taste from my Keurig B70 Platinum coffee brewer?
That should not happen. Return for a replacement. The heating resovour may have factory material in side the unit.
Jan 21, 2013 | Keurig Platinum B70 Coffee Maker
Keurig drinks taste bad like plastic
try running viniger threw it then flush it out
Aug 29, 2012 | Cars & Trucks
We have a strong "plastic"
try washing with vinegar solution. it is just the new factory smell and taste.
Feb 03, 2011 | Samsung Refrigerators
Ran vinegar through to decalcify. The diagnostic returns after only 3 or 4 additional cupsof coffee.
try real cooffe machine descaller not vinegar real descaller melt the scale away vinegar remove in little piece that can block our machine its not strong enough with descaller rinse the machine very good after its nasty stuff thanks
pierre
Aug 01, 2009 | Keurig B60 Coffee Maker
Keurig new with burnt plastic smell
We had the same problem with the Keurig 2.0. We ran many cups of vinegar followed by water and it didn't fix the problem at all. The only fix was calling Keurig and they replaced the unit. We had a real nice 460. They replaced the unit with an inferior 350. Smaller reservoir, B&W screen and some missing menu options and different color trim. However, it works.
May 28, 2009 | Keurig B60 Coffee Maker
My coffee tastes weak
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with a bad burnt taste.
Dec 28, 2007 | Starbucks Barista Utopia
Lasting plastic smell
Obviously, this should not be! First, we need to know if the coffee maker is working correctly. If you have a candy/oven thermometer, check the output temp of the water. Be careful...it will be hot! The correct temp should be about 180-185 degrees. If it is hotter than that...return the machine. It has a defective thermostat.
What you can do about the taste: try taking some baking soda and mix it with the feed water. Use about 2 tablespoons in at least two cups of water. Then, add plain water. The baking soda can't hurt you but throw it away and clean the pot. Now, take some water and run it through. If the taste is gone...enjoy! If not, try another unit.
Nov 20, 2007 | KitchenAid Pro Line Coffeemaker Coffee...
Keurig B70 Coffee Maker Logo
6,447 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
