Plasmaa tv not going
The tv had white lines across the screen,which i asumed maybe dead pixels or burn in then one day it stopped goin,is this repairable and if so how much am i lookn at repair costs
    Problem Solver:
  • 6 Answers
Try using a ground isolator. You can buy them at radio shack, or your local hardware store for under 10 bucks. this item has three holes on one side and two posts on the other. it takes the ground out of the tv. We call those a scrolling line or a hum. Can be caused by incorrect wiring in the tv or the wires that run to the tv, could be running with electrical lines or an hvac unit. try this solution if it doesnt work then go to the altrenative which is sending the unit out for repair.
Posted on Dec 12, 2007
IT IS REPAIARABLE PROBLEM.WHEN I WAS WORKED IN VIDEO INCHARGE THAT TIME IT WAS ARISED IN G.P RIDER SIMULATER MACHINES .THAT TIME WE FOUND THAT DUE TO DESOLDRING IN POWER SECTION SIDE ,TRY YOUR TV ALSO
I keep running into this problem I have the LG 60PC1D and the sound comes through perfect but no picture. I keep resetting the tv by unplugging it and replugging it back in but to no avail. How can I fix this from happening in the future.
Posted on Apr 15, 2008
Sylvania tv model #6842pf has vertical lines on screen what does this mean
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations.
Jul 31, 2014 | Televison & Video
Flat panel TV shows a bright pinpoint of light in dark scenes
maybe or maybe not. It is a pixel that is stuck 'on' all the time. Not a warranty claim item as a few bad pixels are allowed.....
It does not spread, but that is not to say that another pixel somewhere else on the screen will not go bad.
Mar 26, 2010 | Sylvania LC225SSX LCD TV
A couple of days ago I turned on my brand new (about 6 weeks old) Samsung 50'' plasma pn50b650 I noticed an imperfect picture at the top of the screen. Upon closer inspection, there were about 4-5...
U freeze video games 10-20 mins in video game alot of time.Never pause or freeze any kinds of video image in Plasma tv.It very easy cause to burn in Plasma tv problems alots.
Feb 25, 2010 | Samsung PN50B650 50 in. HDTV Plasma TV
I have a Vizio 50-inch Plasma TV (out of warranty) from Costco and recently when I put the TV on pause while watching a show from my DirecTV DVR List, a white line (2-inches) vertically appeared on the TV...
it could be an image burn that was caused over time because you pause the screen to much or from a game or pc use.
You can try to clean it by going to the tv mode and go menu and go to set up and go doen to image cleaner.
Try that maybe it will take care of it.
Aug 10, 2009 | Televison & Video
White bubbles & dead pixel on my tv
This seems to be an issue with your DMD board, that's why you're seeing thosed bubbles and pixels
Jul 30, 2009 | Samsung Televison & Video
My screen on my asus 900 has two lines going across the bottom of the screen.
i may be incorrect, but i believe those lines are dead pixels, basically, they're lines of pixels (or dots) on the screen, that have become permanently one color, usually white or black
Jan 20, 2009 | ASUS Eee PC 900 Notebook
Black Vertical Lines in screen
All I can tell you is that you maybe have left your T.V. on a channel that didn't move for so long, or maybe someone else did and it burnt the screen. Plasma's run off of plasma gas to create the great picture and they collect on the screen and stick. What you need to do is go to your menu and look for "screen burn protection" and put it on white and let it sit for 20 minutes. All of one color such as white doesn't harm your T.V. The only way anything burns is like a bright white line in front of a black background.
Oct 26, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
ProScan PS32500 32"-Picture has white static line & Static/burning smell
It sounds like the circuit board is arching over somewhere. It could be as simply as cleaning and digging out the carbon mark to stop the arching. This is most likely the screen or focus voltage causing this, if there are no parts that have broken down. This will damage the printed circuit board and make things worse the more you let this cook. This could be dangerous for you to mess with because of the high voltage present, so my best advise would be to get this into the repair shop as soon as possible before this board burns up. It should not cost all that much if the CRT board can be repaired. Good Luck
Mar 21, 2007 | Proscan PS32500 32" TV
Televison & Video Logo
504 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
