When computer is started no signal appear on the monitor.
Dear sir
problem with my crt Acer Monitor
when computer is started no signal appear on the monitor.
  • m_maloochess Sep 14, 2009
    ِDear Toney-bones
    Your questions are answered as below:
    1- Is the monitor power light on? No
    2- Is the cable from the monitor connected tightly to the PC? Yes
    3- Does the LED on the monitor changes from red to green as your PC boots up? No because the LED is off and does not become active.
    THANKS
  • Tony-bones May 11, 2010
    Is the monitor power light on? Is the cable from the monitor connected tightly to the PC? Does the LED on the "monitor" change from red to green as your PC boots up?
  • 86 Answers
If your monitor is working fine, my guess is you might forgot to turn on the monitor power switch which is located at the lower right bottom corner. try it
Posted on Sep 13, 2009
Tick tick sound appear from acer 15" crt monitor power supply circuit
the sound you heard come from power regulator. its just fine, just indicate that part are over heat.
maybe you ill consider replace your monitor with LCD. more friendly for your eye and less power consumption
Mar 08, 2011 | Acer AC 711 17" CRT Monitor
My monitor is an Acer 20". model # X203H I am using a MSI MEGA computer which has a VGA connection. My Acer monitor has two connections aVGA and DVI , I am using the VGA connection from the ACER Monitor...
There is both an analog and digital setting on your monitor settings. Bring up the monitor settings and toggle between the digital and analog settings until you get a signal.
Sep 13, 2010 | Acer Computers & Internet
Dell laptop connected to 1209s projector...dell page indicates searching for signal and can't
Using the Display When you start the computer with an external device (such as an external monitor or projector) attached and turned on, the image may appear on either the display or the external device.
Press <Fn><F8> to switch the video image to the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, external DVI monitor only, and external CRT monitor and external DVI monitor simultaneously.
May 15, 2009 | Dell Latitude D800 Notebook
LG Monitor Display Problem
1. Mostly Loose contacts in video section that means CRT Neck board dry points checke it.
2.Pl check VGA Cable RGB signal pins 123 to ground 75 Ohms (on OK condition).
3.check 5v supply
4.check SDL and SCL signals.
Oct 05, 2008 | LG Studioworks 563N 15" CRT Monitor
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
Monitor
The computer is not accepting the card drivers or resolution out of range ...you may need start in safe mode then reinstall the drivers for the monitor. To start in safe mode you need to press the f8 button while starting up the PC. choose safe mode and wait for the PC to start up... right click my computer then choose properties and hardware and device manager.. look for the display driver and uninstall it..then re-install it and se if it works
Apr 30, 2007 | Acer AL1711 17" LCD Monitor
Acer monitor lcd
no signal means there is no communication between your monitor and your system unit.check and be sure your monitor signal cable is firmly connected,if nothing happens, try the monitor on your friend's system.if no change then try and replace the monitor signal cable, eyo7 eyoifiok2005@yahoo.com
Feb 28, 2007 | Acer Professional P211 21" CRT Monitor
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
