Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Code F10 - Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
  • 15,935 Answers
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
My Frigidaire oven shut off due to an f10 error which should I replace first since I have no tools to measure.ohms... sensor or EOC?
Good Morning mark, thank you for your post!
Based off the information you have provided your Frigidaire range is displaying an error code of "F10". An "F10" error code normally stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by flipping the household circuit breaker off for ten minutes. If you continue to experience an issue with the "F10" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. This will help you avoid any unnecessary part purchases. Hopefully this information has been helpful. -Matt
Feb 14, 2015 | Frigidaire Ovens
Frigidaire FEB24S5AB 24 inch F10
Hello friend, thanks for the post!
I understand your Frigidaire wall oven is flashing a F10 code and not heating up. Based off of that information an F10 code stands for a runaway temperature, which could be an issue with a sensor probe or oven control. It could possibly be a miscommunication with the board and that could be cleared out by resetting your appliance. To reset your appliance disconnect power to it by unplugging the oven or flipping the household circuit breaker for ten minutes. If that step does not resolve your issue and you continue to receive the F10 code I would recommend contacting a technician to come and repair your appliance. I hope this information is helpful. -Matt
Jul 23, 2014 | Frigidaire 24" Built-in Single Electric...
Crosley oven dont work f 10 gas
The "F10" oven error code means "Runaway temperature"
try this link http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/70424-what-does-f10-error-code-mean.html#ixzz2VTV50IJ4
Jun 06, 2013 | Ovens
Gaggenau over eb 270 error code f10
hello i m french f10 is a problemn of the temperature sonde that give gou the temperature of your gaggenau
May 26, 2012 | Ovens
Digital display is reading F10 and beeping and the oven shuts off after burning Banana Bread I also had smoke coming out the back panel of the stove top
The F10 error code means that a button on the touchpad is stuck.The error code can be cleared by pushing the cancel/off button and if the F10 returns the clock needs to be replaced since on that model the touchpad is part of the clock.
GENE
Sep 23, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
The letter and numbers f10 keeps appearing on my oven screen what does that mean?
0Hello,
The F10 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F10 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
GENE
Sep 09, 2011 | Kenmore 47702 / 47704 / 47709 Electric...
F10
Hello,the F10 error code means "Runaway temperature"most likely the problem is bad Electronic oven Control ("clock/timer").it has to be replaced together with the overlay because it's glued to the clock.
Thanks
Jun 01, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore oven error code f10
on that type of range F10 indicates a problem within the electronic control, but it could possible be caused by a faulty temperature sensor.
I would recommend service from a technician
May 27, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
159 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
