Question about Madison Avenue Dryers
Remote control ceiling fan randomly turns itself on, never off. I can turn the light off with the remote, but then it usually turns itself back on. This usually goes on for a couple minutes then it quits. The fan speed never adjusts, it just turns the light on. Curious if a different dip switch setting would fix the problem. I thought it might be catching interference from something else, though I would think fan speed or even shutting the light off would be affected. Any help would be greatly appreciated.
  • 33 Answers
Not necessarily true. Your fan light is controlled from the wall unit using radio, it's not hard wired, in most fans today. There is a promulgation of wireless devices in homes today, along with electronics and appliances that interfere. There are no easy answers here, you have to determine which item is causing the effect. Often times it's a microwave oven. My daughter was making breakfast in the kitchen using the stove, refrigerator, toaster and microwave. All of these appliances have electronics and can provide interference. Worst offender is the microwave oven which generates strong RFI inteference. You can test this by putting a 3' x 3' piece of alumnimum foil between the microwave oven and your fan. Not pretty, but at least you know the problem. Your microwave needs to be a goo 10-15 feet away from a device to minimize interference. Yes, that's not what you wanted to hear. Go back to a wired light.fan. There's most likely nothing wrong with your fan. Try changing the frequency that your fan uses. Probably won't help, buts costs nothing but your time. Good Luck
Posted on Jun 08, 2014
  • 323 Answers
SOURCE: remote not controling fan
You either have a bad receiver or the receiver isn't wired correctly,
On the receiver house wire side are black, white, and green.
On the receiver fan side are white, black, blue, and green. The black is hot for the fan, the blue is hot for the light. They can be wired together from receiver to fan.
At the bottom are a blue and a white wire to go to the lights.
Sometimes when installed the receiver is placed so that a part of the wiring box obstructs the signal from the remote and it doesn't work properly, or misses some commands.
I recommend buying a new remote and receiver and wiring the receiver in so that it rests on the sheetrock beside the wire in box.
Posted on May 26, 2009
SOURCE: Remote control ceiling fan
I am changing the remote in hunter fan an i got the wires mixed up coming from the fan what wire goes where?
Posted on Apr 12, 2008
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
  • 34 Answers
SOURCE: HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Posted on Sep 10, 2009
My hunter ceiling fan light keeps turning on randomly, it has been installed for @3 years (just recently started doing this). I have a remote control
There may be another remote control in the room/house that is causing it to turn on. A member of my family has a fan that uses a remote, when they turn on their stereo it also activated the dimmer on their ceiling fan light.
step 1 would be to ensure that it isnt other remotes that are causing this to happen.
step 2 would be to replace the batteries in the remote for the fan. once they are replaced use the remote to turn on and off the functions that are being turned on randomly.
if it is not anything to do with remotes, have the person that put it in for you disconnect it from power completely to try to reset the control board.
if that doesnt help, you may have a defective product that needs to be replaced.
if this doesnt work, report back with some more detail and I will try to help.
Feb 28, 2013 | Hunter Dryers
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
I have a Hunter fan with remote. The fan or the light comes on by itself with no one around
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!! P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Apr 02, 2010 | Hunter 52" Ceiling Fan With Light And...
The remote controls the light but not the fan
Make sure the switch isn't turned off. (Obvious, but it happens) Most of the time, this is a problem with the remote set itself (usually the receiver in my experience) You may be able to save a little bit by replacing it with a universal remote set. (available at the larger home stores) Good luck.
Mar 22, 2010 | Hunter Ceiling Fan Light Remote Control
My ceiling fans light randomely turns on through out the night should I return it?
You remote has a light timer. Press and release the Light timer button and set to "zero" with UP/DOWN arrows. Good luck!
Oct 30, 2009 | Hunter 52" Ceiling Fan With Light And...
10.27.09 - Ceiling Fan Light Kit not Working.
the remote does control the light. i think it's the bottom button, once to turn it on, again to turn it off. there should have been a blue wire connected in to the wires in the ceiling, this is power for the light. if only the white, black, and copper are connected, the light part won't work but the fan will (usually)
Oct 28, 2009 | Hunter 52" Ceiling Fan With Light And...
When I turn the light off with the remote control
im realy not trying to be a smart a*s but bont you only ever use lights at night?? i know i do?
it sounds like its the programer chip within the light that giving you the problem if taking the batterys out the controler dont stop this, its down to the light,
well there is one other thing it may be,,,
a friendly gost playing tricks on you???
or it could be that its getting a surge or spike of power from some were and that tricks the controler in the light to turn itself on???
sorry about that bit of fun as first just could not resist it????
Oct 26, 2009 | Hunter Ceiling Fan Light Remote Control
Ceiling fan and light with remote turns on and off by itself
Both the remote and reciever in the fan base have the ability to have the codes changed. What is happening is you are getting radio interference that is causing the problem. Change the codes by either switching the switches in different positions or adding more dip clips that came with the fan. In any case change the codes in both the reciever and remote to the same code and you should no longer have a problem. Usually the place to change the code in the remote is in the battery area and are small switches (usually 5 or 6 of them) and unfortunately you will have to take the fan down to do the one there.
Oct 12, 2009 | Hunter 52" Ceiling Fan With Light And...
Remote controlled ceiling fan has mind of it's own.
I have the same fan. The fan and the remote have some "jumpers" which allow you to change the codes, useful if someone else nearby has the same fan. You can see the jumpers inside the remote, open the back cover... you'll see "4 3 2 1" on the circuit board. Unfortunately you'll need to dismount the fan to change its jumpers, they need to be the same as the jumpers in your remote (which you can move around pretty easily).
Jul 01, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Ceiling fan/light quit working with remote
Fan does not respond to remote, checked and replaced batteries in remote. No response, and unfortunately it is now well out o warranty but have the same fan in another room purchased same year 2003 which is moving along fine. Cannot find instruction book for either one. Please help. Thanks
Dec 11, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
Dryers Logo
638 people viewed this question
Top Madison Avenue Dryers Experts
Dan Webster
Dan Webster
Are you a Madison Avenue Dryer Expert? Answer questions, earn points and help others
