Question about Durabrand DUR7 Portable DVD Player
DVD no picture
Duraband portable DVD player Model DBPD80. DVD not loading. Screen says loading and makes whirring noise but nothing comes on the screen.
  • 2 more comments
  • h_p_williams Sep 13, 2009
    I did use a ceaner but that didn't solve the problem!
    It doesn't seem as if the expert has offered enough information. The screen comes on so you can see it lit up but the DVD isn't playing!
  • h_p_williams Sep 15, 2009
    The only sound is whirring when the DVD is loaded first for a short peiod. Have tried different DVDs and CDs but nothing.
    What do you mean by the Diode
  • h_p_williams Sep 16, 2009
    Thank you for your response. It isn't covered anymore by the warranty so will need to find a repair person.
    Brigadier General:
  • 7,191 Answers
Your problem dated 13 Sept 09 was re-posted today. If it has been already resolved, kindly ignore this message.
Thanks for using FixYa
Posted on Aug 09, 2010
    Guru:
  • 194 Answers
Hello h p Williams This is a relatively common problem with all dvd players. The problem is that either the lens has become dirty or the lens has burnt out. If the lens is dirty , you have two relatively easy options to fix this. The first option is to go to your local music/electronics store and ask them for a cd/dvd lens cleaner kit. This kit consist of a CD with one or two little brushes on it , and a lens cleaning solution. You simply put a drop of solution on each of the brushes and then insert the cd/dvd in the dvd player. Play this disc for about 5 min and then try one of your normal disks. Repeat a few times if this does not solve your problem immediately. The other option requires you to have a little bit of technical knowledge. It involves removing the outer casing of the dvd player and locating the lens. Borrow some nail varnish REMOVER (not varnish, believe me , someone has made that mistake before) and put a drop on a cotton ear tip. Gently in a circular motion clean the lens. Do not press against the lens , just balance the cotton ear tip on the lens with your fingers. Now take another cotton tip and pull on the cotton to loosen it up a bit. Gently dry the lens in the same manner as you did the cleaning. Make sure no pieces of cotton got stuck near the lens after drying. Replace to cover and insert the power and it should work. If you followed either one of these steps and the unit will still not read a disc , the lens has blown and will have to be replaced. Depending on your unit , this will cost about half of the cost of a new player so I would suggest you replace the unit all together. I hope this information is helpful to you and please feel free to contact me if you need more information. Kind Regards Stephan
Posted on Sep 16, 2009
  • Stephan Reichert
    Stephan Reichert Sep 16, 2009
    Please remember to disconnect the power supply before opening the cover of the unit.
    I apologize for the lack of paragraphs in my post , I don't know why it posted this way.
    Stephan
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please tell me if you can hear any sounds from the player when the dvdv starts spinning? If sound is there then it is due to low diode strength. However, no picture and no sound then it may be a faulty/loose ribbon cable connector inside the player or the digital decoder is defective. Also try running a VCD or another DVD if it helps.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 13, 2009
  • Rylee Smith
    Rylee Smith Sep 15, 2009
    Hi
    By Low strength Diode i mean the laser diode that reads the content of your DVD and output it to the digital video processor may have faulty or its connection might be loose. As no sound is present it can also be a digital decoder. Please get this checked, and check if it is under warranty so that you can get it repaired.
    Thanks
    Rylee
    Brigadier General:
  • 3,614 Answers
It just seems that your player has a dirty optical lens and that wjy it cannot read the disc that you loaded., Better try to use a optical disc cleaner and try to clean the player lens.
Hope this helps
  • micromaster
    micromaster Sep 13, 2009
    that the only thing you can do, since you have already use a disc cleaner it just happen that your player may have a faulty lens, this need to be replace and fix.
    Hope this initial info helps.
Pioneer dv-2010 dvd player makes a whirring noise
That's because the lazer on the tray is trying to read the disc. Does this happen to other discs? When the lazer can't read the file, the drive spins up the disc to help it read it.
Dec 09, 2013 | Televison & Video
Why won't the battery hold a charge anymore?
The cause of this most batteries have CELLS once those cells break down then you will not be able to recharge this-is called CYCLES. What you doing when recharging is taking the energy completely out of the battery and replacing it will new and what this does is takes away a cycle. Once those cycles have been depleted then you cannot recharge it. Now you could take the battery out put it in a plastic bag and put it in a freezer but this will only last for short time.
Please be considerate when passing threw fixya to leave feedback and ratings for your free answer today
May 27, 2010 | Durabrand PDV-709
I have a Duraband Portable DVD player i think model 9PVS-1966) I can hear the dvd whirling but there is not picture....
sounds like the imager is bad, if you can see the menu thats good news. open and reseat all the ribbpon cables conneected to the lcd
Jul 10, 2009 | Durabrand PDV-709
Need owners manual
HI,
Unfortunately the manuals for your model have been discontinued.You will have to contact the Duraband support team and ask them to email you a copy of it.
May 15, 2009 | Durabrand DUR7 Portable DVD Player
Duraband portable dvd player
no, but I have one that I am listing on Ebay for sale.
Jul 22, 2008 | Durabrand PDV-709
RCA Portable DVD palyer
only thing you really can do is open it and check the fuses.
Dec 10, 2007 | RCA DRC6300N DVD Player/VCR
Durabrand dvd player code
I have a duraband pdv 705 and on the top of the screen it constantly has bri running through it
Nov 21, 2007 | Durabrand PDV-705 Portable DVD Player
VM9511TS wont eject
Does it make noises like it's trying to eject? Like whirring motors?
Sep 10, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Durabrand DUR7 Portable DVD Player Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
