Question about Car Audio & Video
Looking for an instruction manual for a 'sub-zero ice spla150 car amplifier' , distributed by Sakura Autoparts ltd.
SOURCE: Sub Zero Frezzer drawer
I had the same problem. I found the piece of plastic in the ice tray and couldn't figure how to put it back. I ordered a new ice flapper from the parts place on the internet and installed it. The ice maker now shuts off. Good Luck.
Rick S.
Posted on Mar 03, 2008
  • 7 Answers
SOURCE: ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Posted on Jun 01, 2008
SOURCE: Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Posted on Jun 30, 2008
wheelshot
  • 102 Answers
SOURCE: sub zero refrig - ice forming inside
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Posted on Apr 11, 2009
jpenn1192
  • 58 Answers
SOURCE: Installation Guide for Car Subwoofers
MOST OF THE TIME AMPLIFIED BOXES ARE EASYER THAN REG AMPS, ALL U HAVE TO DO IS RUN UR RCAS FROM THE BACK OF UR HEAD UNIT TO THE AMP, THAN UR POWER LEAD, FROM UR BATTERY TO THE AMP, THEN UR GROUND MOSTLY ON THE FRAM OF THE CAR OR ON THE BRACKETS ON UR SEATS, THATS MAINLY ALL U NEED TO NO.
Posted on Jun 18, 2009
Hifonics colossus-ltd dual monoblock amp does not have much output, running a cerwin vega stroker dual 2 ohm sub wired 4 ohm load bridged
Bridge at 4ohms your only getting 600watts rms. You will need to bridge at 1ohm (parallel) and adjust the gain accordingly. This will give it 1600 watts rms. If you would of had a dual 4ohm sub, then you could of bridged it at 2ohms mono, but you can't you have to go either 1 ohm or 4ohm. I believe it's not getting enough power.
May 20, 2012 | Hifonics Colossus-ltd Dual Monoblock 3200w...
I have sub-zero model 3211 red. My ice maker stop making ice. what to i do?
Here is a link to a Sub Zero Repair Video
http://www.appliancerepairlesson.com/shop/refrigerator/sub-zero-diy-repair-video-for-replacing-ice-maker/
Feb 20, 2011 | Sub-Zero Refrigerators
Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
My subzero 695 ice maker and water dispenser quit working. Do you have any ideas what I can do to make them start working again?
You might want to check out this forum. Your water controls on both the ice maker AND the door water are out? Could be a power supply issue or perhaps your unit only uses one water flow solenoid. Either way, head to this website and look for a forum for your unit.
http://safemanuals.com/brand-user-guide-instructions-owner-manual/SUB-ZERO
Dec 11, 2009 | Sub-Zero Refrigerators
Ice making for sub zero 48
The sub zero should make ice soon after being installed. If there is ice around the door frame of the freezer there may be a problem with the door frame heaters. There should not be ice around the door frame.
Nov 09, 2009 | Sub-Zero 661/F Side by Side Refrigerator
Sub-Zero service manual
Here is a link to the error codes. If there is a fault condition these should be flashing on the display:
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
One this to try is a hard reset: unplug and wait for a few minutes and re-plug back in. Sometime this resets the service condition and will then display the error codes.
Ice is displayed when the ice maker is turned on. Press the ice on/off and it should turn off.
Feb 19, 2009 | Sub-Zero 642
Ice maker in Sub Zero 642
Call the factory at 800-222-7820 for the manual. It souns like you are missing one or two screws. Pull the ice tray out and lift it up about an inch and it should release. Take a look at the ice maker and there are two supports that both need to have screws on them. There is also a third underneath on some models. Insert the screws and you should be fine.
Sep 16, 2008 | Sub-Zero 642
Feb 14, 2008 | Sub-Zero 690 Side by Side Refrigerator
Nov 21, 2007 | Sub-Zero 632 / S
Rick S.
Oct 26, 2007 | Sub-Zero 650 / O Bottom Freezer...
Car Audio & Video Logo
97 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
