Question about Apple iMac G5 Desktop
Mac 10.5 question mark at start up
Mac OS X 10.5 - question mark at start up
  • 31 Answers
Cannot locate the hard drive postion see: http://support.apple.com/kb/TS1440
Posted on Nov 20, 2009
    Problem Solver:
  • 16 Answers
Http://support.apple.com/kb/TS1440
Posted on Sep 13, 2009
I have a question mark on a file blinking have no internal disc only a external disc please help
The reason you are seeing the blinking question mark is that the computer is unable to find a disk with a usable version of Mac OS X on it. If you know for certain that the 256GB flash storage has Mac OS X try starting your computer without the external drive connected to it. If you still see a blinking question mark, then the Mac OS X installed on the 256GB SSD is corrupt and you have decisions to make.
1. You can get a friend with a Mac to download a copy of Mac OS X from the app store and burn it to a disk. You can then connect a dvd reader to your MacBook Pro, (if it does not have one built-in), and re-install Mac OS X on the flash drive. This will destroy whatever files you have on the disk. This is the shortest route to being able to use your machine again.
Another alternative is have Mac OS X burned to a USB drive and to boot your computer from that. This would give you a chance to save your files to an external drive before reinstalling Mac OS X on you Mac. (I have done this when an OS upgrade failed).
If you don't have a friend with a Mac, or feel uncomfortable following either of these two paths then I would suggest finding an Apple repair shop and letting them do the repair for you. I have no idea what it would cost so ask before committing yourself to the work.
If you live in an area with an Apple store, I would contact them to see if they can help you there. Good luck!
Feb 14, 2015 | Apple MacBook Pro 15" with Retina Display...
I have a question mark sign on my screen please help
sounds like your hard drive has come unplugged, you will have to remove the battery and possibly the "L" shaped metal strip then you can push the hard drive back in
Feb 14, 2015 | Apple MacBook Pro Laptop Computer with...
Why is my macbook air a1466 showin a file with a question mark when i turn it on and how do i fix it
http://support.apple.com/kb/ts1440
A flashing question mark appears when you start your Mac Symptoms
If you see a flashing question mark when you start your Mac, it's probably because it can't find the system software it needs to start up. Usually, all you have to do to get your Mac back up and running is remind it where its software is.
Resolution
If your computer starts up normally after a brief delay, you probably just need to reselect the startup disk in Startup Disk preferences. It's normal to see the flashing question mark when a startup disk has not been selected. In most cases, reselecting the startup disk is all that is required to resolve the issue.
Sometimes, your computer may not start beyond the flashing question mark.
Tip: If your computer has a gray screen (with no flashing question mark) startup issue, see Mac OS X: Gray screen appears during startup.
Check the mouse and keyboard
This issue might occur if a mouse or trackpad button is pressed during startup. Make sure the button isn't pressed.
If the issue persists, shut down your Mac with its power button, disconnect any external mouse and keyboard, then turn on your Mac with its power button. If the flashing question mark issue persists, reconnect the keyboard and mouse.
Additional steps
If your Mac still starts to a flashing question mark, follow the steps below. If any step resolves the issue, you don't need to continue to the next one.
  1. Select your Mac OS X startup disk with Startup Manager by restarting and holding the Option key. After your Mac starts up, restart again to verify that the flashing question mark does not appear.
  2. If the issue persists, insert your Mac OS X installation disc. Be sure to either use the disc that came with your Mac, or, if you installed a later Mac OS X version from disc, use the newer disc.
    MacBook Air note: On a MacBook Air, there are two options for starting up from Mac OS X media: Either connect a MacBook Air SuperDrive to the MacBook Air via the USB port and restart the computer, holding down the C key during startup, or use Remote Install Mac OS X to startup from a system software DVD that's located on a partner computer. Once started up from Mac OS X media, skip to step 3.
  3. Restart the computer, then hold the C key during startup.
  4. From the Utilities menu, choose Disk Utility. Don't click Continue.
  5. Select your Mac OS X disk (named "Macintosh HD" by default) in the left side of the Disk Utility window.
  6. Click the First Aid tab.
  7. Click Repair Disk to verify and repair any issues with your Mac OS X startup disk.
  8. After repairing the disk, try to start up normally.
    Important: If Disk Utility finds issues it cannot repair, you may need to back up as much of your data as possible (or use Time Machine to back up to a different disk), then erase the disk and reinstall Mac OS X. You should back up important files and data before erasing a drive. Erasing deletes everything on the hard disk (including things on your desktop). Also, you can install Mac OS X onto an external disk, start from the external disk, and use Migration Assistant to transfer items from your usual internal Mac OS X startup disk to the external disk, then erase the internal disk and reinstall Mac OS X.
  9. If the issue persists, and Disk Utility didn't find any irreparable issues, quit Disk Utility, quit the Installer, select your disk when prompted, and restart.
  10. If the issue continues, reset PRAM. Note: After resetting PRAM, if the computer starts up normally, reselect the startup disk in the Startup Disk preferences.
  11. If none of these steps resolve the issue, start up from the Mac OS X Installation disc and reinstall Mac OS X.
Last
Mar 30, 2014 | Computers & Internet
MacBook wont start up (Flashing Question Mark)
A flashing question mark indicates that your computer cannot find valid system software. Find your Mac OS X install disk, insert it, and then restart your computer while holding down the 'C' key. Use the included Disk Utility to repair your startup volume. If the problem still persists, then you may need to back up your data and reinstall OS X using the aforementioned install disk.
Jul 21, 2011 | Apple iBook G4 121 in (A1054) Mac Notebook
I have a Mac G4 desktop. It froze up so I restarted using the power button and when it came up it had a blinking question mark inside a folder. It will not do anything even after restarting several times....
This means the mac can not find the system to start up, you can try holding down the alt key as you start the mac, this may bring up a choice of systems to boot from if not then try holding down the shift key at startup, as this will boot without extensions loading. If none of this works then you need the startup dvd that came with the mac, if you dont have it the you need a retail copy of the mac os that will boot your mac , if its g4 then osx 10.3 or 10 .4 will work.
cheers
tech 240
Sep 13, 2010 | Apple iMac G4 Desktop
Installing a later version of mac to to get the printer to work
Here is a link for the Mac OS 9 driver for the MFC-420cn:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlf/000000/000600/dlf000680.html?reg=us&c=us&lang=en&prod=mfc420cn_us&type2=1&os=9&flang=4&dlid=dlf000680
If you need a newer version of Mac OS , you would have to purchase it. Mac OS does not update from 9.1 to 10.X
Mac 9.1 is about 10 years old.
In May 2002, at Apple's Worldwide Developers Conference in San Jose, California, Steve Jobs, accompanied by a coffin, held a mock funeral[5] to announce that Apple had stopped development of Mac OS 9. Mac OS 9.2.2, introduced in December 2001, was the final version of Mac OS 9, and the end of the classic Mac OS.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 08, 2009 | Brother MFC 420CN All-In-One InkJet...
Mac Powerbook shows file wih flashing question mark, won't boot.
The flashing question mark means that the computer can't find an OS.
If the computer previously was working, start up from the OSX disc and run 'Disc Utility' from the 'Utilities' menu in the top toolbar.
Run 'First Aid' to check and repair any errors.
If the computer still can't find an OS then you will need to re-install OSX.
Apr 15, 2009 | Apple PowerBook G4 Mac Notebook
Folder with blinking question mark in it after start-up
Folder with a blinking question mark means a missing system folder, in other words there isn't an OS installed. To fix this you need to boot from the OS X installer CD. With the OS X installer CD in the drive, hold down the C key on your keyboard when you start your mac. This tells the mac to boot from the optical drive (i.e. CD drive) and load the OS X installer. From there just follow the onscreen instructions to install OS X.
Also, you should be aware that the ibook is not compatible with Windows XP. Only the newer “intel macs” of the past few years are compatible with XP. Your mac predates Apple's transition to intel processors and Windows XP compatibility on the mac platform by a few years. This is why your Windows XP CD didn't load on it. The ibook is Mac OS X only.
It only runs on Mac OS X however it is compatible with newer versions of the OS. 10.2 jaguar is kind of old and a little buggy. You may want to consider installing 10.4 Tiger for improved stability and performance. Avoid the newest version (10.5 Leopard) as it is geared towards newer and faster machines.
Hope this helps. Enjoy your mac
Feb 03, 2009 | Apple Computers & Internet
Blinking question mark at startup
It's saying it cannot find the OS. You must have done something to it?  Put your disks in and it will start from them. You can also use it to fix the problem. Do a install and archive.
Nov 11, 2008 | Apple Mac OS X 10.4 Tiger for Mac
Mac drivers for 750z
Oh, there's no problem. I don't have an Optio 750z, but I do have an Optio 30 and it's older. Just tested with an iBook G4 that I just have installed Mac OS X Tiger 10.4.2 in. When the camera is attaced and turned on, iPhoto will open automatically and you have the option of import the images to your computer - you can also mark the "Delete images from the camera". The camera will also appear on the Finder desktop as a removable disc. So, seems to be no need for extra software.
Aug 30, 2005 | Pentax Optio 750Z Digital Camera
Apple iMac G5 Desktop Logo
201 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
