My behringer mixer phx2000 was took a lightning strike. the right speaker does not work. everything else seems ok
    Problem Solver:
  • 31 Answers
Should either unplug all electrical equipment during a storm or get a grounded filter to bleed off excess voltages from storms, power company fluctuation etc. Once the mixer electronics are fried you are SOL (**** Out of Luck) I'm afraid.
Posted on Sep 13, 2009
Can't hear playback through Headphone socket, only through speaker monitors!
i suggest you contact Behringer Customer Service for advixce. Without the setup in front of me, it's hard to figure out the wire routeing, switch positions, ect. that may be leading to this problem. As they would be the people most familiar with the gear, they'sd be the people to ask. http://www.music-group.com/support/behringer/askquestion
Oct 28, 2016 | Behringer Music
Evrything hookup there is no sound iget a good signal in the back of the sub so whats the problem
try connecting a speaker to the sub output terminals at low volume and see if it has loaded output, if it works , your subwoofers voice coil is open/blown
Jan 29, 2014 | Behringer EUROLIVE B1500D-PRO Active 15"...
Having problems connecting speakers via a power amp in to my behringer x2222 usb mixing desk - im not getting the ins and outs correct :(
I had a like problem with a crown amp. I found it was in the amp settings , nothing to do with the mixer set up. We had it a mono setting. Take a look at your amp set up book, i'll almost bet thats where the problem is
Dec 06, 2012 | Behringer Xenyx X2222USB USB Audio Mixer
Behringer Xenyx 1622FX - How do i get a passive stage monitor to work?
You need to send your signal from the mixer to an amplifier and then go from the amp to your speakers.
Alternatively, buy a pair of active speakers.
Jun 06, 2012 | Behringer XENYX 1622FX Premium 16 Ch Mixer...
No sound out of Behringer BXL3000 speaker
Suspected Faulty PC board Dead Capacitor Or Mod Pot I would suggest returning it for an exchange the problem is your speaker will work on a regular stereo because a stereo powers the sound internally causing the magnets in the speaker to vibrate Headphone jacks are designed to pick up off a seperate circuit board with a different connection to the main board hence the no sound from the speaker.
May 04, 2012 | Behringer Ultrabass Bxl3000
How to connect mixer to a crown power base 2 amp and speakers
just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
Nov 22, 2010 | Behringer *new* Behringer X1222 16-input...
How do I connect my behringer mixer desk to
The first thing to do is to swap teh L & R INPUTS to the amplifier. Did the speaker that works change?
If som the problem is with the setting of the mixer deck. If it did not change, then the problem is with your speaker wiring of the dead speaker, the speaker itself, or that side of the amp.
If the working speaker did swap, that means problem is with the mixer. The question then becomes how are you connecting to the mixer. You should be using TRS 1/4 inch connectors or preferably XLR from the MAIN outputs. These are balanced outputs connections.
If the inputs are from one of the mono inputs, the PAN control for that channel will control how much goes to each speaker... If at center, both will get same signal.
There are so many possibilities that I can't evaluate them until you try the test to find if it is problem of the amp or the mixer that I have given you to try.
Dec 28, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer pmh mixer manual. 20 channel 800watt powered mixer no speaker output. I need to test the power supply and the amp modual. Thanks
Are there lights or effects windows lit up? If so, the power supply is likely OK.
If neither speaker is working, that is bad however make sure all your trims and sliders are right to send audio through. Some have a standby switch.
This probably has an HCA2400 amp board in it and those can burn up for various reasons including loose speaker cables.
Nov 28, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
No Volume oe sound coming out of speakers
try connecting speakers to another sound source or if you have access to a ohm meter, check impedance of speakers, should measure 4~8 ohms.
Jan 25, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer F-CONTROL AUDIO... Problem:
I had a similar problem where as I could use the mic no problem at all but couldn't hear anything through the headphones. The simple solution was to disable the driver for my internal soundcard. It took me 48 hours to work it out! Good luck.
Jan 05, 2008 | Behringer FCA202 - FireWire Audio...
65 people viewed this question
 Grubhead
Grubhead
