Home | GE | (JASRM24912) Remote Control | TV CODES
GE Remote Control
Problem for GE (JASRM24912) Remote Control
TV CODES
By FRANKY2K on Dec 11, 2007
I LOST MY MANUAL AND I NEED CODES FOR A ORION TV MY REMOTE CONTROL MODEL IS GE (JASRM24912)
Sponsored Links
Same Problem
Jan 23, 2009
-   I have the same problem i need the code for Orion TV. -   dulcemaria56
Nov 28, 2008
-   NEED CODE FOR ORION TV-   Guest
Aug 17, 2008
-   I need a code for my t.v. The name of my t.v. is Symphonic-   tdss
Jul 26, 2008
-   i have a jasrm24912 and i lost my manual to it.
-   obdulop
Jul 14, 2008
-   GE Universal remote-   Guest
Best Solution
posted on Dec 11, 2007
Very Helpful)
Gigatech
Rank: Guru
Rating: 87%, 511 votes
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR, DVD, etc.). For AUX, press AUX then the device button you are assigning to AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed, repeat steps with the next code. If none of the codes listed for your device work for your device or your brand is not listed, try the Code Search method described below.
USING CODE SEARCH FUNCTION
If your TV, VCR, DVD, etc. does not respond after you have tried all the codes for your brand or if your brand is not listed, try searching for your codes by following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device button for the device you are programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will blink once then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
4. Press and release POWER until your device turns off. Wait at least 2 seconds between each time you press POWER. Important: You may have to press POWER up to 250 times.
5. When your device turns off press the ENTER/SAVE button. The INDICATOR LIGHT will go off.
Comments:
Dec 11, 2007
- ORION ....................... 0121 0135 0035
3-Digits Universal Remote Codes
ORION:035, 121, 135
3-Digits Universal Remote Codes (purchased before August of 2002)
ORION: 035, 191
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Feb 08, 2008
Helpful)
AZZZU
Rank: Apprentice
Rating: 85%, 1 votes
NEED CODE TO PROGRAM HELLO
Was this helpful?
Yes
No
Solution #3
posted on Jul 03, 2009
Not Rated)
danielesteba
Rank: Apprentice
Rating: 0%, 0 votes
tengo un control remoto universal GH RC84912 nesecito los codigos l para un televisor philips me lo pueden enviar a mi correo danielesteban_30@hotmail.com de ante mano gracias
Was this helpful?
Yes
No
Solution #4
posted on Jan 21, 2009
Not Rated)
sinaloa t20
Rank: Apprentice
Rating: 0%, 0 votes
Tengo Un Control Universal General Electric Modelo RC24912-d Pero No encuentro Los Codigos y El manual de uso.
Me Puede Dar Esa Información A Mi Correo Electronico BADIRAGUATO_87@HOTMAIL.COM
Was this helpful?
Yes
No
Solution #5
posted on Aug 31, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Muy Buenas Noches Tengo Un Control Universal General Electric Modelo RC84912 Pero No encuentro Los Codigos y El manual de uso.
Me Puede Dar Esa Información A Mi Correo Electronico micky_sanz777@hotmail.com Por Su Atención Muchisimas Gracias.
Popular Solutions for GE Remote Control
Questions and Unsolved Problems for GE Remote Control
Do you recommend GE (JASRM24912) Remote Control?
Answer
Answer
how do i program this remote to work on a magnavox tv
Answer
hello, I am trying to program my controller to my tv. need the step by step directions to set up. I... (More)
Answer
How can i program this remote to a Sansui television set.
Answer
Do you know the codes for a universal remote control for a philips tv?
8 Other Users Have The Same Problem - Continued
Comment by Guest, posted on May 24, 2008
need ge codes for sylvania tv
Comment by abcefghijk, posted on Apr 19, 2008
GE Remote Control rc24912-b
Comment by tie die, posted on Dec 12, 2007
lost manual for codes, need manual for tv
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Remote Control:
Top Remote Control Experts
Rank: Guru Guru
Solutions: 1444
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Remote Control Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
