Question about Whirlpool GEW9250 Electric Dryer
WE HAVE A WHIRPOOL DUET GEW9250PW1. THE CONTROL LIGHTED PANEL LIGHTS UP AND ALLOWS US TO CHOOSE OUR CYCLES BUT WHEN WE HIT START NOTHING COME ON AND WE HERE A CLICK SOUND ONLY
  • 3 more comments
  • dsbett4 Sep 13, 2009
    this is a dryer problem not a washer but thanks for the suggestion
    WE HAVE A WHIRPOOL DUET DRYER. WHEN THE DRYER IS TURNED THE PANEL LIGHTS UP AND ALLOWS US TO CHOOSE WHICH DRY CYCLE WE WANT, HOWEVER WHEN WE ATTEMPT START THE DRY CYCLE ALL WE HEAR IS A CLICK AND IT WILL NOT START. THE DOOR IS SHUT TIGHTLY AND WE CHECKED OUR CIRCUIT BOARD WHICH IS FINE. THANKS
  • dsbett4 Sep 14, 2009
    this is not the issue- thanks for trying
    it was not the thermal fuse. actually the pulley sheared from the motor itself, ? issue with how it was set up in the factory
    how do you remove the pulley from the motor
  • 298 Answers
Check water supply is open and water is reaching the machine. Possibly faulty solenoid on water supply valve.
Posted on Sep 13, 2009
  • Whirlpool Master
  • 17,970 Answers
Check in the diagnostic mode what code show it. Sound like a common problem:
1. Check the door switch with an ohm meter. It sounds like you might need a new one
Also, can review this document, Duet Dry Manuals
God luck.
Posted on Sep 14, 2009
    President:
  • 1,714 Answers
This usually indicates that the 'thermal fuse' is blown and will need to be changed. It's way down in the dryer and you will need to remove the back to get to it. Here is a picture of the thermal fuse:
  • Craig Butler
    Craig Butler Sep 14, 2009
    Have you checked it, the symptom you describe sounds like a thermal fuse?
How do you unlock a whirpool duet control panel?
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. This unlocks the control panel so that the washer is ready for use.
Read more : http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html How to Unlock the Control on Whirlpool Duet eHow
Sep 29, 2015 | Washing Machines
Control locked light is on? whirlpool duet dryer-mod GEW9250PW1.
Hi
Press and Hold the End of Cycle Signal button for 15 seconds, this will unlock the control. Hope this helps...please post back for further assistance.
Daniel
Sep 15, 2011 | Whirlpool GEW9250P Electric Dryer
I have a Whirlpool electric dryer, it is a Duet with a model # of: GEW9250PW1. When I try to select the the "normal" setting on the automatic side, it lights up the delicate light and has the...
Is the selector knob loose on the stem? Look on the knob to see if there is a set screw of some sort that you can tighten to set it where it belongs, it just seems it's loose and isn't pointing to where it should. Let me know if this works or not,
Please rate and comment, Thank you,
Joe
Sep 01, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
Duet whirpool washing machine stop and DLF sign appear
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Shane
Apr 03, 2011 | Washing Machines
I have a whirpool duet. The lights on the front panel light up, but the dryer will not start. I just hear a click and then nothing ????
Remove bottom panel and check the thermal fuse just behind the ducting. If this is blown it's a inexpensive fix. If it's good you may have a bad control board. Remove control board an inspect the back side of it for burning.
Rich
Western Appliance Repair
Appliance Repair Meridian
Oct 09, 2010 | Whirlpool Dryers
I have a whirlpool duet model GEW9250PW1 DRYER The display screen wont light up and there is power going to the unit I can hit the security lock and that indicator light comes on but that is the only...
sounds like the control board is out. If you remove the lower front cover a hex head screw in each corner, there should be a plastic pouch with tech sheets inside run test #1 part number for the board is 8546219
Oct 02, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Dryer
I have a whirlpool duet dryer GEW9250PW1 and the control panel wont come on, I have took out the circuit boards cleaned them with contact cleaner blew out the top and took off the bottom panel and blew it out, after all that it still wont come on unless you unplug it for at least 20 minutes.
Oct 07, 2009 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
503 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
